GSoC Project | Basic Support for Trace Compass
Thu Jul 25 07:30:02 UTC 2019
On 25/07/2019 09:24, Ravindra Kumar Meena wrote:
>     https://github.com/rmeena840/rtems-tools/commit/f7838f156006064ffc53b1b1d3fb01f80ef15ae4
>     No, sorry, this is not what we need. Maybe you should delete this code
>     part and start from scratch.
>     We process record events and produce LTTNG events. Is this clear?
>     Your task is:
>     1. Gather the information from two record events
>     (RTEMS_RECORD_THREAD_SWITCH_OUT and RTEMS_RECORD_THREAD_SWITCH_IN) with
>     the same timestamp on the same CPU.
> A CPU can have many records events. Since RTEMS_RECORD_THREAD_SWITCH_IN
> is received after RTEMS_RECORD_THREAD_SWITCH_OUT we can just directly
> write into corresponding CPU file after receiving
> RTEMS_RECORD_THREAD_SWITCH_IN for the same timestamp.
Yes.
All the record handling must be done per CPU.
>     2. Once you gathered the information of two events that meet this
>     criteria, you produce exactly one LTTNG sched_switch event.
>   Okay. So this particular lttng sched_switch will have prev_* value
> as RTEMS_RECORD_THREAD_SWITCH_OUT data and next_* value
> as RTEMS_RECORD_THREAD_SWITCH_IN.
Yes.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
