GSoC Project | Basic Support for Trace Compass
Ravindra Kumar Meena
rmeena840 at gmail.com
Thu Jul 25 08:44:40 UTC 2019
> > 1. Gather the information from two record events
> > (RTEMS_RECORD_THREAD_SWITCH_OUT and RTEMS_RECORD_THREAD_SWITCH_IN)
> with
> > the same timestamp on the same CPU.
> > A CPU can have many records events. Since RTEMS_RECORD_THREAD_SWITCH_IN
> > is received after RTEMS_RECORD_THREAD_SWITCH_OUT we can just directly
> > write into corresponding CPU file after receiving
> > RTEMS_RECORD_THREAD_SWITCH_IN for the same timestamp.
> Yes.
> All the record handling must be done per CPU.
> > 2. Once you gathered the information of two events that meet this
> > criteria, you produce exactly one LTTNG sched_switch event.
> > Okay. So this particular lttng sched_switch will have prev_* value
> > as RTEMS_RECORD_THREAD_SWITCH_OUT data and next_* value
> > as RTEMS_RECORD_THREAD_SWITCH_IN.
> Yes.
Have made changes:
https://github.com/rmeena840/rtems-tools/commit/4048dfb7f5c49ba731e46946b51b12af95088109
Have a look
I have made code more easy to understand.
Babeltrace output:
babeltrace . | head
[19:16:31.180116542] (+?.?????????) Record_Item sched_switch: { cpu_id = 17
}, { prev_comm = "0a01002b", prev_tid = 167837739, prev_prio = 0,
prev_state = 0, next_comm = "09010014", next_tid = 151060500, next_prio = 0
[19:16:31.180154588] (+0.000038046) Record_Item sched_switch: { cpu_id = 17
}, { prev_comm = "09010014", prev_tid = 151060500, prev_prio = 0,
prev_state = 0, next_comm = "0a01002b", next_tid = 167837739, next_prio = 0
[19:16:31.180174232] (+0.000019644) Record_Item sched_switch: { cpu_id = 17
[19:16:31.180223920] (+0.000049688) Record_Item sched_switch: { cpu_id = 5
}, { prev_comm = "09010015", prev_tid = 151060501, prev_prio = 0,
[19:16:31.180241405] (+0.000017485) Record_Item sched_switch: { cpu_id = 5
prev_state = 0, next_comm = "09010015", next_tid = 151060501, next_prio = 0
[19:16:31.180281360] (+0.000039955) Record_Item sched_switch: { cpu_id = 5
[19:16:31.180295428] (+0.000014068) Record_Item sched_switch: { cpu_id = 5
[19:16:31.180348740] (+0.000053312) Record_Item sched_switch: { cpu_id = 5
[19:16:31.180362596] (+0.000013856) Record_Item sched_switch: { cpu_id = 5
[19:16:31.180397048] (+0.000034452) Record_Item sched_switch: { cpu_id = 5
Both prev_* and next_* values are different.
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190725/a244df09/attachment-0001.html>
