[PATCH 02/10] TDA19988 : port to RTEMS
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri Jul 26 11:22:48 UTC 2019
 Makefile.todo                                 | 27 ++++++
 buildset/default.ini                          |  1 +
 libbsd.py                                     | 45 +++++++++
 rtemsbsd/include/bsp/nexus-devices.h          |  1 +
 .../machine/rtems-bsd-kernel-namespace.h      | 65 +++++++++++++
 rtemsbsd/include/rtems/bsd/local/clknode_if.h | 92 +++++++++++++++++++
 rtemsbsd/include/rtems/bsd/local/hdmi_if.h    | 71 ++++++++++++++
 .../include/rtems/bsd/local/opt_videomode.h   |  0
 rtemsbsd/local/clknode_if.c                   | 40 ++++++++
 rtemsbsd/local/hdmi_if.c                      | 35 +++++++
 10 files changed, 377 insertions(+)
 create mode 100644 rtemsbsd/include/rtems/bsd/local/clknode_if.h
 create mode 100644 rtemsbsd/include/rtems/bsd/local/hdmi_if.h
 create mode 100644 rtemsbsd/include/rtems/bsd/local/opt_videomode.h
 create mode 100644 rtemsbsd/local/clknode_if.c
 create mode 100644 rtemsbsd/local/hdmi_if.c
diff --git a/Makefile.todo b/Makefile.todo
index 42bedc15..358d6956 100644
--- a/Makefile.todo
+++ b/Makefile.todo
@@ -47,6 +47,10 @@ GENERATED += $(LOCAL_INC)/gpiobus_if.h
 GENERATED += $(LOCAL_SRC)/gpiobus_if.c
 GENERATED += $(LOCAL_INC)/iicbus_if.h
 GENERATED += $(LOCAL_SRC)/iicbus_if.c
+GENERATED += $(LOCAL_INC)/clknode_if.h
+GENERATED += $(LOCAL_SRC)/clknode_if.c
+GENERATED += $(LOCAL_INC)/hdmi_if.h
+GENERATED += $(LOCAL_SRC)/hdmi_if.c
 GENERATED += rtemsbsd/include/machine/rtems-bsd-regdomain.h
 GENERATED += rtemsbsd/rtems/rtems-bsd-regdomain.c
@@ -239,6 +243,29 @@ $(LOCAL_SRC)/sdhci_if.c: $(FREEBSD_SRC)/sys/dev/sdhci/sdhci_if.m
 	    -e 's|#include "sdhci_if.h"|#include <rtems/bsd/local/sdhci_if.h>|'
 	mv sdhci_if.c $@
+$(LOCAL_INC)/clknode_if.h: $(FREEBSD_SRC)/sys/dev/extres/clk/clknode_if.m
+	awk -f $(TOOLS)/makeobjops.awk $< -h
+	mv clknode_if.h $@
+$(LOCAL_SRC)/clknode_if.c: $(FREEBSD_SRC)/sys/dev/extres/clk/clknode_if.m
+	awk -f $(TOOLS)/makeobjops.awk $< -c
+	sed -i clknode_if.c \
+	    -e '1 i\#include <machine/rtems-bsd-kernel-space.h>\n' \
+	    -e 's|#include "clknode_if.h"|#include <rtems/bsd/local/clknode_if.h>|'
+	mv clknode_if.c $@
+$(LOCAL_INC)/hdmi_if.h: $(FREEBSD_SRC)/sys/dev/hdmi/hdmi_if.m
+	mv hdmi_if.h $@
+$(LOCAL_SRC)/hdmi_if.c: $(FREEBSD_SRC)/sys/dev/hdmi/hdmi_if.m
+	sed -i hdmi_if.c \
+	    -e 's|#include "hdmi_if.h"|#include <rtems/bsd/local/hdmi_if.h>|'
+	mv hdmi_if.c $@
 $(LOCAL_SRC)/gpio_if.c: $(FREEBSD_SRC)/sys/dev/gpio/gpio_if.m
 	mv gpio_if.c $@
diff --git a/buildset/default.ini b/buildset/default.ini
index 4acb2368..1d052a48 100644
--- a/buildset/default.ini
+++ b/buildset/default.ini
@@ -37,6 +37,7 @@ dev_usb_storage = on
 dev_usb_wlan = off
 dev_wlan_rtwn = off
 iic = on
+display = on
 dhcpcd = on
 dpaa = on
 evdev = on
diff --git a/libbsd.py b/libbsd.py
index 12d4c2ed..bb4f27e1 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -777,6 +777,50 @@ class iic(builder.Module):
             mm.generator['source']()
+# DISPLAY
+class display(builder.Module):
+    def __init__(self, manager):
+        super(display, self).__init__(manager, type(self).__name__)
+    def generate(self):
+        mm = self.manager
+        self.addKernelSpaceHeaderFiles(
+                'sys/dev/extres/clk/clk.h',
+                'sys/dev/hdmi/dwc_hdmi.h',
+                'sys/dev/hdmi/dwc_hdmireg.h',
+                'sys/dev/videomode/videomode.h',
+                'sys/dev/videomode/edidvar.h',
+                'sys/dev/videomode/edidreg.h',
+                'sys/dev/videomode/ediddevs.h',
+                'sys/dev/videomode/ediddevs_data.h',
+                'sys/dev/videomode/vesagtf.h',
+        self.addKernelSpaceSourceFiles(
+                'sys/arm/ti/am335x/tda19988.c',
+                'sys/dev/hdmi/dwc_hdmi.c',
+                'sys/dev/hdmi/dwc_hdmi_fdt.c',
+                'sys/dev/videomode/pickmode.c',
+                'sys/dev/videomode/edid.c',
+                'sys/dev/videomode/vesagtf.c',
+                'sys/dev/videomode/videomode.c',
+            mm.generator['source']()
+        self.addRTEMSSourceFiles(
+                'local/clknode_if.c',
+                'local/hdmi_if.c',
 # USB
@@ -5134,6 +5178,7 @@ def load(mm):
     mm.addModule(dev_input(mm))
     mm.addModule(evdev(mm))
     mm.addModule(iic(mm))
+    mm.addModule(display(mm))
     mm.addModule(dev_usb(mm))
     mm.addModule(dev_usb_controller(mm))
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index 97f6d2b2..3ec136ae 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -64,6 +64,7 @@ SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
 SYSINIT_DRIVER_REFERENCE(rtems_i2c, simplebus);
 SYSINIT_DRIVER_REFERENCE(ofw_iicbus, rtems_i2c);
 SYSINIT_DRIVER_REFERENCE(iic, iicbus);
+SYSINIT_DRIVER_REFERENCE(tda, iicbus);
 SYSINIT_DRIVER_REFERENCE(iicbus, rtems_i2c);
 #ifdef RTEMS_BSD_MODULE_NET80211
 SYSINIT_DRIVER_REFERENCE(rtwn_usb, uhub);
diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
index 235c9886..bef9f411 100644
--- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
+++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
@@ -563,7 +563,53 @@
 #define	clean_unrhdrl _bsd_clean_unrhdrl
 #define	ClearCheckNewLink _bsd_ClearCheckNewLink
 #define	clear_unrhdr _bsd_clear_unrhdr
+#define	clk_disable _bsd_clk_disable
+#define	clkdom_create _bsd_clkdom_create
+#define	clkdom_dump _bsd_clkdom_dump
+#define	clkdom_finit _bsd_clkdom_finit
+#define	clkdom_get_by_dev _bsd_clkdom_get_by_dev
+#define	clkdom_set_ofw_mapper _bsd_clkdom_set_ofw_mapper
+#define	clkdom_unlock _bsd_clkdom_unlock
+#define	clkdom_xlock _bsd_clkdom_xlock
+#define	clk_enable _bsd_clk_enable
+#define	clk_get_by_id _bsd_clk_get_by_id
+#define	clk_get_by_name _bsd_clk_get_by_name
+#define	clk_get_by_ofw_index _bsd_clk_get_by_ofw_index
+#define	clk_get_by_ofw_index_prop _bsd_clk_get_by_ofw_index_prop
+#define	clk_get_by_ofw_name _bsd_clk_get_by_ofw_name
+#define	clk_get_freq _bsd_clk_get_freq
+#define	clk_get_name _bsd_clk_get_name
+#define	clk_get_parent _bsd_clk_get_parent
 #define	clk_intr_event _bsd_clk_intr_event
+#define	clknode_class _bsd_clknode_class
+#define	clknode_create _bsd_clknode_create
+#define	clknode_disable _bsd_clknode_disable
+#define	clknode_enable _bsd_clknode_enable
+#define	clknode_find_by_id _bsd_clknode_find_by_id
+#define	clknode_find_by_name _bsd_clknode_find_by_name
+#define	clknode_get_device _bsd_clknode_get_device
+#define	clknode_get_flags _bsd_clknode_get_flags
+#define	clknode_get_freq _bsd_clknode_get_freq
+#define	clknode_get_name _bsd_clknode_get_name
+#define	clknode_get_parent _bsd_clknode_get_parent
+#define	clknode_get_parent_idx _bsd_clknode_get_parent_idx
+#define	clknode_get_parent_names _bsd_clknode_get_parent_names
+#define	clknode_get_parents_num _bsd_clknode_get_parents_num
+#define	clknode_get_softc _bsd_clknode_get_softc
+#define	clknode_init_parent_idx _bsd_clknode_init_parent_idx
+#define	clknode_register _bsd_clknode_register
+#define	clknode_set_freq _bsd_clknode_set_freq
+#define	clknode_set_parent_by_idx _bsd_clknode_set_parent_by_idx
+#define	clknode_set_parent_by_name _bsd_clknode_set_parent_by_name
+#define	clknode_stop _bsd_clknode_stop
+#define	clk_parse_ofw_clk_name _bsd_clk_parse_ofw_clk_name
+#define	clk_parse_ofw_out_names _bsd_clk_parse_ofw_out_names
+#define	clk_release _bsd_clk_release
+#define	clk_set_assigned _bsd_clk_set_assigned
+#define	clk_set_freq _bsd_clk_set_freq
+#define	clk_set_parent_by_clk _bsd_clk_set_parent_by_clk
+#define	clk_stop _bsd_clk_stop
+#define	clk_test_freq _bsd_clk_test_freq
 #define	comp_algo_deflate _bsd_comp_algo_deflate
 #define	comp_algorithm_lookup _bsd_comp_algorithm_lookup
 #define	config_intrhook_disestablish _bsd_config_intrhook_disestablish
@@ -775,6 +821,9 @@
 #define	drbr_needs_enqueue_drv _bsd_drbr_needs_enqueue_drv
 #define	driver_module_handler _bsd_driver_module_handler
 #define	dwc_driver _bsd_dwc_driver
+#define	dwc_hdmi_get_edid _bsd_dwc_hdmi_get_edid
+#define	dwc_hdmi_init _bsd_dwc_hdmi_init
+#define	dwc_hdmi_set_videomode _bsd_dwc_hdmi_set_videomode
 #define	dwc_otg_attach _bsd_dwc_otg_attach
 #define	dwc_otg_detach _bsd_dwc_otg_detach
 #define	dwc_otg_driver _bsd_dwc_otg_driver
@@ -1087,6 +1136,13 @@
 #define	e1000_write_vfta_generic _bsd_e1000_write_vfta_generic
 #define	e1000_write_vfta_i350 _bsd_e1000_write_vfta_i350
 #define	e1000_write_xmdio_reg _bsd_e1000_write_xmdio_reg
+#define	edid_is_valid _bsd_edid_is_valid
+#define	edid_nproducts _bsd_edid_nproducts
+#define	edid_nvendors _bsd_edid_nvendors
+#define	edid_parse _bsd_edid_parse
+#define	edid_print _bsd_edid_print
+#define	edid_products _bsd_edid_products
+#define	edid_vendors _bsd_edid_vendors
 #define	ehci_detach _bsd_ehci_detach
 #define	ehci_get_port_speed_hostc _bsd_ehci_get_port_speed_hostc
 #define	ehci_get_port_speed_portsc _bsd_ehci_get_port_speed_portsc
@@ -2732,6 +2788,7 @@
 #define	m_checkalignment _bsd_m_checkalignment
 #define	m_clget _bsd_m_clget
 #define	m_cljget _bsd_m_cljget
+#define	M_CLOCK _bsd_M_CLOCK
 #define	m_collapse _bsd_m_collapse
 #define	m_copyback _bsd_m_copyback
 #define	m_copydata _bsd_m_copydata
@@ -3442,6 +3499,8 @@
 #define	pgsigio _bsd_pgsigio
 #define	phashinit _bsd_phashinit
 #define	phashinit_flags _bsd_phashinit_flags
+#define	pick_mode_by_dotclock _bsd_pick_mode_by_dotclock
+#define	pick_mode_by_ref _bsd_pick_mode_by_ref
 #define	pipe_dtor _bsd_pipe_dtor
 #define	pipe_named_ctor _bsd_pipe_named_ctor
 #define	pipeselwakeup _bsd_pipeselwakeup
@@ -4614,6 +4673,7 @@
 #define	soreceive_generic _bsd_soreceive_generic
 #define	soreserve _bsd_soreserve
 #define	sorflush _bsd_sorflush
+#define	sort_modes _bsd_sort_modes
 #define	sosend _bsd_sosend
 #define	sosend_dgram _bsd_sosend_dgram
 #define	sosend_generic _bsd_sosend_generic
@@ -4722,6 +4782,7 @@
 #define	sysctl_handle_uma_zone_max _bsd_sysctl_handle_uma_zone_max
 #define	sysctl___hw _bsd_sysctl___hw
 #define	sysctl___hw_bus _bsd_sysctl___hw_bus
+#define	sysctl___hw_clock _bsd_sysctl___hw_clock
 #define	sysctl___hw_fdt _bsd_sysctl___hw_fdt
 #define	sysctl___hw_pci _bsd_sysctl___hw_pci
 #define	sysctl___hw_sdhci _bsd_sysctl___hw_sdhci
@@ -5450,6 +5511,10 @@
 #define	uuid_ether_add _bsd_uuid_ether_add
 #define	uuid_ether_del _bsd_uuid_ether_del
 #define	vht80_chan_ranges _bsd_vht80_chan_ranges
+#define	vesagtf_mode _bsd_vesagtf_mode
+#define	vesagtf_mode_params _bsd_vesagtf_mode_params
+#define	videomode_count _bsd_videomode_count
+#define	videomode_list _bsd_videomode_list
 #define	vlan_cookie_p _bsd_vlan_cookie_p
 #define	vlan_devat_p _bsd_vlan_devat_p
 #define	vlan_input_p _bsd_vlan_input_p
diff --git a/rtemsbsd/include/rtems/bsd/local/clknode_if.h b/rtemsbsd/include/rtems/bsd/local/clknode_if.h
new file mode 100644
index 00000000..97f4c956
--- /dev/null
+++ b/rtemsbsd/include/rtems/bsd/local/clknode_if.h
@@ -0,0 +1,92 @@
+ * This file is @generated automatically.
+ * Do not modify anything in here by hand.
+ * Created from source file
+ *   freebsd-org/sys/dev/extres/clk/clknode_if.m
+ * with
+ *   makeobjops.awk
+ * See the source file for legal information
+#ifndef _clknode_if_h_
+#define _clknode_if_h_
+struct clknode;
+/** @brief Unique descriptor for the CLKNODE_INIT() method */
+extern struct kobjop_desc clknode_init_desc;
+/** @brief A function implementing the CLKNODE_INIT() method */
+typedef int clknode_init_t(struct clknode *clk, device_t dev);
+static __inline int CLKNODE_INIT(struct clknode *clk, device_t dev)
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)clk)->ops,clknode_init);
+	rc = ((clknode_init_t *) _m)(clk, dev);
+	return (rc);
+/** @brief Unique descriptor for the CLKNODE_RECALC_FREQ() method */
+extern struct kobjop_desc clknode_recalc_freq_desc;
+/** @brief A function implementing the CLKNODE_RECALC_FREQ() method */
+typedef int clknode_recalc_freq_t(struct clknode *clk, uint64_t *freq);
+static __inline int CLKNODE_RECALC_FREQ(struct clknode *clk, uint64_t *freq)
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)clk)->ops,clknode_recalc_freq);
+	rc = ((clknode_recalc_freq_t *) _m)(clk, freq);
+	return (rc);
+/** @brief Unique descriptor for the CLKNODE_SET_FREQ() method */
+extern struct kobjop_desc clknode_set_freq_desc;
+/** @brief A function implementing the CLKNODE_SET_FREQ() method */
+typedef int clknode_set_freq_t(struct clknode *clk, uint64_t fin,
+                               uint64_t *fout, int flags, int *done);
+static __inline int CLKNODE_SET_FREQ(struct clknode *clk, uint64_t fin,
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)clk)->ops,clknode_set_freq);
+	rc = ((clknode_set_freq_t *) _m)(clk, fin, fout, flags, done);
+	return (rc);
+/** @brief Unique descriptor for the CLKNODE_SET_GATE() method */
+extern struct kobjop_desc clknode_set_gate_desc;
+/** @brief A function implementing the CLKNODE_SET_GATE() method */
+typedef int clknode_set_gate_t(struct clknode *clk, bool enable);
+static __inline int CLKNODE_SET_GATE(struct clknode *clk, bool enable)
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)clk)->ops,clknode_set_gate);
+	rc = ((clknode_set_gate_t *) _m)(clk, enable);
+	return (rc);
+/** @brief Unique descriptor for the CLKNODE_SET_MUX() method */
+extern struct kobjop_desc clknode_set_mux_desc;
+/** @brief A function implementing the CLKNODE_SET_MUX() method */
+typedef int clknode_set_mux_t(struct clknode *clk, int idx);
+static __inline int CLKNODE_SET_MUX(struct clknode *clk, int idx)
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)clk)->ops,clknode_set_mux);
+	rc = ((clknode_set_mux_t *) _m)(clk, idx);
+	return (rc);
+#endif /* _clknode_if_h_ */
diff --git a/rtemsbsd/include/rtems/bsd/local/hdmi_if.h b/rtemsbsd/include/rtems/bsd/local/hdmi_if.h
index 00000000..fc23c801
--- /dev/null
+++ b/rtemsbsd/include/rtems/bsd/local/hdmi_if.h
@@ -0,0 +1,71 @@
+ *   freebsd-org/sys/dev/hdmi/hdmi_if.m
+ * with
+ *   makeobjops.awk
+#ifndef _hdmi_if_h_
+#define _hdmi_if_h_
+#include <sys/eventhandler.h>
+typedef void (*hdmi_event_hook)(void *, device_t, int);
+EVENTHANDLER_DECLARE(hdmi_event, hdmi_event_hook);
+#define HDMI_EVENT_CONNECTED	0
+/** @brief Unique descriptor for the HDMI_GET_EDID() method */
+extern struct kobjop_desc hdmi_get_edid_desc;
+/** @brief A function implementing the HDMI_GET_EDID() method */
+typedef int hdmi_get_edid_t(device_t dev, uint8_t **edid,
+                            uint32_t *edid_length);
+static __inline int HDMI_GET_EDID(device_t dev, uint8_t **edid,
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,hdmi_get_edid);
+	rc = ((hdmi_get_edid_t *) _m)(dev, edid, edid_length);
+	return (rc);
+/** @brief Unique descriptor for the HDMI_SET_VIDEOMODE() method */
+extern struct kobjop_desc hdmi_set_videomode_desc;
+/** @brief A function implementing the HDMI_SET_VIDEOMODE() method */
+typedef int hdmi_set_videomode_t(device_t dev,
+                                 const struct videomode *videomode);
+static __inline int HDMI_SET_VIDEOMODE(device_t dev,
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,hdmi_set_videomode);
+	rc = ((hdmi_set_videomode_t *) _m)(dev, videomode);
+	return (rc);
+/** @brief Unique descriptor for the HDMI_ENABLE() method */
+extern struct kobjop_desc hdmi_enable_desc;
+/** @brief A function implementing the HDMI_ENABLE() method */
+typedef int hdmi_enable_t(device_t dev, int onoff);
+static __inline int HDMI_ENABLE(device_t dev, int onoff)
+	kobjop_t _m;
+	int rc;
+	KOBJOPLOOKUP(((kobj_t)dev)->ops,hdmi_enable);
+	rc = ((hdmi_enable_t *) _m)(dev, onoff);
+	return (rc);
+#endif /* _hdmi_if_h_ */
diff --git a/rtemsbsd/include/rtems/bsd/local/opt_videomode.h b/rtemsbsd/include/rtems/bsd/local/opt_videomode.h
index 00000000..e69de29b
diff --git a/rtemsbsd/local/clknode_if.c b/rtemsbsd/local/clknode_if.c
index 00000000..6f1c0ba3
--- /dev/null
+++ b/rtemsbsd/local/clknode_if.c
@@ -0,0 +1,40 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * with
+ *   makeobjops.awk
+#include <sys/param.h>
+#include <sys/queue.h>
+#include <sys/kernel.h>
+#include <sys/kobj.h>
+#include <rtems/bsd/local/clknode_if.h>
+struct kobjop_desc clknode_init_desc = {
+	0, { &clknode_init_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc clknode_recalc_freq_desc = {
+	0, { &clknode_recalc_freq_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc clknode_set_freq_desc = {
+	0, { &clknode_set_freq_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc clknode_set_gate_desc = {
+	0, { &clknode_set_gate_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc clknode_set_mux_desc = {
+	0, { &clknode_set_mux_desc, (kobjop_t)kobj_error_method }
diff --git a/rtemsbsd/local/hdmi_if.c b/rtemsbsd/local/hdmi_if.c
index 00000000..847f7d4d
--- /dev/null
+++ b/rtemsbsd/local/hdmi_if.c
@@ -0,0 +1,35 @@
+ * with
+ *   makeobjops.awk
+#include <sys/bus.h>
+#include <dev/videomode/videomode.h>
+#include <dev/videomode/edidvar.h>
+#include <rtems/bsd/local/hdmi_if.h>
+struct kobjop_desc hdmi_get_edid_desc = {
+	0, { &hdmi_get_edid_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc hdmi_set_videomode_desc = {
+	0, { &hdmi_set_videomode_desc, (kobjop_t)kobj_error_method }
+struct kobjop_desc hdmi_enable_desc = {
+	0, { &hdmi_enable_desc, (kobjop_t)kobj_error_method }
2.20.1
