[PATCH 03/10] am335x display drivers: Import from FreeBSD
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri Jul 26 11:22:49 UTC 2019
 freebsd/sys/arm/ti/am335x/am335x_ecap.c  |  202 ++++
 freebsd/sys/arm/ti/am335x/am335x_lcd.c   | 1085 ++++++++++++++++++++++
 freebsd/sys/arm/ti/am335x/am335x_lcd.h   |   60 ++
 freebsd/sys/arm/ti/am335x/am335x_pwm.h   |   35 +
 freebsd/sys/arm/ti/am335x/am335x_pwmss.c |  165 ++++
 freebsd/sys/dev/fb/fbreg.h               |  345 +++++++
 freebsd/sys/dev/syscons/syscons.h        |  693 ++++++++++++++
 freebsd/sys/dev/vt/vt.h                  |  474 ++++++++++
 freebsd/sys/sys/consio.h                 |  468 ++++++++++
 freebsd/sys/sys/fbio.h                   |  622 +++++++++++++
 freebsd/sys/sys/terminal.h               |  240 +++++
 freebsd/sys/teken/teken.h                |  221 +++++
 12 files changed, 4610 insertions(+)
 create mode 100644 freebsd/sys/arm/ti/am335x/am335x_ecap.c
 create mode 100644 freebsd/sys/arm/ti/am335x/am335x_lcd.c
 create mode 100644 freebsd/sys/arm/ti/am335x/am335x_lcd.h
 create mode 100644 freebsd/sys/arm/ti/am335x/am335x_pwm.h
 create mode 100644 freebsd/sys/arm/ti/am335x/am335x_pwmss.c
 create mode 100644 freebsd/sys/dev/fb/fbreg.h
 create mode 100644 freebsd/sys/dev/syscons/syscons.h
 create mode 100644 freebsd/sys/dev/vt/vt.h
 create mode 100644 freebsd/sys/sys/consio.h
 create mode 100644 freebsd/sys/sys/fbio.h
 create mode 100644 freebsd/sys/sys/terminal.h
 create mode 100644 freebsd/sys/teken/teken.h
diff --git a/freebsd/sys/arm/ti/am335x/am335x_ecap.c b/freebsd/sys/arm/ti/am335x/am335x_ecap.c
new file mode 100644
index 00000000..9ebc51db
--- /dev/null
+++ b/freebsd/sys/arm/ti/am335x/am335x_ecap.c
@@ -0,0 +1,202 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2013 Oleksandr Tymoshenko <gonzo at freebsd.org>
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/bus.h>
+#include <sys/kernel.h>
+#include <sys/limits.h>
+#include <sys/lock.h>
+#include <sys/module.h>
+#include <sys/mutex.h>
+#include <rtems/bsd/sys/resource.h>
+#include <sys/rman.h>
+#include <sys/sysctl.h>
+#include <machine/bus.h>
+#include <dev/ofw/openfirm.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#include "am335x_pwm.h"
+#define	ECAP_TSCTR		0x00
+#define	ECAP_CAP1		0x08
+#define	ECAP_CAP2		0x0C
+#define	ECAP_CAP3		0x10
+#define	ECAP_CAP4		0x14
+#define	ECAP_ECCTL2		0x2A
+#define		ECCTL2_MODE_APWM		(1 << 9)
+#define		ECCTL2_SYNCO_SEL		(3 << 6)
+#define		ECCTL2_TSCTRSTOP_FREERUN	(1 << 4)
+#define	ECAP_READ2(_sc, reg)	bus_read_2((_sc)->sc_mem_res, reg);
+#define	ECAP_WRITE2(_sc, reg, value)	\
+    bus_write_2((_sc)->sc_mem_res, reg, value);
+#define	ECAP_READ4(_sc, reg)	bus_read_4((_sc)->sc_mem_res, reg);
+#define	ECAP_WRITE4(_sc, reg, value)	\
+    bus_write_4((_sc)->sc_mem_res, reg, value);
+#define	PWM_LOCK(_sc)		mtx_lock(&(_sc)->sc_mtx)
+#define	PWM_UNLOCK(_sc)		mtx_unlock(&(_sc)->sc_mtx)
+#define	PWM_LOCK_INIT(_sc)	mtx_init(&(_sc)->sc_mtx, \
+    device_get_nameunit(_sc->sc_dev), "am335x_ecap softc", MTX_DEF)
+#define	PWM_LOCK_DESTROY(_sc)	mtx_destroy(&(_sc)->sc_mtx)
+static device_probe_t am335x_ecap_probe;
+static device_attach_t am335x_ecap_attach;
+static device_detach_t am335x_ecap_detach;
+struct am335x_ecap_softc {
+	device_t		sc_dev;
+	struct mtx		sc_mtx;
+	struct resource		*sc_mem_res;
+	int			sc_mem_rid;
+static device_method_t am335x_ecap_methods[] = {
+	DEVMETHOD(device_probe,		am335x_ecap_probe),
+	DEVMETHOD(device_attach,	am335x_ecap_attach),
+	DEVMETHOD(device_detach,	am335x_ecap_detach),
+	DEVMETHOD_END
+static driver_t am335x_ecap_driver = {
+	"am335x_ecap",
+	am335x_ecap_methods,
+	sizeof(struct am335x_ecap_softc),
+static devclass_t am335x_ecap_devclass;
+ * API function to set period/duty cycles for ECAPx
+int
+am335x_pwm_config_ecap(int unit, int period, int duty)
+	device_t dev;
+	struct am335x_ecap_softc *sc;
+	uint16_t reg;
+	dev = devclass_get_device(am335x_ecap_devclass, unit);
+	if (dev == NULL)
+		return (ENXIO);
+	if (duty > period)
+		return (EINVAL);
+	if (period == 0)
+		return (EINVAL);
+	sc = device_get_softc(dev);
+	PWM_LOCK(sc);
+	reg = ECAP_READ2(sc, ECAP_ECCTL2);
+	reg |= ECCTL2_MODE_APWM | ECCTL2_TSCTRSTOP_FREERUN | ECCTL2_SYNCO_SEL;
+	ECAP_WRITE2(sc, ECAP_ECCTL2, reg);
+	/* CAP3 in APWM mode is APRD shadow register */
+	ECAP_WRITE4(sc, ECAP_CAP3, period - 1);
+	/* CAP4 in APWM mode is ACMP shadow register */
+	ECAP_WRITE4(sc, ECAP_CAP4, duty);
+	/* Restart counter */
+	ECAP_WRITE4(sc, ECAP_TSCTR, 0);
+	PWM_UNLOCK(sc);
+	return (0);
+static int
+am335x_ecap_probe(device_t dev)
+	if (!ofw_bus_status_okay(dev))
+		return (ENXIO);
+	if (!ofw_bus_is_compatible(dev, "ti,am33xx-ecap"))
+		return (ENXIO);
+	device_set_desc(dev, "AM335x eCAP");
+	return (BUS_PROBE_DEFAULT);
+static int
+am335x_ecap_attach(device_t dev)
+	sc->sc_dev = dev;
+	PWM_LOCK_INIT(sc);
+	sc->sc_mem_res = bus_alloc_resource_any(dev, SYS_RES_MEMORY,
+	    &sc->sc_mem_rid, RF_ACTIVE);
+	if (sc->sc_mem_res == NULL) {
+		device_printf(dev, "cannot allocate memory resources\n");
+		goto fail;
+	return (0);
+fail:
+	PWM_LOCK_DESTROY(sc);
+	return (ENXIO);
+static int
+am335x_ecap_detach(device_t dev)
+	PWM_LOCK(sc);
+	if (sc->sc_mem_res)
+		bus_release_resource(dev, SYS_RES_MEMORY,
+		    sc->sc_mem_rid, sc->sc_mem_res);
+	PWM_UNLOCK(sc);
+	return (0);
+DRIVER_MODULE(am335x_ecap, am335x_pwmss, am335x_ecap_driver, am335x_ecap_devclass, 0, 0);
+MODULE_VERSION(am335x_ecap, 1);
+MODULE_DEPEND(am335x_ecap, am335x_pwmss, 1, 1, 1);
diff --git a/freebsd/sys/arm/ti/am335x/am335x_lcd.c b/freebsd/sys/arm/ti/am335x/am335x_lcd.c
index 00000000..7c0dd63e
--- /dev/null
+++ b/freebsd/sys/arm/ti/am335x/am335x_lcd.c
@@ -0,0 +1,1085 @@
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright 2013 Oleksandr Tymoshenko <gonzo at freebsd.org>
+ * are met:
+ * SUCH DAMAGE.
+#include <rtems/bsd/local/opt_syscons.h>
+#include <sys/clock.h>
+#include <sys/eventhandler.h>
+#include <sys/time.h>
+#include <vm/vm.h>
+#include <vm/pmap.h>
+#include <sys/fbio.h>
+#include <sys/consio.h>
+#include <dev/fdt/fdt_common.h>
+#include <dev/videomode/videomode.h>
+#include <dev/videomode/edidvar.h>
+#include <dev/fb/fbreg.h>
+#ifdef DEV_SC
+#include <dev/syscons/syscons.h>
+#else /* VT */
+#include <dev/vt/vt.h>
+#endif
+#include <arm/ti/ti_prcm.h>
+#include <arm/ti/ti_scm.h>
+#include "am335x_lcd.h"
+#include <rtems/bsd/local/fb_if.h>
+#include <rtems/bsd/local/hdmi_if.h>
+#define	LCD_PID			0x00
+#define	LCD_CTRL		0x04
+#define		CTRL_DIV_MASK		0xff
+#define		CTRL_DIV_SHIFT		8
+#define		CTRL_AUTO_UFLOW_RESTART	(1 << 1)
+#define		CTRL_RASTER_MODE	1
+#define		CTRL_LIDD_MODE		0
+#define	LCD_LIDD_CTRL		0x0C
+#define	LCD_LIDD_CS0_CONF	0x10
+#define	LCD_LIDD_CS0_ADDR	0x14
+#define	LCD_LIDD_CS0_DATA	0x18
+#define	LCD_LIDD_CS1_CONF	0x1C
+#define	LCD_LIDD_CS1_ADDR	0x20
+#define	LCD_LIDD_CS1_DATA	0x24
+#define	LCD_RASTER_CTRL		0x28
+#define		RASTER_CTRL_TFT24_UNPACKED	(1 << 26)
+#define		RASTER_CTRL_TFT24		(1 << 25)
+#define		RASTER_CTRL_STN565		(1 << 24)
+#define		RASTER_CTRL_TFTPMAP		(1 << 23)
+#define		RASTER_CTRL_NIBMODE		(1 << 22)
+#define		RASTER_CTRL_PALMODE_SHIFT	20
+#define		PALETTE_PALETTE_AND_DATA	0x00
+#define		PALETTE_PALETTE_ONLY		0x01
+#define		PALETTE_DATA_ONLY		0x02
+#define		RASTER_CTRL_REQDLY_SHIFT	12
+#define		RASTER_CTRL_MONO8B		(1 << 9)
+#define		RASTER_CTRL_RBORDER		(1 << 8)
+#define		RASTER_CTRL_LCDTFT		(1 << 7)
+#define		RASTER_CTRL_LCDBW		(1 << 1)
+#define		RASTER_CTRL_LCDEN		(1 << 0)
+#define	LCD_RASTER_TIMING_0	0x2C
+#define		RASTER_TIMING_0_HBP_SHIFT	24
+#define		RASTER_TIMING_0_HFP_SHIFT	16
+#define		RASTER_TIMING_0_HSW_SHIFT	10
+#define		RASTER_TIMING_0_PPLLSB_SHIFT	4
+#define		RASTER_TIMING_0_PPLMSB_SHIFT	3
+#define	LCD_RASTER_TIMING_1	0x30
+#define		RASTER_TIMING_1_VBP_SHIFT	24
+#define		RASTER_TIMING_1_VFP_SHIFT	16
+#define		RASTER_TIMING_1_VSW_SHIFT	10
+#define		RASTER_TIMING_1_LPP_SHIFT	0
+#define	LCD_RASTER_TIMING_2	0x34
+#define		RASTER_TIMING_2_HSWHI_SHIFT	27
+#define		RASTER_TIMING_2_LPP_B10_SHIFT	26
+#define		RASTER_TIMING_2_PHSVS		(1 << 25)
+#define		RASTER_TIMING_2_PHSVS_RISE	(1 << 24)
+#define		RASTER_TIMING_2_PHSVS_FALL	(0 << 24)
+#define		RASTER_TIMING_2_IOE		(1 << 23)
+#define		RASTER_TIMING_2_IPC		(1 << 22)
+#define		RASTER_TIMING_2_IHS		(1 << 21)
+#define		RASTER_TIMING_2_IVS		(1 << 20)
+#define		RASTER_TIMING_2_ACBI_SHIFT	16
+#define		RASTER_TIMING_2_ACB_SHIFT	8
+#define		RASTER_TIMING_2_HBPHI_SHIFT	4
+#define		RASTER_TIMING_2_HFPHI_SHIFT	0
+#define	LCD_RASTER_SUBPANEL	0x38
+#define	LCD_RASTER_SUBPANEL2	0x3C
+#define	LCD_LCDDMA_CTRL		0x40
+#define		LCDDMA_CTRL_DMA_MASTER_PRIO_SHIFT		16
+#define		LCDDMA_CTRL_TH_FIFO_RDY_SHIFT	8
+#define		LCDDMA_CTRL_BURST_SIZE_SHIFT	4
+#define		LCDDMA_CTRL_BYTES_SWAP		(1 << 3)
+#define		LCDDMA_CTRL_BE			(1 << 1)
+#define		LCDDMA_CTRL_FB0_ONLY		0
+#define		LCDDMA_CTRL_FB0_FB1		(1 << 0)
+#define	LCD_LCDDMA_FB0_BASE	0x44
+#define	LCD_LCDDMA_FB0_CEILING	0x48
+#define	LCD_LCDDMA_FB1_BASE	0x4C
+#define	LCD_LCDDMA_FB1_CEILING	0x50
+#define	LCD_SYSCONFIG		0x54
+#define		SYSCONFIG_STANDBY_FORCE		(0 << 4)
+#define		SYSCONFIG_STANDBY_NONE		(1 << 4)
+#define		SYSCONFIG_STANDBY_SMART		(2 << 4)
+#define		SYSCONFIG_IDLE_FORCE		(0 << 2)
+#define		SYSCONFIG_IDLE_NONE		(1 << 2)
+#define		SYSCONFIG_IDLE_SMART		(2 << 2)
+#define	LCD_IRQSTATUS_RAW	0x58
+#define	LCD_IRQSTATUS		0x5C
+#define	LCD_IRQENABLE_SET	0x60
+#define	LCD_IRQENABLE_CLEAR	0x64
+#define		IRQ_EOF1		(1 << 9)
+#define		IRQ_EOF0		(1 << 8)
+#define		IRQ_PL			(1 << 6)
+#define		IRQ_FUF			(1 << 5)
+#define		IRQ_ACB			(1 << 3)
+#define		IRQ_SYNC_LOST		(1 << 2)
+#define		IRQ_RASTER_DONE		(1 << 1)
+#define		IRQ_FRAME_DONE		(1 << 0)
+#define	LCD_END_OF_INT_IND	0x68
+#define	LCD_CLKC_ENABLE		0x6C
+#define		CLKC_ENABLE_DMA		(1 << 2)
+#define		CLKC_ENABLE_LDID	(1 << 1)
+#define		CLKC_ENABLE_CORE	(1 << 0)
+#define	LCD_CLKC_RESET		0x70
+#define		CLKC_RESET_MAIN		(1 << 3)
+#define		CLKC_RESET_DMA		(1 << 2)
+#define		CLKC_RESET_LDID		(1 << 1)
+#define		CLKC_RESET_CORE		(1 << 0)
+#define	LCD_LOCK(_sc)		mtx_lock(&(_sc)->sc_mtx)
+#define	LCD_UNLOCK(_sc)		mtx_unlock(&(_sc)->sc_mtx)
+#define	LCD_LOCK_INIT(_sc)	mtx_init(&(_sc)->sc_mtx, \
+    device_get_nameunit(_sc->sc_dev), "am335x_lcd", MTX_DEF)
+#define	LCD_LOCK_DESTROY(_sc)	mtx_destroy(&(_sc)->sc_mtx);
+#define	LCD_READ4(_sc, reg)	bus_read_4((_sc)->sc_mem_res, reg);
+#define	LCD_WRITE4(_sc, reg, value)	\
+/* Backlight is controlled by eCAS interface on PWM unit 0 */
+#define	PWM_UNIT	0
+#define	PWM_PERIOD	100
+#define	MODE_HBP(mode)	((mode)->htotal - (mode)->hsync_end)
+#define	MODE_HFP(mode)	((mode)->hsync_start - (mode)->hdisplay)
+#define	MODE_HSW(mode)	((mode)->hsync_end - (mode)->hsync_start)
+#define	MODE_VBP(mode)	((mode)->vtotal - (mode)->vsync_end)
+#define	MODE_VFP(mode)	((mode)->vsync_start - (mode)->vdisplay)
+#define	MODE_VSW(mode)	((mode)->vsync_end - (mode)->vsync_start)
+#define	MAX_PIXEL_CLOCK	126000
+#define	MAX_BANDWIDTH	(1280*1024*60)
+struct am335x_lcd_softc {
+	device_t		sc_dev;
+	struct fb_info		sc_fb_info;
+	struct resource		*sc_irq_res;
+	void			*sc_intr_hl;
+	int			sc_backlight;
+	struct sysctl_oid	*sc_oid;
+	struct panel_info	sc_panel;
+	/* Framebuffer */
+	bus_dma_tag_t		sc_dma_tag;
+	bus_dmamap_t		sc_dma_map;
+	size_t			sc_fb_size;
+	bus_addr_t		sc_fb_phys;
+	uint8_t			*sc_fb_base;
+	/* HDMI framer */
+	phandle_t		sc_hdmi_framer;
+	eventhandler_tag	sc_hdmi_evh;
+static void
+am335x_fb_dmamap_cb(void *arg, bus_dma_segment_t *segs, int nseg, int err)
+	bus_addr_t *addr;
+	if (err)
+		return;
+	addr = (bus_addr_t*)arg;
+	*addr = segs[0].ds_addr;
+static uint32_t
+am335x_lcd_calc_divisor(uint32_t reference, uint32_t freq)
+	uint32_t div, i;
+	uint32_t delta, min_delta;
+	min_delta = freq;
+	div = 255;
+	/* Raster mode case: divisors are in range from 2 to 255 */
+	for (i = 2; i < 255; i++) {
+		delta = abs(reference/i - freq);
+		if (delta < min_delta) {
+			div = i;
+			min_delta = delta;
+	return (div);
+static int
+am335x_lcd_sysctl_backlight(SYSCTL_HANDLER_ARGS)
+	struct am335x_lcd_softc *sc = (struct am335x_lcd_softc*)arg1;
+	int error;
+	int backlight;
+	backlight = sc->sc_backlight;
+	error = sysctl_handle_int(oidp, &backlight, 0, req);
+	if (error != 0 || req->newptr == NULL)
+		return (error);
+	if (backlight < 0)
+		backlight = 0;
+	if (backlight > 100)
+		backlight = 100;
+	LCD_LOCK(sc);
+	error = am335x_pwm_config_ecap(PWM_UNIT, PWM_PERIOD,
+	    backlight*PWM_PERIOD/100);
+	if (error == 0)
+		sc->sc_backlight = backlight;
+	LCD_UNLOCK(sc);
+	return (error);
+static uint32_t
+am335x_mode_vrefresh(const struct videomode *mode)
+	uint32_t refresh;
+	/* Calculate vertical refresh rate */
+        refresh = (mode->dot_clock * 1000 / mode->htotal);
+	refresh = (refresh + mode->vtotal / 2) / mode->vtotal;
+	if (mode->flags & VID_INTERLACE)
+		refresh *= 2;
+	if (mode->flags & VID_DBLSCAN)
+		refresh /= 2;
+	return refresh;
+static int
+am335x_mode_is_valid(const struct videomode *mode)
+	uint32_t hbp, hfp, hsw;
+	uint32_t vbp, vfp, vsw;
+	if (mode->dot_clock > MAX_PIXEL_CLOCK)
+		return (0);
+	if (mode->hdisplay & 0xf)
+		return (0);
+	if (mode->vdisplay > 2048)
+		return (0);
+	/* Check ranges for timing parameters */
+	hbp = MODE_HBP(mode) - 1;
+	hfp = MODE_HFP(mode) - 1;
+	hsw = MODE_HSW(mode) - 1;
+	vbp = MODE_VBP(mode);
+	vfp = MODE_VFP(mode);
+	vsw = MODE_VSW(mode) - 1;
+	if (hbp > 0x3ff)
+		return (0);
+	if (hfp > 0x3ff)
+		return (0);
+	if (hsw > 0x3ff)
+		return (0);
+	if (vbp > 0xff)
+		return (0);
+	if (vfp > 0xff)
+		return (0);
+	if (vsw > 0x3f)
+		return (0);
+	if (mode->vdisplay*mode->hdisplay*am335x_mode_vrefresh(mode)
+	    > MAX_BANDWIDTH)
+		return (0);
+	return (1);
+static void
+am335x_read_hdmi_property(device_t dev)
+	phandle_t node, xref;
+	phandle_t endpoint;
+	phandle_t hdmi_xref;
+	struct am335x_lcd_softc *sc;
+	node = ofw_bus_get_node(dev);
+	sc->sc_hdmi_framer = 0;
+	 * Old FreeBSD way of referencing to HDMI framer
+	if (OF_getencprop(node, "hdmi", &hdmi_xref, sizeof(hdmi_xref)) != -1) {
+		sc->sc_hdmi_framer = hdmi_xref;
+		return;
+	 * Use bindings described in Linux docs:
+	 * bindings/media/video-interfaces.txt
+	 * We assume that the only endpoint in LCDC node
+	 * is HDMI framer.
+	node = ofw_bus_find_child(node, "port");
+	/* No media bindings */
+	if (node == 0)
+		return;
+	for (endpoint = OF_child(node); endpoint != 0; endpoint = OF_peer(endpoint)) {
+		if (OF_getencprop(endpoint, "remote-endpoint", &xref, sizeof(xref)) != -1) {
+			/* port/port at 0/endpoint at 0 */
+			node = OF_node_from_xref(xref);
+			/* port/port at 0 */
+			node = OF_parent(node);
+			/* port */
+			/* actual owner of port, in our case HDMI framer */
+			sc->sc_hdmi_framer = OF_xref_from_node(OF_parent(node));
+			if (sc->sc_hdmi_framer != 0)
+				return;
+static int
+am335x_read_property(device_t dev, phandle_t node, const char *name, uint32_t *val)
+	pcell_t cell;
+	if ((OF_getencprop(node, name, &cell, sizeof(cell))) <= 0) {
+		device_printf(dev, "missing '%s' attribute in LCD panel info\n",
+		    name);
+		return (ENXIO);
+	*val = cell;
+	return (0);
+static int
+am335x_read_timing(device_t dev, phandle_t node, struct panel_info *panel)
+	int error;
+	phandle_t timings_node, timing_node, native;
+	timings_node = ofw_bus_find_child(node, "display-timings");
+	if (timings_node == 0) {
+		device_printf(dev, "no \"display-timings\" node\n");
+		return (-1);
+	if (OF_searchencprop(timings_node, "native-mode", &native,
+	    sizeof(native)) == -1) {
+		device_printf(dev, "no \"native-mode\" reference in \"timings\" node\n");
+		return (-1);
+	timing_node = OF_node_from_xref(native);
+	error = 0;
+	if ((error = am335x_read_property(dev, timing_node,
+	    "hactive", &panel->panel_width)))
+		goto out;
+	    "vactive", &panel->panel_height)))
+		goto out;
+	    "hfront-porch", &panel->panel_hfp)))
+		goto out;
+	    "hback-porch", &panel->panel_hbp)))
+		goto out;
+	    "hsync-len", &panel->panel_hsw)))
+		goto out;
+	    "vfront-porch", &panel->panel_vfp)))
+		goto out;
+	    "vback-porch", &panel->panel_vbp)))
+		goto out;
+	    "vsync-len", &panel->panel_vsw)))
+		goto out;
+	    "clock-frequency", &panel->panel_pxl_clk)))
+		goto out;
+	    "pixelclk-active", &panel->pixelclk_active)))
+		goto out;
+	    "hsync-active", &panel->hsync_active)))
+		goto out;
+	    "vsync-active", &panel->vsync_active)))
+		goto out;
+out:
+	return (error);
+static int
+am335x_read_panel_info(device_t dev, phandle_t node, struct panel_info *panel)
+	phandle_t panel_info_node;
+	panel_info_node = ofw_bus_find_child(node, "panel-info");
+	if (panel_info_node == 0)
+		return (-1);
+	am335x_read_property(dev, panel_info_node,
+	    "ac-bias", &panel->ac_bias);
+	    "ac-bias-intrpt", &panel->ac_bias_intrpt);
+	    "dma-burst-sz", &panel->dma_burst_sz);
+	    "bpp", &panel->bpp);
+	    "fdd", &panel->fdd);
+	    "sync-edge", &panel->sync_edge);
+	    "sync-ctrl", &panel->sync_ctrl);
+	return (0);
+static void
+am335x_lcd_intr(void *arg)
+	struct am335x_lcd_softc *sc = arg;
+	uint32_t reg;
+	reg = LCD_READ4(sc, LCD_IRQSTATUS);
+	LCD_WRITE4(sc, LCD_IRQSTATUS, reg);
+	/* Read value back to make sure it reached the hardware */
+	if (reg & IRQ_SYNC_LOST) {
+		reg = LCD_READ4(sc, LCD_RASTER_CTRL);
+		reg &= ~RASTER_CTRL_LCDEN;
+		LCD_WRITE4(sc, LCD_RASTER_CTRL, reg);
+		reg |= RASTER_CTRL_LCDEN;
+		goto done;
+	if (reg & IRQ_PL) {
+		goto done;
+	if (reg & IRQ_EOF0) {
+		LCD_WRITE4(sc, LCD_LCDDMA_FB0_BASE, sc->sc_fb_phys);
+		LCD_WRITE4(sc, LCD_LCDDMA_FB0_CEILING, sc->sc_fb_phys + sc->sc_fb_size - 1);
+		reg &= ~IRQ_EOF0;
+	if (reg & IRQ_EOF1) {
+		LCD_WRITE4(sc, LCD_LCDDMA_FB1_BASE, sc->sc_fb_phys);
+		LCD_WRITE4(sc, LCD_LCDDMA_FB1_CEILING, sc->sc_fb_phys + sc->sc_fb_size - 1);
+		reg &= ~IRQ_EOF1;
+	if (reg & IRQ_FUF) {
+		/* TODO: Handle FUF */
+	if (reg & IRQ_ACB) {
+		/* TODO: Handle ACB */
+done:
+	LCD_WRITE4(sc, LCD_END_OF_INT_IND, 0);
+	reg = LCD_READ4(sc, LCD_END_OF_INT_IND);
+static const struct videomode *
+am335x_lcd_pick_mode(struct edid_info *ei)
+	const struct videomode *videomode;
+	const struct videomode *m;
+	int n;
+	/* Get standard VGA as default */
+	videomode = NULL;
+	 * Pick a mode.
+	if (ei->edid_preferred_mode != NULL) {
+		if (am335x_mode_is_valid(ei->edid_preferred_mode))
+			videomode = ei->edid_preferred_mode;
+	if (videomode == NULL) {
+		m = ei->edid_modes;
+		sort_modes(ei->edid_modes,
+		    &ei->edid_preferred_mode,
+		    ei->edid_nmodes);
+		for (n = 0; n < ei->edid_nmodes; n++)
+			if (am335x_mode_is_valid(&m[n])) {
+				videomode = &m[n];
+				break;
+	return videomode;
+static int
+am335x_lcd_configure(struct am335x_lcd_softc *sc)
+	int div;
+	uint32_t reg, timing0, timing1, timing2;
+	uint32_t burst_log;
+	size_t dma_size;
+	uint32_t width, height;
+	unsigned int ref_freq;
+	int err;
+	 * try to adjust clock to get double of requested frequency
+	 * HDMI/DVI displays are very sensitive to error in frequncy value
+	if (ti_prcm_clk_set_source_freq(LCDC_CLK, sc->sc_panel.panel_pxl_clk*2)) {
+		device_printf(sc->sc_dev, "can't set source frequency\n");
+		return (ENXIO);
+	if (ti_prcm_clk_get_source_freq(LCDC_CLK, &ref_freq)) {
+		device_printf(sc->sc_dev, "can't get reference frequency\n");
+		return (ENXIO);
+	/* Panle initialization */
+	dma_size = round_page(sc->sc_panel.panel_width*sc->sc_panel.panel_height*sc->sc_panel.bpp/8);
+	 * Now allocate framebuffer memory
+	err = bus_dma_tag_create(
+	    bus_get_dma_tag(sc->sc_dev),
+	    4, 0,		/* alignment, boundary */
+	    BUS_SPACE_MAXADDR_32BIT,	/* lowaddr */
+	    BUS_SPACE_MAXADDR,		/* highaddr */
+	    NULL, NULL,			/* filter, filterarg */
+	    dma_size, 1,			/* maxsize, nsegments */
+	    dma_size, 0,			/* maxsegsize, flags */
+	    NULL, NULL,			/* lockfunc, lockarg */
+	    &sc->sc_dma_tag);
+	if (err)
+		goto done;
+	err = bus_dmamem_alloc(sc->sc_dma_tag, (void **)&sc->sc_fb_base,
+	    BUS_DMA_COHERENT, &sc->sc_dma_map);
+	if (err) {
+		device_printf(sc->sc_dev, "cannot allocate framebuffer\n");
+		goto done;
+	err = bus_dmamap_load(sc->sc_dma_tag, sc->sc_dma_map, sc->sc_fb_base,
+	    dma_size, am335x_fb_dmamap_cb, &sc->sc_fb_phys, BUS_DMA_NOWAIT);
+	if (err) {
+		device_printf(sc->sc_dev, "cannot load DMA map\n");
+		goto done;
+	/* Make sure it's blank */
+	memset(sc->sc_fb_base, 0x0, dma_size);
+	/* Calculate actual FB Size */
+	sc->sc_fb_size = sc->sc_panel.panel_width*sc->sc_panel.panel_height*sc->sc_panel.bpp/8;
+	/* Only raster mode is supported */
+	reg = CTRL_RASTER_MODE;
+	div = am335x_lcd_calc_divisor(ref_freq, sc->sc_panel.panel_pxl_clk);
+	reg |= (div << CTRL_DIV_SHIFT);
+	LCD_WRITE4(sc, LCD_CTRL, reg);
+	/* Set timing */
+	timing0 = timing1 = timing2 = 0;
+	hbp = sc->sc_panel.panel_hbp - 1;
+	hfp = sc->sc_panel.panel_hfp - 1;
+	hsw = sc->sc_panel.panel_hsw - 1;
+	vbp = sc->sc_panel.panel_vbp;
+	vfp = sc->sc_panel.panel_vfp;
+	vsw = sc->sc_panel.panel_vsw - 1;
+	height = sc->sc_panel.panel_height - 1;
+	width = sc->sc_panel.panel_width - 1;
+	/* Horizontal back porch */
+	timing0 |= (hbp & 0xff) << RASTER_TIMING_0_HBP_SHIFT;
+	timing2 |= ((hbp >> 8) & 3) << RASTER_TIMING_2_HBPHI_SHIFT;
+	/* Horizontal front porch */
+	timing0 |= (hfp & 0xff) << RASTER_TIMING_0_HFP_SHIFT;
+	timing2 |= ((hfp >> 8) & 3) << RASTER_TIMING_2_HFPHI_SHIFT;
+	/* Horizontal sync width */
+	timing0 |= (hsw & 0x3f) << RASTER_TIMING_0_HSW_SHIFT;
+	timing2 |= ((hsw >> 6) & 0xf) << RASTER_TIMING_2_HSWHI_SHIFT;
+	/* Vertical back porch, front porch, sync width */
+	timing1 |= (vbp & 0xff) << RASTER_TIMING_1_VBP_SHIFT;
+	timing1 |= (vfp & 0xff) << RASTER_TIMING_1_VFP_SHIFT;
+	timing1 |= (vsw & 0x3f) << RASTER_TIMING_1_VSW_SHIFT;
+	/* Pixels per line */
+	timing0 |= ((width >> 10) & 1)
+	    << RASTER_TIMING_0_PPLMSB_SHIFT;
+	timing0 |= ((width >> 4) & 0x3f)
+	    << RASTER_TIMING_0_PPLLSB_SHIFT;
+	/* Lines per panel */
+	timing1 |= (height & 0x3ff)
+	    << RASTER_TIMING_1_LPP_SHIFT;
+	timing2 |= ((height >> 10 ) & 1)
+	    << RASTER_TIMING_2_LPP_B10_SHIFT;
+	/* clock signal settings */
+	if (sc->sc_panel.sync_ctrl)
+		timing2 |= RASTER_TIMING_2_PHSVS;
+	if (sc->sc_panel.sync_edge)
+		timing2 |= RASTER_TIMING_2_PHSVS_RISE;
+	else
+		timing2 |= RASTER_TIMING_2_PHSVS_FALL;
+	if (sc->sc_panel.hsync_active == 0)
+		timing2 |= RASTER_TIMING_2_IHS;
+	if (sc->sc_panel.vsync_active == 0)
+		timing2 |= RASTER_TIMING_2_IVS;
+	if (sc->sc_panel.pixelclk_active == 0)
+		timing2 |= RASTER_TIMING_2_IPC;
+	/* AC bias */
+	timing2 |= (sc->sc_panel.ac_bias << RASTER_TIMING_2_ACB_SHIFT);
+	timing2 |= (sc->sc_panel.ac_bias_intrpt << RASTER_TIMING_2_ACBI_SHIFT);
+	LCD_WRITE4(sc, LCD_RASTER_TIMING_0, timing0);
+	LCD_WRITE4(sc, LCD_RASTER_TIMING_1, timing1);
+	LCD_WRITE4(sc, LCD_RASTER_TIMING_2, timing2);
+	/* DMA settings */
+	reg = LCDDMA_CTRL_FB0_FB1;
+	/* Find power of 2 for current burst size */
+	switch (sc->sc_panel.dma_burst_sz) {
+	case 1:
+		burst_log = 0;
+		break;
+	case 2:
+		burst_log = 1;
+		break;
+	case 4:
+		burst_log = 2;
+		break;
+	case 8:
+		burst_log = 3;
+		break;
+	case 16:
+	default:
+		burst_log = 4;
+		break;
+	reg |= (burst_log << LCDDMA_CTRL_BURST_SIZE_SHIFT);
+	/* XXX: FIFO TH */
+	reg |= (0 << LCDDMA_CTRL_TH_FIFO_RDY_SHIFT);
+	LCD_WRITE4(sc, LCD_LCDDMA_CTRL, reg);
+	/* Enable LCD */
+	reg = RASTER_CTRL_LCDTFT;
+	reg |= (sc->sc_panel.fdd << RASTER_CTRL_REQDLY_SHIFT);
+	reg |= (PALETTE_DATA_ONLY << RASTER_CTRL_PALMODE_SHIFT);
+	if (sc->sc_panel.bpp >= 24)
+		reg |= RASTER_CTRL_TFT24;
+	if (sc->sc_panel.bpp == 32)
+		reg |= RASTER_CTRL_TFT24_UNPACKED;
+	LCD_WRITE4(sc, LCD_CLKC_ENABLE,
+	    CLKC_ENABLE_DMA | CLKC_ENABLE_LDID | CLKC_ENABLE_CORE);
+	LCD_WRITE4(sc, LCD_CLKC_RESET, CLKC_RESET_MAIN);
+	DELAY(100);
+	LCD_WRITE4(sc, LCD_CLKC_RESET, 0);
+	reg = IRQ_EOF1 | IRQ_EOF0 | IRQ_FUF | IRQ_PL |
+	    IRQ_ACB | IRQ_SYNC_LOST |  IRQ_RASTER_DONE |
+	    IRQ_FRAME_DONE;
+	LCD_WRITE4(sc, LCD_IRQENABLE_SET, reg);
+	LCD_WRITE4(sc, LCD_SYSCONFIG,
+	    SYSCONFIG_STANDBY_SMART | SYSCONFIG_IDLE_SMART);
+	sc->sc_fb_info.fb_name = device_get_nameunit(sc->sc_dev);
+	sc->sc_fb_info.fb_vbase = (intptr_t)sc->sc_fb_base;
+	sc->sc_fb_info.fb_pbase = sc->sc_fb_phys;
+	sc->sc_fb_info.fb_size = sc->sc_fb_size;
+	sc->sc_fb_info.fb_bpp = sc->sc_fb_info.fb_depth = sc->sc_panel.bpp;
+	sc->sc_fb_info.fb_stride = sc->sc_panel.panel_width*sc->sc_panel.bpp / 8;
+	sc->sc_fb_info.fb_width = sc->sc_panel.panel_width;
+	sc->sc_fb_info.fb_height = sc->sc_panel.panel_height;
+#ifdef	DEV_SC
+	err = (sc_attach_unit(device_get_unit(sc->sc_dev),
+	    device_get_flags(sc->sc_dev) | SC_AUTODETECT_KBD));
+	if (err) {
+		device_printf(sc->sc_dev, "failed to attach syscons\n");
+		goto fail;
+	am335x_lcd_syscons_setup((vm_offset_t)sc->sc_fb_base, sc->sc_fb_phys, &panel);
+#else /* VT */
+	device_t fbd = device_add_child(sc->sc_dev, "fbd",
+	device_get_unit(sc->sc_dev));
+	if (fbd != NULL) {
+		if (device_probe_and_attach(fbd) != 0)
+			device_printf(sc->sc_dev, "failed to attach fbd device\n");
+	} else
+		device_printf(sc->sc_dev, "failed to add fbd child\n");
+#endif
+done:
+	return (err);
+static void
+am335x_lcd_hdmi_event(void *arg, device_t hdmi, int event)
+	struct videomode hdmi_mode;
+	device_t hdmi_dev;
+	uint8_t *edid;
+	uint32_t edid_len;
+	struct edid_info ei;
+	sc = arg;
+	/* Nothing to work with */
+	if (!sc->sc_hdmi_framer) {
+		device_printf(sc->sc_dev, "HDMI event without HDMI framer set\n");
+		return;
+	hdmi_dev = OF_device_from_xref(sc->sc_hdmi_framer);
+	if (!hdmi_dev) {
+		device_printf(sc->sc_dev, "no actual device for \"hdmi\" property\n");
+		return;
+	edid = NULL;
+	edid_len = 0;
+	if (HDMI_GET_EDID(hdmi_dev, &edid, &edid_len) != 0) {
+		device_printf(sc->sc_dev, "failed to get EDID info from HDMI framer\n");
+		return;
+	videomode = NULL;
+	if (edid_parse(edid, &ei) == 0) {
+		edid_print(&ei);
+		videomode = am335x_lcd_pick_mode(&ei);
+	} else
+		device_printf(sc->sc_dev, "failed to parse EDID\n");
+	/* Use standard VGA as fallback */
+		videomode = pick_mode_by_ref(640, 480, 60);
+		device_printf(sc->sc_dev, "failed to find usable videomode");
+		return;
+	device_printf(sc->sc_dev, "detected videomode: %dx%d @ %dKHz\n", videomode->hdisplay,
+		videomode->vdisplay, am335x_mode_vrefresh(videomode));
+	sc->sc_panel.panel_width = videomode->hdisplay;
+	sc->sc_panel.panel_height = videomode->vdisplay;
+	sc->sc_panel.panel_hfp = videomode->hsync_start - videomode->hdisplay;
+	sc->sc_panel.panel_hbp = videomode->htotal - videomode->hsync_end;
+	sc->sc_panel.panel_hsw = videomode->hsync_end - videomode->hsync_start;
+	sc->sc_panel.panel_vfp = videomode->vsync_start - videomode->vdisplay;
+	sc->sc_panel.panel_vbp = videomode->vtotal - videomode->vsync_end;
+	sc->sc_panel.panel_vsw = videomode->vsync_end - videomode->vsync_start;
+	sc->sc_panel.pixelclk_active = 1;
+	/* logic for HSYNC should be reversed */
+	if (videomode->flags & VID_NHSYNC)
+		sc->sc_panel.hsync_active = 1;
+	else
+		sc->sc_panel.hsync_active = 0;
+	if (videomode->flags & VID_NVSYNC)
+		sc->sc_panel.vsync_active = 0;
+	else
+		sc->sc_panel.vsync_active = 1;
+	sc->sc_panel.panel_pxl_clk = videomode->dot_clock * 1000;
+	am335x_lcd_configure(sc);
+	memcpy(&hdmi_mode, videomode, sizeof(hdmi_mode));
+	hdmi_mode.hskew = videomode->hsync_end - videomode->hsync_start;
+	hdmi_mode.flags |= VID_HSKEW;
+	HDMI_SET_VIDEOMODE(hdmi_dev, &hdmi_mode);
+static int
+am335x_lcd_probe(device_t dev)
+#ifdef DEV_SC
+	int err;
+#endif
+		return (ENXIO);
+	if (!ofw_bus_is_compatible(dev, "ti,am33xx-tilcdc"))
+		return (ENXIO);
+	device_set_desc(dev, "AM335x LCD controller");
+#ifdef DEV_SC
+	err = sc_probe_unit(device_get_unit(dev),
+	    device_get_flags(dev) | SC_AUTODETECT_KBD);
+	if (err != 0)
+		return (err);
+#endif
+static int
+am335x_lcd_attach(device_t dev)
+	int err;
+	int rid;
+	struct sysctl_ctx_list *ctx;
+	struct sysctl_oid *tree;
+	phandle_t root, panel_node;
+	err = 0;
+	sc->sc_dev = dev;
+	am335x_read_hdmi_property(dev);
+	root = OF_finddevice("/");
+	if (root == -1) {
+		device_printf(dev, "failed to get FDT root node\n");
+		return (ENXIO);
+	sc->sc_panel.ac_bias = 255;
+	sc->sc_panel.ac_bias_intrpt = 0;
+	sc->sc_panel.dma_burst_sz = 16;
+	sc->sc_panel.bpp = 16;
+	sc->sc_panel.fdd = 128;
+	sc->sc_panel.sync_edge = 0;
+	sc->sc_panel.sync_ctrl = 1;
+	panel_node = fdt_find_compatible(root, "ti,tilcdc,panel", 1);
+	if (panel_node != 0) {
+		device_printf(dev, "using static panel info\n");
+		if (am335x_read_panel_info(dev, panel_node, &sc->sc_panel)) {
+			device_printf(dev, "failed to read panel info\n");
+			return (ENXIO);
+		if (am335x_read_timing(dev, panel_node, &sc->sc_panel)) {
+			device_printf(dev, "failed to read timings\n");
+			return (ENXIO);
+	ti_prcm_clk_enable(LCDC_CLK);
+	rid = 0;
+	sc->sc_mem_res = bus_alloc_resource_any(dev, SYS_RES_MEMORY, &rid,
+	    RF_ACTIVE);
+	if (!sc->sc_mem_res) {
+		device_printf(dev, "cannot allocate memory window\n");
+		return (ENXIO);
+	rid = 0;
+	sc->sc_irq_res = bus_alloc_resource_any(dev, SYS_RES_IRQ, &rid,
+	    RF_ACTIVE);
+	if (!sc->sc_irq_res) {
+		bus_release_resource(dev, SYS_RES_MEMORY, 0, sc->sc_mem_res);
+		device_printf(dev, "cannot allocate interrupt\n");
+		return (ENXIO);
+	if (bus_setup_intr(dev, sc->sc_irq_res, INTR_TYPE_MISC | INTR_MPSAFE,
+			NULL, am335x_lcd_intr, sc,
+			&sc->sc_intr_hl) != 0) {
+		bus_release_resource(dev, SYS_RES_IRQ, rid,
+		    sc->sc_irq_res);
+		bus_release_resource(dev, SYS_RES_MEMORY, rid,
+		    sc->sc_mem_res);
+		device_printf(dev, "Unable to setup the irq handler.\n");
+		return (ENXIO);
+	LCD_LOCK_INIT(sc);
+	/* Init backlight interface */
+	ctx = device_get_sysctl_ctx(sc->sc_dev);
+	tree = device_get_sysctl_tree(sc->sc_dev);
+	sc->sc_oid = SYSCTL_ADD_PROC(ctx, SYSCTL_CHILDREN(tree), OID_AUTO,
+	    "backlight", CTLTYPE_INT | CTLFLAG_RW, sc, 0,
+	    am335x_lcd_sysctl_backlight, "I", "LCD backlight");
+	sc->sc_backlight = 0;
+	/* Check if eCAS interface is available at this point */
+	if (am335x_pwm_config_ecap(PWM_UNIT,
+	    PWM_PERIOD, PWM_PERIOD) == 0)
+		sc->sc_backlight = 100;
+	else
+		sc->sc_hdmi_evh = EVENTHANDLER_REGISTER(hdmi_event,
+		    am335x_lcd_hdmi_event, sc, EVENTHANDLER_PRI_ANY);
+	return (0);
+static int
+am335x_lcd_detach(device_t dev)
+	/* Do not let unload driver */
+	return (EBUSY);
+static struct fb_info *
+am335x_lcd_fb_getinfo(device_t dev)
+	return (&sc->sc_fb_info);
+static device_method_t am335x_lcd_methods[] = {
+	DEVMETHOD(device_probe,		am335x_lcd_probe),
+	DEVMETHOD(device_attach,	am335x_lcd_attach),
+	DEVMETHOD(device_detach,	am335x_lcd_detach),
+	/* Framebuffer service methods */
+	DEVMETHOD(fb_getinfo,		am335x_lcd_fb_getinfo),
+	DEVMETHOD_END
+static driver_t am335x_lcd_driver = {
+	"fb",
+	am335x_lcd_methods,
+	sizeof(struct am335x_lcd_softc),
+static devclass_t am335x_lcd_devclass;
+DRIVER_MODULE(am335x_lcd, simplebus, am335x_lcd_driver, am335x_lcd_devclass, 0, 0);
+MODULE_VERSION(am335x_lcd, 1);
+MODULE_DEPEND(am335x_lcd, simplebus, 1, 1, 1);
diff --git a/freebsd/sys/arm/ti/am335x/am335x_lcd.h b/freebsd/sys/arm/ti/am335x/am335x_lcd.h
index 00000000..f230a930
--- /dev/null
+++ b/freebsd/sys/arm/ti/am335x/am335x_lcd.h
@@ -0,0 +1,60 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef __AM335X_LCD_H__
+#define __AM335X_LCD_H__
+struct panel_info {
+	/* Timing part */
+	uint32_t panel_width;
+	uint32_t panel_height;
+	uint32_t panel_hfp;
+	uint32_t panel_hbp;
+	uint32_t panel_hsw;
+	uint32_t panel_vfp;
+	uint32_t panel_vbp;
+	uint32_t panel_vsw;
+	uint32_t hsync_active;
+	uint32_t vsync_active;
+	uint32_t panel_pxl_clk;
+	uint32_t ac_bias;
+	uint32_t ac_bias_intrpt;
+	uint32_t dma_burst_sz;
+	uint32_t bpp;
+	uint32_t fdd;
+	uint32_t sync_edge;
+	uint32_t sync_ctrl;
+	uint32_t pixelclk_active;
+int am335x_lcd_syscons_setup(vm_offset_t vaddr, vm_paddr_t paddr,
+    struct panel_info *panel);
+#endif /* __AM335X_LCD_H__ */
diff --git a/freebsd/sys/arm/ti/am335x/am335x_pwm.h b/freebsd/sys/arm/ti/am335x/am335x_pwm.h
index 00000000..956913dc
--- /dev/null
+++ b/freebsd/sys/arm/ti/am335x/am335x_pwm.h
@@ -0,0 +1,35 @@
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef __AM335X_PWM_H__
+#define __AM335X_PWM_H__
+int am335x_pwm_config_ecap(int unit, int period, int duty);
+#endif /* __AM335X_PWM_H__ */
diff --git a/freebsd/sys/arm/ti/am335x/am335x_pwmss.c b/freebsd/sys/arm/ti/am335x/am335x_pwmss.c
index 00000000..f9249989
--- /dev/null
+++ b/freebsd/sys/arm/ti/am335x/am335x_pwmss.c
@@ -0,0 +1,165 @@
+ * are met:
+ * SUCH DAMAGE.
+#include <dev/fdt/simplebus.h>
+#include <arm/ti/ti_hwmods.h>
+#include "am335x_scm.h"
+#define	PWMSS_IDVER		0x00
+#define	PWMSS_SYSCONFIG		0x04
+#define	PWMSS_CLKCONFIG		0x08
+#define		CLKCONFIG_EPWMCLK_EN	(1 << 8)
+#define	PWMSS_CLKSTATUS		0x0C
+static device_probe_t am335x_pwmss_probe;
+static device_attach_t am335x_pwmss_attach;
+static device_detach_t am335x_pwmss_detach;
+struct am335x_pwmss_softc {
+	struct simplebus_softc	sc_simplebus;
+	device_t		sc_dev;
+	clk_ident_t		sc_clk;
+static device_method_t am335x_pwmss_methods[] = {
+	DEVMETHOD(device_probe,		am335x_pwmss_probe),
+	DEVMETHOD(device_attach,	am335x_pwmss_attach),
+	DEVMETHOD(device_detach,	am335x_pwmss_detach),
+	DEVMETHOD_END
+static int
+am335x_pwmss_probe(device_t dev)
+		return (ENXIO);
+	if (!ofw_bus_is_compatible(dev, "ti,am33xx-pwmss"))
+		return (ENXIO);
+	device_set_desc(dev, "AM335x PWM");
+static int
+am335x_pwmss_attach(device_t dev)
+	struct am335x_pwmss_softc *sc;
+	uint32_t reg, id;
+	phandle_t node;
+	sc->sc_dev = dev;
+	sc->sc_clk = ti_hwmods_get_clock(dev);
+	if (sc->sc_clk == INVALID_CLK_IDENT) {
+		device_printf(dev, "failed to get device id based on ti,hwmods\n");
+		return (EINVAL);
+	ti_prcm_clk_enable(sc->sc_clk);
+	ti_scm_reg_read_4(SCM_PWMSS_CTRL, &reg);
+	switch (sc->sc_clk) {
+		case PWMSS0_CLK:
+			id = 0;
+			break;
+		case PWMSS1_CLK:
+			id = 1;
+			break;
+		case PWMSS2_CLK:
+			id = 2;
+			break;
+		default:
+			device_printf(dev, "unknown pwmss clock id: %d\n", sc->sc_clk);
+			return (EINVAL);
+	reg |= (1 << id);
+	ti_scm_reg_write_4(SCM_PWMSS_CTRL, reg);
+	if (node == -1)
+		return (ENXIO);
+	simplebus_init(dev, node);
+	 * Allow devices to identify.
+	bus_generic_probe(dev);
+	 * Now walk the OFW tree and attach top-level devices.
+	for (node = OF_child(node); node > 0; node = OF_peer(node))
+		simplebus_add_device(dev, node, 0, NULL, -1, NULL);
+	return (bus_generic_attach(dev));
+static int
+am335x_pwmss_detach(device_t dev)
+	return (0);
+DEFINE_CLASS_1(am335x_pwmss, am335x_pwmss_driver, am335x_pwmss_methods,
+    sizeof(struct am335x_pwmss_softc), simplebus_driver);
+static devclass_t am335x_pwmss_devclass;
+DRIVER_MODULE(am335x_pwmss, simplebus, am335x_pwmss_driver, am335x_pwmss_devclass, 0, 0);
+MODULE_VERSION(am335x_pwmss, 1);
diff --git a/freebsd/sys/dev/fb/fbreg.h b/freebsd/sys/dev/fb/fbreg.h
index 00000000..d5bfd0da
--- /dev/null
+++ b/freebsd/sys/dev/fb/fbreg.h
@@ -0,0 +1,345 @@
+ * Copyright (c) 1999 Kazutaka YOKOTA <yokota at zodiac.mech.utsunomiya-u.ac.jp>
+ * are met:
+ *    notice, this list of conditions and the following disclaimer as
+ *    the first lines of this file unmodified.
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
+ * IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
+ * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
+ * IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
+ * DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
+ * THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _DEV_FB_FBREG_H_
+#define _DEV_FB_FBREG_H_
+#ifdef _KERNEL
+#define V_MAX_ADAPTERS		8		/* XXX */
+/* some macros */
+#if defined(__amd64__) || defined(__i386__)
+static __inline void
+copyw(uint16_t *src, uint16_t *dst, size_t size)
+	size >>= 1;
+	while (size--)
+		*dst++ = *src++;
+#define bcopy_io(s, d, c)	copyw((void*)(s), (void*)(d), (c))
+#define bcopy_toio(s, d, c)	copyw((void*)(s), (void*)(d), (c))
+#define bcopy_fromio(s, d, c)	copyw((void*)(s), (void*)(d), (c))
+#define bzero_io(d, c)		bzero((void *)(d), (c))
+#define fill_io(p, d, c)	fill((p), (void *)(d), (c))
+#define fillw_io(p, d, c)	fillw((p), (void *)(d), (c))
+#elif defined(__sparc64__)
+fillw(int val, uint16_t *buf, size_t size)
+	while (size--)
+		*buf++ = val;
+#elif defined(__powerpc__)
+#define bcopy_io(s, d, c)	ofwfb_bcopy((void *)(s), (void *)(d), (c))
+#define bcopy_toio(s, d, c)	ofwfb_bcopy((void *)(s), (void *)(d), (c))
+#define bcopy_fromio(s, d, c)	ofwfb_bcopy((void *)(s), (void *)(d), (c))
+#define bzero_io(d, c)		ofwfb_bzero((void *)(d), (c))
+#define fillw(p, d, c)		ofwfb_fillw((p), (void *)(d), (c))
+#define fillw_io(p, d, c)	ofwfb_fillw((p), (void *)(d), (c))
+#define	readw(a)		ofwfb_readw((u_int16_t *)(a))
+#define	writew(a, v)		ofwfb_writew((u_int16_t *)(a), (v))
+void ofwfb_bcopy(const void *s, void *d, size_t c);
+void ofwfb_bzero(void *d, size_t c);
+void ofwfb_fillw(int pat, void *base, size_t cnt);
+u_int16_t ofwfb_readw(u_int16_t *addr);
+void ofwfb_writew(u_int16_t *addr, u_int16_t val);
+#elif defined(__mips__) || defined(__arm__)
+ * Use amd64/i386-like settings under the assumption that MIPS-based display
+ * drivers will have to add a level of indirection between a syscons-managed
+ * frame buffer and the actual video hardware.  We are forced to do this
+ * because syscons doesn't carry around required busspace handles and tags to
+ * use here.  This is only really a problem for true VGA devices hooked up to
+ * MIPS, as others will be performing a translation anyway.
+#define bcopy_io(s, d, c)	memcpy((void *)(d), (void *)(s), (c))
+#define bcopy_toio(s, d, c)	memcpy((void *)(d), (void *)(s), (c))
+#define bcopy_fromio(s, d, c)	memcpy((void *)(d), (void *)(s), (c))
+#define bzero_io(d, c)		memset((void *)(d), 0, (c))
+#define fill_io(p, d, c)	memset((void *)(d), (p), (c))
+	while (size--)
+		*buf++ = val;
+#if defined(__arm__)
+#define	readw(a)		(*(uint16_t*)(a))
+#define	writew(a, v)		(*(uint16_t*)(a) = (v))
+#endif
+#else /* !__i386__ && !__amd64__ && !__sparc64__ && !__powerpc__ */
+#define bcopy_io(s, d, c)	memcpy_io((d), (s), (c))
+#define bcopy_toio(s, d, c)	memcpy_toio((d), (void *)(s), (c))
+#define bcopy_fromio(s, d, c)	memcpy_fromio((void *)(d), (s), (c))
+#define bzero_io(d, c)		memset_io((d), 0, (c))
+#define fill_io(p, d, c)	memset_io((d), (p), (c))
+#define fillw(p, d, c)		memsetw((d), (p), (c))
+#define fillw_io(p, d, c)	memsetw_io((d), (p), (c))
+#endif /* !__i386__ */
+/* video function table */
+typedef int vi_probe_t(int unit, video_adapter_t **adpp, void *arg, int flags);
+typedef int vi_init_t(int unit, video_adapter_t *adp, int flags);
+typedef int vi_get_info_t(video_adapter_t *adp, int mode, video_info_t *info);
+typedef int vi_query_mode_t(video_adapter_t *adp, video_info_t *info);
+typedef int vi_set_mode_t(video_adapter_t *adp, int mode);
+typedef int vi_save_font_t(video_adapter_t *adp, int page, int size, int width,
+			   u_char *data, int c, int count);
+typedef int vi_load_font_t(video_adapter_t *adp, int page, int size, int width,
+typedef int vi_show_font_t(video_adapter_t *adp, int page);
+typedef int vi_save_palette_t(video_adapter_t *adp, u_char *palette);
+typedef int vi_load_palette_t(video_adapter_t *adp, u_char *palette);
+typedef int vi_set_border_t(video_adapter_t *adp, int border);
+typedef int vi_save_state_t(video_adapter_t *adp, void *p, size_t size);
+typedef int vi_load_state_t(video_adapter_t *adp, void *p);
+typedef int vi_set_win_org_t(video_adapter_t *adp, off_t offset);
+typedef int vi_read_hw_cursor_t(video_adapter_t *adp, int *col, int *row);
+typedef int vi_set_hw_cursor_t(video_adapter_t *adp, int col, int row);
+typedef int vi_set_hw_cursor_shape_t(video_adapter_t *adp, int base,
+				     int height, int celsize, int blink);
+typedef int vi_blank_display_t(video_adapter_t *adp, int mode);
+/* defined in sys/fbio.h
+#define V_DISPLAY_ON		0
+#define V_DISPLAY_BLANK		1
+#define V_DISPLAY_STAND_BY	2
+#define V_DISPLAY_SUSPEND	3
+typedef int vi_mmap_t(video_adapter_t *adp, vm_ooffset_t offset,
+		      vm_paddr_t *paddr, int prot, vm_memattr_t *memattr);
+typedef int vi_ioctl_t(video_adapter_t *adp, u_long cmd, caddr_t data);
+typedef int vi_clear_t(video_adapter_t *adp);
+typedef int vi_fill_rect_t(video_adapter_t *adp, int val, int x, int y,
+			   int cx, int cy);
+typedef int vi_bitblt_t(video_adapter_t *adp, ...);
+typedef int vi_diag_t(video_adapter_t *adp, int level);
+typedef int vi_save_cursor_palette_t(video_adapter_t *adp, u_char *palette);
+typedef int vi_load_cursor_palette_t(video_adapter_t *adp, u_char *palette);
+typedef int vi_copy_t(video_adapter_t *adp, vm_offset_t src, vm_offset_t dst,
+		      int n);
+typedef int vi_putp_t(video_adapter_t *adp, vm_offset_t off, u_int32_t p,
+		       u_int32_t a, int size, int bpp, int bit_ltor,
+		       int byte_ltor);
+typedef int vi_putc_t(video_adapter_t *adp, vm_offset_t off, u_int8_t c,
+		      u_int8_t a);
+typedef int vi_puts_t(video_adapter_t *adp, vm_offset_t off, u_int16_t *s,
+		       int len);
+typedef int vi_putm_t(video_adapter_t *adp, int x, int y, u_int8_t *pixel_image,
+		      u_int32_t pixel_mask, int size, int width);
+typedef struct video_switch {
+    vi_probe_t		*probe;
+    vi_init_t		*init;
+    vi_get_info_t	*get_info;
+    vi_query_mode_t	*query_mode;
+    vi_set_mode_t	*set_mode;
+    vi_save_font_t	*save_font;
+    vi_load_font_t	*load_font;
+    vi_show_font_t	*show_font;
+    vi_save_palette_t	*save_palette;
+    vi_load_palette_t	*load_palette;
+    vi_set_border_t	*set_border;
+    vi_save_state_t	*save_state;
+    vi_load_state_t	*load_state;
+    vi_set_win_org_t	*set_win_org;
+    vi_read_hw_cursor_t	*read_hw_cursor;
+    vi_set_hw_cursor_t	*set_hw_cursor;
+    vi_set_hw_cursor_shape_t *set_hw_cursor_shape;
+    vi_blank_display_t	*blank_display;
+    vi_mmap_t		*mmap;
+    vi_ioctl_t		*ioctl;
+    vi_clear_t		*clear;
+    vi_fill_rect_t	*fill_rect;
+    vi_bitblt_t		*bitblt;
+    int			(*reserved1)(void);
+    int			(*reserved2)(void);
+    vi_diag_t		*diag;
+    vi_save_cursor_palette_t	*save_cursor_palette;
+    vi_load_cursor_palette_t	*load_cursor_palette;
+    vi_copy_t		*copy;
+    vi_putp_t		*putp;
+    vi_putc_t		*putc;
+    vi_puts_t		*puts;
+    vi_putm_t		*putm;
+} video_switch_t;
+#define vidd_probe(unit, adpp, arg, flags)				\
+	(*vidsw[(adp)->va_index]->probe)((unit), (adpp), (arg), (flags))
+#define vidd_init(unit, adp, flags)					\
+	(*vidsw[(adp)->va_index]->init)((unit), (adp), (flags))
+#define vidd_get_info(adp, mode, info)					\
+	(*vidsw[(adp)->va_index]->get_info)((adp), (mode), (info))
+#define vidd_query_mode(adp, mode)					\
+	(*vidsw[(adp)->va_index]->query_mode)((adp), (mode))
+#define vidd_set_mode(adp, mode)					\
+	(*vidsw[(adp)->va_index]->set_mode)((adp), (mode))
+#define vidd_save_font(adp, page, size, width, data, c, count)		\
+	(*vidsw[(adp)->va_index]->save_font)((adp), (page), (size),	\
+	    (width), (data), (c), (count))
+#define vidd_load_font(adp, page, size, width, data, c, count)		\
+	(*vidsw[(adp)->va_index]->load_font)((adp), (page), (size),	\
+#define vidd_show_font(adp, page)					\
+	(*vidsw[(adp)->va_index]->show_font)((adp), (page))
+#define vidd_save_palette(adp, pallete)					\
+	(*vidsw[(adp)->va_index]->save_palette)((adp), (pallete))
+#define vidd_load_palette(adp, pallete)					\
+	(*vidsw[(adp)->va_index]->load_palette)((adp), (pallete))
+#define vidd_set_border(adp, border)					\
+	(*vidsw[(adp)->va_index]->set_border)((adp), (border))
+#define vidd_save_state(adp, p, size)					\
+	(*vidsw[(adp)->va_index]->save_state)((adp), (p), (size))
+#define vidd_load_state(adp, p)						\
+	(*vidsw[(adp)->va_index]->load_state)((adp), (p))
+#define vidd_set_win_org(adp, offset)					\
+	(*vidsw[(adp)->va_index]->set_win_org)((adp), (offset))
+#define vidd_read_hw_cursor(adp, col, row)				\
+	(*vidsw[(adp)->va_index]->read_hw_cursor)((adp), (col), (row))
+#define vidd_set_hw_cursor(adp, col, row)				\
+	(*vidsw[(adp)->va_index]->set_hw_cursor)((adp), (col), (row))
+#define vidd_set_hw_cursor_shape(adp, base, height, celsize, blink)	\
+	(*vidsw[(adp)->va_index]->set_hw_cursor_shape)((adp), (base),	\
+	    (height), (celsize), (blink))
+#define vidd_blank_display(adp, mode)					\
+	(*vidsw[(adp)->va_index]->blank_display)((adp), (mode))
+#define vidd_mmap(adp, offset, paddr, prot, memattr)			\
+	(*vidsw[(adp)->va_index]->mmap)((adp), (offset), (paddr),	\
+	    (prot), (memattr))
+#define vidd_ioctl(adp, cmd, data)					\
+	(*vidsw[(adp)->va_index]->ioctl)((adp), (cmd), (data))
+#define vidd_clear(adp)							\
+	(*vidsw[(adp)->va_index]->clear)((adp))
+#define vidd_fill_rect(adp, val, x, y, cx, cy)				\
+	(*vidsw[(adp)->va_index]->fill_rect)((adp), (val), (x), (y),	\
+	    (cx), (cy))
+#define vidd_bitblt(adp, ...)						\
+	(*vidsw[(adp)->va_index]->bitblt)(adp, __VA_ARGS__)
+#define vidd_diag(adp, level)						\
+	(*vidsw[(adp)->va_index]->diag)((adp), (level))
+#define vidd_save_cursor_palette(adp, palette)				\
+	(*vidsw[(adp)->va_index]->save_cursor_palette)((adp), (palette))
+#define vidd_load_cursor_palette(adp, palette)				\
+	(*vidsw[(adp)->va_index]->load_cursor_palette)((adp), (palette))
+#define vidd_copy(adp, src, dst, n)					\
+	(*vidsw[(adp)->va_index]->copy)((adp), (src), (dst), (n))
+#define vidd_putp(adp, offset, p, a, size, bpp, bit_ltor1, byte_ltor2)	\
+	(*vidsw[(adp)->va_index]->putp)((adp), (offset), (p), (a), 	\
+	    (size), (bpp), (bit_ltor1), (bit_ltor2))
+#define vidd_putc(adp, offset, c, a)					\
+	(*vidsw[(adp)->va_index]->putc)((adp), (offset), (c), (a))
+#define vidd_puts(adp, offset, s, len)					\
+	(*vidsw[(adp)->va_index]->puts)((adp), (offset), (s), (len))
+#define vidd_putm(adp, x, y, pixel_image, pixel_mask, size, width)	\
+	(*vidsw[(adp)->va_index]->putm)((adp), (x), (y), (pixel_image),	\
+	    (pixel_mask), (size), (width))
+/* video driver */
+typedef struct video_driver {
+    char		*name;
+    video_switch_t	*vidsw;
+    int			(*configure)(int); /* backdoor for the console driver */
+} video_driver_t;
+#define VIDEO_DRIVER(name, sw, config)			\
+	static struct video_driver name##_driver = {	\
+		#name, &sw, config			\
+	DATA_SET(videodriver_set, name##_driver);
+/* global variables */
+extern struct video_switch **vidsw;
+/* functions for the video card driver */
+int		vid_register(video_adapter_t *adp);
+int		vid_unregister(video_adapter_t *adp);
+video_switch_t	*vid_get_switch(char *name);
+void		vid_init_struct(video_adapter_t *adp, char *name, int type,
+				int unit);
+/* functions for the video card client */
+int		vid_allocate(char *driver, int unit, void *id);
+int		vid_release(video_adapter_t *adp, void *id);
+int		vid_find_adapter(char *driver, int unit);
+video_adapter_t	*vid_get_adapter(int index);
+/* a backdoor for the console driver to tickle the video driver XXX */
+int		vid_configure(int flags);
+#define VIO_PROBE_ONLY	(1 << 0)	/* probe only, don't initialize */
+#ifdef FB_INSTALL_CDEV
+/* virtual frame buffer driver functions */
+int		fb_attach(int unit, video_adapter_t *adp,
+			  struct cdevsw *cdevsw);
+int		fb_detach(int unit, video_adapter_t *adp,
+/* generic frame buffer cdev driver functions */
+typedef struct genfb_softc {
+	int		gfb_flags;	/* flag/status bits */
+#define FB_OPEN		(1 << 0)
+} genfb_softc_t;
+int		genfbopen(genfb_softc_t *sc, video_adapter_t *adp,
+			  int flag, int mode, struct thread *td);
+int		genfbclose(genfb_softc_t *sc, video_adapter_t *adp,
+int		genfbread(genfb_softc_t *sc, video_adapter_t *adp,
+			  struct uio *uio, int flag);
+int		genfbwrite(genfb_softc_t *sc, video_adapter_t *adp,
+int		genfbioctl(genfb_softc_t *sc, video_adapter_t *adp,
+			   u_long cmd, caddr_t arg, int flag, struct thread *td);
+int		genfbmmap(genfb_softc_t *sc, video_adapter_t *adp,
+			  vm_ooffset_t offset, vm_paddr_t *paddr,
+			  int prot, vm_memattr_t *memattr);
+#endif /* FB_INSTALL_CDEV */
+/* generic low-level driver functions */
+void		fb_dump_adp_info(char *driver, video_adapter_t *adp, int level);
+void		fb_dump_mode_info(char *driver, video_adapter_t *adp,
+				  video_info_t *info, int level);
+int		fb_type(int adp_type);
+int		fb_commonioctl(video_adapter_t *adp, u_long cmd, caddr_t arg);
+#endif /* _KERNEL */
+#endif /* !_DEV_FB_FBREG_H_ */
diff --git a/freebsd/sys/dev/syscons/syscons.h b/freebsd/sys/dev/syscons/syscons.h
index 00000000..defdf0f2
--- /dev/null
+++ b/freebsd/sys/dev/syscons/syscons.h
@@ -0,0 +1,693 @@
+ * SPDX-License-Identifier: BSD-3-Clause
+ * Copyright (c) 1995-1998 Søren Schmidt
+ * This code is derived from software contributed to The DragonFly Project
+ * by Sascha Wildner <saw at online.de>
+ * are met:
+ *    notice, this list of conditions and the following disclaimer,
+ *    without modification, immediately at the beginning of the file.
+ * 3. The name of the author may not be used to endorse or promote products
+ *    derived from this software without specific prior written permission.
+ * $FreeBSD$
+#ifndef _DEV_SYSCONS_SYSCONS_H_
+#define	_DEV_SYSCONS_SYSCONS_H_
+#include <sys/kdb.h>		/* XXX */
+#include <sys/_lock.h>
+#include <sys/_mutex.h>
+/* default values for configuration options */
+#ifndef MAXCONS
+#define MAXCONS		16
+#endif
+#ifdef SC_NO_SYSMOUSE
+#undef SC_NO_CUTPASTE
+#define SC_NO_CUTPASTE	1
+#endif
+#ifdef SC_NO_MODE_CHANGE
+#undef SC_PIXEL_MODE
+#endif
+/* Always load font data if the pixel (raster text) mode is to be used. */
+#ifdef SC_PIXEL_MODE
+#undef SC_NO_FONT_LOADING
+#endif
+ * If font data is not available, the `arrow'-shaped mouse cursor cannot
+ * be drawn.  Use the alternative drawing method.
+#ifdef SC_NO_FONT_LOADING
+#undef SC_ALT_MOUSE_IMAGE
+#define SC_ALT_MOUSE_IMAGE 1
+#endif
+#ifndef SC_CURSOR_CHAR
+#define SC_CURSOR_CHAR	7
+#endif
+#ifndef SC_MOUSE_CHAR
+#define SC_MOUSE_CHAR	8
+#endif
+#if SC_MOUSE_CHAR <= SC_CURSOR_CHAR && SC_CURSOR_CHAR < (SC_MOUSE_CHAR + 4)
+#undef SC_CURSOR_CHAR
+#define SC_CURSOR_CHAR	(SC_MOUSE_CHAR + 4)
+#endif
+#ifndef SC_DEBUG_LEVEL
+#define SC_DEBUG_LEVEL	0
+#endif
+#define DPRINTF(l, p)	if (SC_DEBUG_LEVEL >= (l)) printf p
+#ifndef __sparc64__
+#define SC_DRIVER_NAME	"sc"
+#else
+ * Use a different driver name on sparc64 so it does not get confused
+ * with the system controller devices which are also termed 'sc' in OFW.
+#define SC_DRIVER_NAME	"syscons"
+#endif
+#define SC_VTY(dev)	(((sc_ttysoftc *)tty_softc(tp))->st_index)
+#define SC_DEV(sc, vty)	((sc)->dev[(vty) - (sc)->first_vty])
+#define SC_STAT(tp)	(*((scr_stat **)&((sc_ttysoftc *)tty_softc(tp))->st_stat))
+/* printable chars */
+#ifndef PRINTABLE
+#define PRINTABLE(ch)	((ch) > 0x1b || ((ch) > 0x0d && (ch) < 0x1b) \
+			 || (ch) < 0x07)
+#endif
+/* macros for "intelligent" screen update */
+#define mark_for_update(scp, x)	{\
+			  	    if ((x) < scp->start) scp->start = (x);\
+				    else if ((x) > scp->end) scp->end = (x);\
+#define mark_all(scp)		{\
+				    scp->start = 0;\
+				    scp->end = scp->xsize * scp->ysize - 1;\
+/* vty status flags (scp->status) */
+#define UNKNOWN_MODE	0x00010		/* unknown video mode */
+#define SWITCH_WAIT_REL	0x00080		/* waiting for vty release */
+#define SWITCH_WAIT_ACQ	0x00100		/* waiting for vty ack */
+#define BUFFER_SAVED	0x00200		/* vty buffer is saved */
+#define CURSOR_ENABLED 	0x00400		/* text cursor is enabled */
+#define MOUSE_MOVED	0x01000		/* mouse cursor has moved */
+#define MOUSE_CUTTING	0x02000		/* mouse cursor is cutting text */
+#define MOUSE_VISIBLE	0x04000		/* mouse cursor is showing */
+#define GRAPHICS_MODE	0x08000		/* vty is in a graphics mode */
+#define PIXEL_MODE	0x10000		/* vty is in a raster text mode */
+#define SAVER_RUNNING	0x20000		/* screen saver is running */
+#define VR_CURSOR_BLINK	0x40000		/* blinking text cursor */
+#define VR_CURSOR_ON	0x80000		/* text cursor is on */
+#define MOUSE_HIDDEN	0x100000	/* mouse cursor is temporarily hidden */
+/* misc defines */
+#define FALSE		0
+#define TRUE		1
+   The following #defines are hard-coded for a maximum text
+   resolution corresponding to a maximum framebuffer
+   resolution of 1920x1200 with an 8x8 font...
+#define	COL		240
+#define	ROW		150
+#define PCBURST		128
+#ifndef BELL_DURATION
+#define BELL_DURATION	((5 * hz + 99) / 100)
+#define BELL_PITCH	800
+#endif
+/* virtual terminal buffer */
+typedef struct sc_vtb {
+	int		vtb_flags;
+#define VTB_VALID	(1 << 0)
+#define VTB_ALLOCED	(1 << 1)
+	int		vtb_type;
+#define VTB_INVALID	0
+#define VTB_MEMORY	1
+#define VTB_FRAMEBUFFER	2
+#define VTB_RINGBUFFER	3
+	int		vtb_cols;
+	int		vtb_rows;
+	int		vtb_size;
+	vm_offset_t	vtb_buffer;
+	int		vtb_tail;	/* valid for VTB_RINGBUFFER only */
+} sc_vtb_t;
+/* text and some mouse cursor attributes */
+struct cursor_attr {
+	u_char		flags;
+	u_char		base;
+	u_char		height;
+	u_char		bg[3];
+	u_char		mouse_ba;
+	u_char		mouse_ia;
+/* softc */
+struct keyboard;
+struct video_adapter;
+struct scr_stat;
+struct tty;
+struct sc_cnstate {
+	u_char		kbd_locked;
+	u_char		kdb_locked;
+	u_char		mtx_locked;
+	u_char		kbd_opened;
+	u_char		scr_opened;
+typedef struct sc_softc {
+	int		unit;			/* unit # */
+	int		config;			/* configuration flags */
+#define SC_VESAMODE	(1 << 7)
+#define SC_AUTODETECT_KBD (1 << 8)
+#define SC_KERNEL_CONSOLE (1 << 9)
+	int		flags;			/* status flags */
+#define SC_VISUAL_BELL	(1 << 0)
+#define SC_QUIET_BELL	(1 << 1)
+#if 0 /* not used anymore */
+#define SC_BLINK_CURSOR	(1 << 2)
+#define SC_CHAR_CURSOR	(1 << 3)
+#endif
+#define SC_MOUSE_ENABLED (1 << 4)
+#define	SC_SCRN_IDLE	(1 << 5)
+#define	SC_SCRN_BLANKED	(1 << 6)
+#define	SC_SAVER_FAILED	(1 << 7)
+#define	SC_SCRN_VTYLOCK	(1 << 8)
+#define	SC_INIT_DONE	(1 << 16)
+#define	SC_SPLASH_SCRN	(1 << 17)
+	int		keyboard;		/* -1 if unavailable */
+	struct keyboard	*kbd;
+	int		adapter;
+	struct video_adapter *adp;
+	int		initial_mode;		/* initial video mode */
+	int		first_vty;
+	int		vtys;
+	struct tty **dev;
+	struct scr_stat	*cur_scp;
+	struct scr_stat	*new_scp;
+	struct scr_stat	*old_scp;
+	int     	delayed_next_scr;
+	char        	font_loading_in_progress;
+	char        	switch_in_progress;
+	char        	write_in_progress;
+	char        	blink_in_progress;
+	int		grab_level;
+	/* 2 is just enough for kdb to grab for stepping normal grabbing: */
+	struct sc_cnstate grab_state[2];
+	int		kbd_open_level;
+	struct mtx	video_mtx;
+	long		scrn_time_stamp;
+	struct cursor_attr dflt_curs_attr;
+	struct cursor_attr curs_attr;
+	u_char      	scr_map[256];
+	u_char      	scr_rmap[256];
+#ifdef _SC_MD_SOFTC_DECLARED_
+	sc_md_softc_t	md;			/* machine dependent vars */
+#endif
+#ifndef SC_NO_PALETTE_LOADING
+	u_char		palette[256 * 3];
+	u_char		palette2[256 * 3];
+#endif
+#endif
+#ifndef SC_NO_FONT_LOADING
+	int     	fonts_loaded;
+#define FONT_8		2
+#define FONT_14		4
+#define FONT_16		8
+#define FONT_22		8
+	u_char		*font_8;
+	u_char		*font_14;
+	u_char		*font_16;
+	u_char		*font_22;
+#endif
+	u_char		cursor_char;
+	u_char		mouse_char;
+#ifdef KDB
+	int		sc_altbrk;
+#endif
+	struct callout	ctimeout;
+	struct callout	cblink;
+} sc_softc_t;
+/* virtual screen */
+typedef struct scr_stat {
+	int		index;			/* index of this vty */
+	struct sc_softc *sc;			/* pointer to softc */
+	struct sc_rndr_sw *rndr;		/* renderer */
+	sc_vtb_t	scr;
+#endif
+	sc_vtb_t	vtb;
+	int 		xpos;			/* current X position */
+	int 		ypos;			/* current Y position */
+	int 		xsize;			/* X text size */
+	int 		ysize;			/* Y text size */
+	int 		xpixel;			/* X graphics size */
+	int 		ypixel;			/* Y graphics size */
+	int		xoff;			/* X offset in pixel mode */
+	int		yoff;			/* Y offset in pixel mode */
+	u_char		*font;			/* current font */
+	int		font_size;		/* fontsize in Y direction */
+	int		font_width;		/* fontsize in X direction */
+	int		start;			/* modified area start */
+	int		end;			/* modified area end */
+	struct sc_term_sw *tsw;
+	void		*ts;
+	int	 	status;			/* status (bitfield) */
+	int		kbd_mode;		/* keyboard I/O mode */
+	int		cursor_pos;		/* cursor buffer position */
+	int		cursor_oldpos;		/* cursor old buffer position */
+	struct cursor_attr base_curs_attr;
+	int		mouse_pos;		/* mouse buffer position */
+	int		mouse_oldpos;		/* mouse old buffer position */
+	short		mouse_xpos;		/* mouse x coordinate */
+	short		mouse_ypos;		/* mouse y coordinate */
+	short		mouse_oldxpos;		/* mouse previous x coordinate */
+	short		mouse_oldypos;		/* mouse previous y coordinate */
+	short		mouse_buttons;		/* mouse buttons */
+	int		mouse_cut_start;	/* mouse cut start pos */
+	int		mouse_cut_end;		/* mouse cut end pos */
+	int		mouse_level;		/* xterm mouse protocol */
+	struct proc 	*mouse_proc;		/* proc* of controlling proc */
+	pid_t 		mouse_pid;		/* pid of controlling proc */
+	int		mouse_signal;		/* signal # to report with */
+	const void	*mouse_data;		/* renderer (pixmap) data */
+	u_short		bell_duration;
+	u_short		bell_pitch;
+	u_char		border;			/* border color */
+	int	 	mode;			/* mode */
+	pid_t 		pid;			/* pid of controlling proc */
+	struct proc 	*proc;			/* proc* of controlling proc */
+	struct vt_mode 	smode;			/* switch mode */
+	sc_vtb_t	*history;		/* circular history buffer */
+	int		history_pos;		/* position shown on screen */
+	int		history_size;		/* size of history buffer */
+	int		splash_save_mode;	/* saved mode for splash screen */
+	int		splash_save_status;	/* saved status for splash screen */
+#ifdef _SCR_MD_STAT_DECLARED_
+	scr_md_stat_t	md;			/* machine dependent vars */
+#endif
+} scr_stat;
+/* TTY softc. */
+typedef struct sc_ttysoftc {
+	int		st_index;
+	scr_stat	*st_stat;
+} sc_ttysoftc;
+#ifndef SC_NORM_ATTR
+#define SC_NORM_ATTR		(FG_LIGHTGREY | BG_BLACK)
+#endif
+#ifndef SC_NORM_REV_ATTR
+#define SC_NORM_REV_ATTR	(FG_BLACK | BG_LIGHTGREY)
+#endif
+#ifndef SC_KERNEL_CONS_ATTR
+#define SC_KERNEL_CONS_ATTR	(FG_WHITE | BG_BLACK)
+#endif
+#ifndef SC_KERNEL_CONS_REV_ATTR
+#define SC_KERNEL_CONS_REV_ATTR	(FG_BLACK | BG_LIGHTGREY)
+#endif
+/* terminal emulator */
+#ifndef SC_DFLT_TERM
+#define SC_DFLT_TERM	"scteken"
+#endif
+typedef int	sc_term_init_t(scr_stat *scp, void **tcp, int code);
+#define SC_TE_COLD_INIT	0
+#define SC_TE_WARM_INIT	1
+typedef int	sc_term_term_t(scr_stat *scp, void **tcp);
+typedef void	sc_term_puts_t(scr_stat *scp, u_char *buf, int len);
+typedef int	sc_term_ioctl_t(scr_stat *scp, struct tty *tp, u_long cmd,
+				caddr_t data, struct thread *td);
+typedef int	sc_term_reset_t(scr_stat *scp, int code);
+#define SC_TE_HARD_RESET 0
+#define SC_TE_SOFT_RESET 1
+typedef void	sc_term_default_attr_t(scr_stat *scp, int norm, int rev);
+typedef void	sc_term_clear_t(scr_stat *scp);
+typedef void	sc_term_notify_t(scr_stat *scp, int event);
+#define SC_TE_NOTIFY_VTSWITCH_IN	0
+#define SC_TE_NOTIFY_VTSWITCH_OUT	1
+typedef int	sc_term_input_t(scr_stat *scp, int c, struct tty *tp);
+typedef const char *sc_term_fkeystr_t(scr_stat *scp, int c);
+typedef void sc_term_sync_t(scr_stat *scp);
+typedef struct sc_term_sw {
+	LIST_ENTRY(sc_term_sw)	link;
+	char 			*te_name;	/* name of the emulator */
+	char 			*te_desc;	/* description */
+	char 			*te_renderer;	/* matching renderer */
+	size_t			te_size;	/* size of internal buffer */
+	int			te_refcount;	/* reference counter */
+	sc_term_init_t		*te_init;
+	sc_term_term_t		*te_term;
+	sc_term_puts_t		*te_puts;
+	sc_term_ioctl_t		*te_ioctl;
+	sc_term_reset_t		*te_reset;
+	sc_term_default_attr_t	*te_default_attr;
+	sc_term_clear_t		*te_clear;
+	sc_term_notify_t	*te_notify;
+	sc_term_input_t		*te_input;
+	sc_term_fkeystr_t	*te_fkeystr;
+	sc_term_sync_t		*te_sync;
+} sc_term_sw_t;
+#define SCTERM_MODULE(name, sw)					\
+	DATA_SET(scterm_set, sw);				\
+	static int						\
+	scterm_##name##_event(module_t mod, int type, void *data) \
+		switch (type) {					\
+		case MOD_LOAD:					\
+			return sc_term_add(&sw);		\
+		case MOD_UNLOAD:				\
+			if (sw.te_refcount > 0)			\
+				return EBUSY;			\
+			return sc_term_remove(&sw);		\
+		default:					\
+			return EOPNOTSUPP;			\
+			break;					\
+		return 0;					\
+	static moduledata_t scterm_##name##_mod = {		\
+		"scterm-" #name,				\
+		scterm_##name##_event,				\
+		NULL,						\
+	DECLARE_MODULE(scterm_##name, scterm_##name##_mod,	\
+		       SI_SUB_DRIVERS, SI_ORDER_MIDDLE)
+/* renderer function table */
+typedef void	vr_init_t(scr_stat *scp);
+typedef void	vr_clear_t(scr_stat *scp, int c, int attr);
+typedef void	vr_draw_border_t(scr_stat *scp, int color);
+typedef void	vr_draw_t(scr_stat *scp, int from, int count, int flip);
+typedef void	vr_set_cursor_t(scr_stat *scp, int base, int height, int blink);
+typedef void	vr_draw_cursor_t(scr_stat *scp, int at, int blink,
+				 int on, int flip);
+typedef void	vr_blink_cursor_t(scr_stat *scp, int at, int flip);
+typedef void	vr_set_mouse_t(scr_stat *scp);
+typedef void	vr_draw_mouse_t(scr_stat *scp, int x, int y, int on);
+typedef struct sc_rndr_sw {
+	vr_init_t		*init;
+	vr_clear_t		*clear;
+	vr_draw_border_t	*draw_border;
+	vr_draw_t		*draw;
+	vr_set_cursor_t		*set_cursor;
+	vr_draw_cursor_t	*draw_cursor;
+	vr_blink_cursor_t	*blink_cursor;
+	vr_set_mouse_t		*set_mouse;
+	vr_draw_mouse_t		*draw_mouse;
+} sc_rndr_sw_t;
+typedef struct sc_renderer {
+	char			*name;
+	int			mode;
+	sc_rndr_sw_t		*rndrsw;
+	LIST_ENTRY(sc_renderer)	link;
+} sc_renderer_t;
+#define RENDERER(name, mode, sw, set)				\
+	static struct sc_renderer scrndr_##name##_##mode = {	\
+		#name, mode, &sw				\
+	DATA_SET(scrndr_set, scrndr_##name##_##mode);		\
+	DATA_SET(set, scrndr_##name##_##mode)
+#define RENDERER_MODULE(name, set)				\
+	SET_DECLARE(set, sc_renderer_t);			\
+	static int						\
+	scrndr_##name##_event(module_t mod, int type, void *data) \
+		sc_renderer_t **list;				\
+		int error = 0;					\
+		switch (type) {					\
+		case MOD_LOAD:					\
+			SET_FOREACH(list, set) {		\
+				error = sc_render_add(*list);	\
+				if (error)			\
+					break;			\
+			break;					\
+				error = sc_render_remove(*list);\
+				if (error)			\
+					break;			\
+			break;					\
+		default:					\
+			break;					\
+		return error;					\
+	static moduledata_t scrndr_##name##_mod = {		\
+		"scrndr-" #name,				\
+		scrndr_##name##_event,				\
+		NULL,						\
+	DECLARE_MODULE(scrndr_##name, scrndr_##name##_mod, 	\
+typedef struct {
+	int		shift_state;
+	int		bell_pitch;
+} bios_values_t;
+/* other macros */
+#define ISTEXTSC(scp)	(!((scp)->status 				\
+			  & (UNKNOWN_MODE | GRAPHICS_MODE | PIXEL_MODE)))
+#define ISGRAPHSC(scp)	(((scp)->status 				\
+			  & (UNKNOWN_MODE | GRAPHICS_MODE)))
+#define ISPIXELSC(scp)	(((scp)->status 				\
+			  & (UNKNOWN_MODE | GRAPHICS_MODE | PIXEL_MODE))\
+			  == PIXEL_MODE)
+#define ISUNKNOWNSC(scp) ((scp)->status & UNKNOWN_MODE)
+#define ISMOUSEAVAIL(af) ((af) & V_ADP_FONT)
+#define ISFONTAVAIL(af)	((af) & V_ADP_FONT)
+#define ISPALAVAIL(af)	((af) & V_ADP_PALETTE)
+#define ISSIGVALID(sig)	((sig) > 0 && (sig) < NSIG)
+#define SC_VIDEO_LOCKINIT(sc)						\
+		mtx_init(&(sc)->video_mtx, "syscons video lock", NULL,	\
+		    MTX_SPIN | MTX_RECURSE);
+#define SC_VIDEO_LOCK(sc)						\
+		do {							\
+			if (!kdb_active)				\
+				mtx_lock_spin(&(sc)->video_mtx);	\
+		} while(0)
+#define SC_VIDEO_UNLOCK(sc)						\
+		do {							\
+				mtx_unlock_spin(&(sc)->video_mtx);	\
+		} while(0)
+/* syscons.c */
+extern int 	(*sc_user_ioctl)(struct tty *tp, u_long cmd, caddr_t data,
+				 struct thread *td);
+int		sc_probe_unit(int unit, int flags);
+int		sc_attach_unit(int unit, int flags);
+int		set_mode(scr_stat *scp);
+void		sc_set_border(scr_stat *scp, int color);
+void		sc_load_font(scr_stat *scp, int page, int size, int width,
+			     u_char *font, int base, int count);
+void		sc_save_font(scr_stat *scp, int page, int size, int width,
+void		sc_show_font(scr_stat *scp, int page);
+void		sc_touch_scrn_saver(void);
+void		sc_draw_cursor_image(scr_stat *scp);
+void		sc_remove_cursor_image(scr_stat *scp);
+void		sc_set_cursor_image(scr_stat *scp);
+void		sc_change_cursor_shape(scr_stat *scp, int flags,
+				       int base, int height);
+int		sc_clean_up(scr_stat *scp);
+int		sc_switch_scr(sc_softc_t *sc, u_int next_scr);
+void		sc_alloc_scr_buffer(scr_stat *scp, int wait, int discard);
+int		sc_init_emulator(scr_stat *scp, char *name);
+void		sc_paste(scr_stat *scp, const u_char *p, int count);
+void		sc_respond(scr_stat *scp, const u_char *p,
+			   int count, int wakeup);
+void		sc_bell(scr_stat *scp, int pitch, int duration);
+/* schistory.c */
+#ifndef SC_NO_HISTORY
+int		sc_alloc_history_buffer(scr_stat *scp, int lines,
+					int prev_ysize, int wait);
+void		sc_free_history_buffer(scr_stat *scp, int prev_ysize);
+void		sc_hist_save(scr_stat *scp);
+#define		sc_hist_save_one_line(scp, from)	\
+		sc_vtb_append(&(scp)->vtb, (from), (scp)->history, (scp)->xsize)
+int		sc_hist_restore(scr_stat *scp);
+void		sc_hist_home(scr_stat *scp);
+void		sc_hist_end(scr_stat *scp);
+int		sc_hist_up_line(scr_stat *scp);
+int		sc_hist_down_line(scr_stat *scp);
+int		sc_hist_ioctl(struct tty *tp, u_long cmd, caddr_t data,
+#endif /* SC_NO_HISTORY */
+/* scmouse.c */
+#ifndef SC_NO_CUTPASTE
+void		sc_alloc_cut_buffer(scr_stat *scp, int wait);
+void		sc_draw_mouse_image(scr_stat *scp);
+void		sc_remove_mouse_image(scr_stat *scp);
+int		sc_inside_cutmark(scr_stat *scp, int pos);
+void		sc_remove_cutmarking(scr_stat *scp);
+void		sc_remove_all_cutmarkings(sc_softc_t *scp);
+void		sc_remove_all_mouse(sc_softc_t *scp);
+void		sc_mouse_paste(scr_stat *scp);
+#else
+#define		sc_draw_mouse_image(scp)
+#define		sc_remove_mouse_image(scp)
+#define		sc_inside_cutmark(scp, pos)	FALSE
+#define		sc_remove_cutmarking(scp)
+#define		sc_remove_all_cutmarkings(scp)
+#define		sc_remove_all_mouse(scp)
+#define		sc_mouse_paste(scp)
+#endif /* SC_NO_CUTPASTE */
+#ifndef SC_NO_SYSMOUSE
+void		sc_mouse_move(scr_stat *scp, int x, int y);
+int		sc_mouse_ioctl(struct tty *tp, u_long cmd, caddr_t data,
+#endif /* SC_NO_SYSMOUSE */
+/* scvidctl.c */
+int		sc_set_text_mode(scr_stat *scp, struct tty *tp, int mode,
+				 int xsize, int ysize, int fontsize,
+				 int font_width);
+int		sc_set_graphics_mode(scr_stat *scp, struct tty *tp, int mode);
+int		sc_set_pixel_mode(scr_stat *scp, struct tty *tp, int xsize,
+				  int ysize, int fontsize, int font_width);
+int		sc_support_pixel_mode(void *arg);
+int		sc_vid_ioctl(struct tty *tp, u_long cmd, caddr_t data,
+int		sc_render_add(sc_renderer_t *rndr);
+int		sc_render_remove(sc_renderer_t *rndr);
+sc_rndr_sw_t	*sc_render_match(scr_stat *scp, char *name, int mode);
+/* scvtb.c */
+void		sc_vtb_init(sc_vtb_t *vtb, int type, int cols, int rows,
+			    void *buffer, int wait);
+void		sc_vtb_destroy(sc_vtb_t *vtb);
+size_t		sc_vtb_size(int cols, int rows);
+void		sc_vtb_clear(sc_vtb_t *vtb, int c, int attr);
+int		sc_vtb_getc(sc_vtb_t *vtb, int at);
+int		sc_vtb_geta(sc_vtb_t *vtb, int at);
+void		sc_vtb_putc(sc_vtb_t *vtb, int at, int c, int a);
+vm_offset_t	sc_vtb_putchar(sc_vtb_t *vtb, vm_offset_t p, int c, int a);
+vm_offset_t	sc_vtb_pointer(sc_vtb_t *vtb, int at);
+int		sc_vtb_pos(sc_vtb_t *vtb, int pos, int offset);
+#define		sc_vtb_tail(vtb)	((vtb)->vtb_tail)
+#define		sc_vtb_rows(vtb)	((vtb)->vtb_rows)
+#define		sc_vtb_cols(vtb)	((vtb)->vtb_cols)
+void		sc_vtb_copy(sc_vtb_t *vtb1, int from, sc_vtb_t *vtb2, int to,
+			    int count);
+void		sc_vtb_append(sc_vtb_t *vtb1, int from, sc_vtb_t *vtb2,
+			      int count);
+void		sc_vtb_seek(sc_vtb_t *vtb, int pos);
+void		sc_vtb_erase(sc_vtb_t *vtb, int at, int count, int c, int attr);
+void		sc_vtb_move(sc_vtb_t *vtb, int from, int to, int count);
+void		sc_vtb_delete(sc_vtb_t *vtb, int at, int count, int c, int attr);
+void		sc_vtb_ins(sc_vtb_t *vtb, int at, int count, int c, int attr);
+/* sysmouse.c */
+int		sysmouse_event(mouse_info_t *info);
+/* scterm.c */
+void		sc_move_cursor(scr_stat *scp, int x, int y);
+void		sc_clear_screen(scr_stat *scp);
+int		sc_term_add(sc_term_sw_t *sw);
+int		sc_term_remove(sc_term_sw_t *sw);
+sc_term_sw_t	*sc_term_match(char *name);
+sc_term_sw_t	*sc_term_match_by_number(int index);
+/* machine dependent functions */
+int		sc_max_unit(void);
+sc_softc_t	*sc_get_softc(int unit, int flags);
+sc_softc_t	*sc_find_softc(struct video_adapter *adp, struct keyboard *kbd);
+int		sc_get_cons_priority(int *unit, int *flags);
+void		sc_get_bios_values(bios_values_t *values);
+int		sc_tone(int herz);
+#endif /* !_DEV_SYSCONS_SYSCONS_H_ */
diff --git a/freebsd/sys/dev/vt/vt.h b/freebsd/sys/dev/vt/vt.h
new file mode 100644
index 00000000..34d4c228
--- /dev/null
+++ b/freebsd/sys/dev/vt/vt.h
@@ -0,0 +1,474 @@
+ * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
+ * Copyright (c) 2009, 2013 The FreeBSD Foundation
+ * All rights reserved.
+ * This software was developed by Ed Schouten under sponsorship from the
+ * FreeBSD Foundation.
+ * Portions of this software were developed by Oleksandr Rybalko
+ * under sponsorship from the FreeBSD Foundation.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _DEV_VT_VT_H_
+#define	_DEV_VT_VT_H_
+#include <sys/param.h>
+#include <sys/callout.h>
+#include <sys/condvar.h>
+#include <sys/conf.h>
+#include <sys/consio.h>
+#include <sys/kbio.h>
+#include <sys/mouse.h>
+#include <sys/terminal.h>
+#include <sys/sysctl.h>
+#include <rtems/bsd/local/opt_syscons.h>
+#include <rtems/bsd/local/opt_splash.h>
+#ifndef	VT_MAXWINDOWS
+#ifdef	MAXCONS
+#define	VT_MAXWINDOWS	MAXCONS
+#else
+#define	VT_MAXWINDOWS	12
+#endif
+#endif
+#ifndef VT_ALT_TO_ESC_HACK
+#define	VT_ALT_TO_ESC_HACK	1
+#endif
+#define	VT_CONSWINDOW	0
+#if defined(SC_TWOBUTTON_MOUSE) || defined(VT_TWOBUTTON_MOUSE)
+#define VT_MOUSE_PASTEBUTTON	MOUSE_BUTTON3DOWN	/* right button */
+#define VT_MOUSE_EXTENDBUTTON	MOUSE_BUTTON2DOWN	/* not really used */
+#else
+#define VT_MOUSE_PASTEBUTTON	MOUSE_BUTTON2DOWN	/* middle button */
+#define VT_MOUSE_EXTENDBUTTON	MOUSE_BUTTON3DOWN	/* right button */
+#endif /* defined(SC_TWOBUTTON_MOUSE) || defined(VT_TWOBUTTON_MOUSE) */
+#define	SC_DRIVER_NAME	"vt"
+#ifdef VT_DEBUG
+#define	DPRINTF(_l, ...)	if (vt_debug > (_l)) printf( __VA_ARGS__ )
+#define VT_CONSOLECTL_DEBUG
+#define VT_SYSMOUSE_DEBUG
+#else
+#define	DPRINTF(_l, ...)	do {} while (0)
+#endif
+#define	VT_SYSCTL_INT(_name, _default, _descr)				\
+int vt_##_name = (_default);						\
+SYSCTL_INT(_kern_vt, OID_AUTO, _name, CTLFLAG_RWTUN, &vt_##_name, 0, _descr)
+struct vt_driver;
+void vt_allocate(const struct vt_driver *, void *);
+void vt_deallocate(const struct vt_driver *, void *);
+typedef unsigned int	vt_axis_t;
+ * List of locks
+ * (d)	locked by vd_lock
+ * (b)	locked by vb_lock
+ * (G)	locked by Giant
+ * (u)	unlocked, locked by higher levels
+ * (c)	const until freeing
+ * (?)	yet to be determined
+ * Per-device datastructure.
+struct vt_mouse_cursor;
+#endif
+struct vt_pastebuf {
+	term_char_t		*vpb_buf;	/* Copy-paste buffer. */
+	unsigned int		 vpb_bufsz;	/* Buffer size. */
+	unsigned int		 vpb_len;	/* Length of a last selection. */
+struct vt_device {
+	struct vt_window	*vd_windows[VT_MAXWINDOWS]; /* (c) Windows. */
+	struct vt_window	*vd_curwindow;	/* (d) Current window. */
+	struct vt_window	*vd_savedwindow;/* (?) Saved for suspend. */
+	struct vt_pastebuf	 vd_pastebuf;	/* (?) Copy/paste buf. */
+	const struct vt_driver	*vd_driver;	/* (c) Graphics driver. */
+	void			*vd_softc;	/* (u) Driver data. */
+	const struct vt_driver	*vd_prev_driver;/* (?) Previous driver. */
+	void			*vd_prev_softc;	/* (?) Previous driver data. */
+	device_t		 vd_video_dev;	/* (?) Video adapter. */
+	struct vt_mouse_cursor	*vd_mcursor;	/* (?) Cursor bitmap. */
+	term_color_t		 vd_mcursor_fg;	/* (?) Cursor fg color. */
+	term_color_t		 vd_mcursor_bg;	/* (?) Cursor bg color. */
+	vt_axis_t		 vd_mx_drawn;	/* (?) Mouse X and Y      */
+	vt_axis_t		 vd_my_drawn;	/*     as of last redraw. */
+	int			 vd_mshown;	/* (?) Mouse shown during */
+#endif						/*     last redrawn.      */
+	uint16_t		 vd_mx;		/* (?) Current mouse X. */
+	uint16_t		 vd_my;		/* (?) current mouse Y. */
+	uint32_t		 vd_mstate;	/* (?) Mouse state. */
+	vt_axis_t		 vd_width;	/* (?) Screen width. */
+	vt_axis_t		 vd_height;	/* (?) Screen height. */
+	size_t			 vd_transpose;	/* (?) Screen offset in FB */
+	struct mtx		 vd_lock;	/* Per-device lock. */
+	struct cv		 vd_winswitch;	/* (d) Window switch notify. */
+	struct callout		 vd_timer;	/* (d) Display timer. */
+	volatile unsigned int	 vd_timer_armed;/* (?) Display timer started.*/
+	int			 vd_flags;	/* (d) Device flags. */
+#define	VDF_TEXTMODE	0x01	/* Do text mode rendering. */
+#define	VDF_SPLASH	0x02	/* Splash screen active. */
+#define	VDF_ASYNC	0x04	/* vt_timer() running. */
+#define	VDF_INVALID	0x08	/* Entire screen should be re-rendered. */
+#define	VDF_DEAD	0x10	/* Early probing found nothing. */
+#define	VDF_INITIALIZED	0x20	/* vtterm_cnprobe already done. */
+#define	VDF_MOUSECURSOR	0x40	/* Mouse cursor visible. */
+#define	VDF_QUIET_BELL	0x80	/* Disable bell. */
+#define	VDF_SUSPENDED	0x100	/* Device has been suspended. */
+#define	VDF_DOWNGRADE	0x8000	/* The driver is being downgraded. */
+	int			 vd_keyboard;	/* (G) Keyboard index. */
+	unsigned int		 vd_kbstate;	/* (?) Device unit. */
+	unsigned int		 vd_unit;	/* (c) Device unit. */
+	int			 vd_altbrk;	/* (?) Alt break seq. state */
+	term_char_t		*vd_drawn;	/* (?) Most recent char drawn. */
+	term_color_t		*vd_drawnfg;	/* (?) Most recent fg color drawn. */
+	term_color_t		*vd_drawnbg;	/* (?) Most recent bg color drawn. */
+#define	VD_PASTEBUF(vd)	((vd)->vd_pastebuf.vpb_buf)
+#define	VD_PASTEBUFSZ(vd)	((vd)->vd_pastebuf.vpb_bufsz)
+#define	VD_PASTEBUFLEN(vd)	((vd)->vd_pastebuf.vpb_len)
+#define	VT_LOCK(vd)	mtx_lock(&(vd)->vd_lock)
+#define	VT_UNLOCK(vd)	mtx_unlock(&(vd)->vd_lock)
+#define	VT_LOCK_ASSERT(vd, what)	mtx_assert(&(vd)->vd_lock, what)
+void vt_resume(struct vt_device *vd);
+void vt_resume_flush_timer(struct vt_window *vw, int ms);
+void vt_suspend(struct vt_device *vd);
+ * Per-window terminal screen buffer.
+ * Because redrawing is performed asynchronously, the buffer keeps track
+ * of a rectangle that needs to be redrawn (vb_dirtyrect).  Because this
+ * approach seemed to cause suboptimal performance (when the top left
+ * and the bottom right of the screen are modified), it also uses a set
+ * of bitmasks to keep track of the rows and columns (mod 64) that have
+ * been modified.
+struct vt_buf {
+	struct mtx		 vb_lock;	/* Buffer lock. */
+	term_pos_t		 vb_scr_size;	/* (b) Screen dimensions. */
+	int			 vb_flags;	/* (b) Flags. */
+#define	VBF_CURSOR	0x1	/* Cursor visible. */
+#define	VBF_STATIC	0x2	/* Buffer is statically allocated. */
+#define	VBF_MTX_INIT	0x4	/* Mutex initialized. */
+#define	VBF_SCROLL	0x8	/* scroll locked mode. */
+#define	VBF_HISTORY_FULL 0x10	/* All rows filled. */
+	unsigned int		 vb_history_size;
+	unsigned int		 vb_roffset;	/* (b) History rows offset. */
+	unsigned int		 vb_curroffset;	/* (b) Saved rows offset. */
+	term_pos_t		 vb_cursor;	/* (u) Cursor position. */
+	term_pos_t		 vb_mark_start;	/* (b) Copy region start. */
+	term_pos_t		 vb_mark_end;	/* (b) Copy region end. */
+	int			 vb_mark_last;	/* Last mouse event. */
+	term_rect_t		 vb_dirtyrect;	/* (b) Dirty rectangle. */
+	term_char_t		*vb_buffer;	/* (u) Data buffer. */
+	term_char_t		**vb_rows;	/* (u) Array of rows */
+#ifdef SC_HISTORY_SIZE
+#define	VBF_DEFAULT_HISTORY_SIZE	SC_HISTORY_SIZE
+#else
+#define	VBF_DEFAULT_HISTORY_SIZE	500
+#endif
+void vtbuf_lock(struct vt_buf *);
+void vtbuf_unlock(struct vt_buf *);
+void vtbuf_copy(struct vt_buf *, const term_rect_t *, const term_pos_t *);
+void vtbuf_fill(struct vt_buf *, const term_rect_t *, term_char_t);
+void vtbuf_init_early(struct vt_buf *);
+void vtbuf_init(struct vt_buf *, const term_pos_t *);
+void vtbuf_grow(struct vt_buf *, const term_pos_t *, unsigned int);
+void vtbuf_putchar(struct vt_buf *, const term_pos_t *, term_char_t);
+void vtbuf_cursor_position(struct vt_buf *, const term_pos_t *);
+void vtbuf_scroll_mode(struct vt_buf *vb, int yes);
+void vtbuf_dirty(struct vt_buf *vb, const term_rect_t *area);
+void vtbuf_undirty(struct vt_buf *, term_rect_t *);
+void vtbuf_sethistory_size(struct vt_buf *, unsigned int);
+int vtbuf_iscursor(const struct vt_buf *vb, int row, int col);
+void vtbuf_cursor_visibility(struct vt_buf *, int);
+int vtbuf_set_mark(struct vt_buf *vb, int type, int col, int row);
+int vtbuf_get_marked_len(struct vt_buf *vb);
+void vtbuf_extract_marked(struct vt_buf *vb, term_char_t *buf, int sz);
+#endif
+#define	VTB_MARK_NONE		0
+#define	VTB_MARK_END		1
+#define	VTB_MARK_START		2
+#define	VTB_MARK_WORD		3
+#define	VTB_MARK_ROW		4
+#define	VTB_MARK_EXTEND		5
+#define	VTB_MARK_MOVE		6
+#define	VTBUF_SLCK_ENABLE(vb)	vtbuf_scroll_mode((vb), 1)
+#define	VTBUF_SLCK_DISABLE(vb)	vtbuf_scroll_mode((vb), 0)
+#define	VTBUF_MAX_HEIGHT(vb) \
+	((vb)->vb_history_size)
+#define	VTBUF_GET_ROW(vb, r) \
+	((vb)->vb_rows[((vb)->vb_roffset + (r)) % VTBUF_MAX_HEIGHT(vb)])
+#define	VTBUF_GET_FIELD(vb, r, c) \
+	((vb)->vb_rows[((vb)->vb_roffset + (r)) % VTBUF_MAX_HEIGHT(vb)][(c)])
+#define	VTBUF_FIELD(vb, r, c) \
+	((vb)->vb_rows[((vb)->vb_curroffset + (r)) % VTBUF_MAX_HEIGHT(vb)][(c)])
+#define	VTBUF_ISCURSOR(vb, r, c) \
+	vtbuf_iscursor((vb), (r), (c))
+#define	VTBUF_DIRTYROW(mask, row) \
+	((mask)->vbm_row & ((uint64_t)1 << ((row) % 64)))
+#define	VTBUF_DIRTYCOL(mask, col) \
+	((mask)->vbm_col & ((uint64_t)1 << ((col) % 64)))
+#define	VTBUF_SPACE_CHAR(attr)	(' ' | (attr))
+#define	VHS_SET	0
+#define	VHS_CUR	1
+#define	VHS_END	2
+int vthistory_seek(struct vt_buf *, int offset, int whence);
+void vthistory_addlines(struct vt_buf *vb, int offset);
+void vthistory_getpos(const struct vt_buf *, unsigned int *offset);
+ * Per-window datastructure.
+struct vt_window {
+	struct vt_device	*vw_device;	/* (c) Device. */
+	struct terminal		*vw_terminal;	/* (c) Terminal. */
+	struct vt_buf		 vw_buf;	/* (u) Screen buffer. */
+	struct vt_font		*vw_font;	/* (d) Graphical font. */
+	term_rect_t		 vw_draw_area;	/* (?) Drawable area. */
+	unsigned int		 vw_number;	/* (c) Window number. */
+	int			 vw_kbdmode;	/* (?) Keyboard mode. */
+	int			 vw_prev_kbdmode;/* (?) Previous mode. */
+	int			 vw_kbdstate;	/* (?) Keyboard state. */
+	int			 vw_grabbed;	/* (?) Grab count. */
+	char			*vw_kbdsq;	/* Escape sequence queue*/
+	unsigned int		 vw_flags;	/* (d) Per-window flags. */
+	int			 vw_mouse_level;/* Mouse op mode. */
+#define	VWF_BUSY	0x1	/* Busy reconfiguring device. */
+#define	VWF_OPENED	0x2	/* TTY in use. */
+#define	VWF_SCROLL	0x4	/* Keys influence scrollback. */
+#define	VWF_CONSOLE	0x8	/* Kernel message console window. */
+#define	VWF_VTYLOCK	0x10	/* Prevent window switch. */
+#define	VWF_MOUSE_HIDE	0x20	/* Disable mouse events processing. */
+#define	VWF_READY	0x40	/* Window fully initialized. */
+#define	VWF_GRAPHICS	0x80	/* Window in graphics mode (KDSETMODE). */
+#define	VWF_SWWAIT_REL	0x10000	/* Program wait for VT acquire is done. */
+#define	VWF_SWWAIT_ACQ	0x20000	/* Program wait for VT release is done. */
+	pid_t			 vw_pid;	/* Terminal holding process */
+	struct proc		*vw_proc;
+	struct vt_mode		 vw_smode;	/* switch mode */
+	struct callout		 vw_proc_dead_timer;
+	struct vt_window	*vw_switch_to;
+#define	VT_AUTO		0		/* switching is automatic */
+#define	VT_PROCESS	1		/* switching controlled by prog */
+#define	VT_KERNEL	255		/* switching controlled in kernel */
+#define	IS_VT_PROC_MODE(vw)	((vw)->vw_smode.mode == VT_PROCESS)
+ * Per-device driver routines.
+typedef int vd_init_t(struct vt_device *vd);
+typedef int vd_probe_t(struct vt_device *vd);
+typedef void vd_fini_t(struct vt_device *vd, void *softc);
+typedef void vd_postswitch_t(struct vt_device *vd);
+typedef void vd_blank_t(struct vt_device *vd, term_color_t color);
+typedef void vd_bitblt_text_t(struct vt_device *vd, const struct vt_window *vw,
+    const term_rect_t *area);
+typedef void vd_invalidate_text_t(struct vt_device *vd,
+typedef void vd_bitblt_bmp_t(struct vt_device *vd, const struct vt_window *vw,
+    const uint8_t *pattern, const uint8_t *mask,
+    unsigned int width, unsigned int height,
+    unsigned int x, unsigned int y, term_color_t fg, term_color_t bg);
+typedef int vd_fb_ioctl_t(struct vt_device *, u_long, caddr_t, struct thread *);
+typedef int vd_fb_mmap_t(struct vt_device *, vm_ooffset_t, vm_paddr_t *, int,
+    vm_memattr_t *);
+typedef void vd_drawrect_t(struct vt_device *, int, int, int, int, int,
+    term_color_t);
+typedef void vd_setpixel_t(struct vt_device *, int, int, term_color_t);
+typedef void vd_suspend_t(struct vt_device *);
+typedef void vd_resume_t(struct vt_device *);
+struct vt_driver {
+	char		 vd_name[16];
+	/* Console attachment. */
+	vd_probe_t	*vd_probe;
+	vd_init_t	*vd_init;
+	vd_fini_t	*vd_fini;
+	/* Drawing. */
+	vd_blank_t	*vd_blank;
+	vd_drawrect_t	*vd_drawrect;
+	vd_setpixel_t	*vd_setpixel;
+	vd_bitblt_text_t *vd_bitblt_text;
+	vd_invalidate_text_t *vd_invalidate_text;
+	vd_bitblt_bmp_t	*vd_bitblt_bmp;
+	/* Framebuffer ioctls, if present. */
+	vd_fb_ioctl_t	*vd_fb_ioctl;
+	/* Framebuffer mmap, if present. */
+	vd_fb_mmap_t	*vd_fb_mmap;
+	/* Update display setting on vt switch. */
+	vd_postswitch_t	*vd_postswitch;
+	/* Suspend/resume handlers. */
+	vd_suspend_t	*vd_suspend;
+	vd_resume_t	*vd_resume;
+	/* Priority to know which one can override */
+	int		vd_priority;
+#define	VD_PRIORITY_DUMB	10
+#define	VD_PRIORITY_GENERIC	100
+#define	VD_PRIORITY_SPECIFIC	1000
+ * Console device madness.
+ * Utility macro to make early vt(4) instances work.
+extern struct vt_device vt_consdev;
+extern struct terminal vt_consterm;
+extern const struct terminal_class vt_termclass;
+void vt_upgrade(struct vt_device *vd);
+#define	PIXEL_WIDTH(w)	((w) / 8)
+#define	PIXEL_HEIGHT(h)	((h) / 16)
+#ifndef VT_FB_MAX_WIDTH
+#define	VT_FB_MAX_WIDTH	4096
+#endif
+#ifndef VT_FB_MAX_HEIGHT
+#define	VT_FB_MAX_HEIGHT	2400
+#endif
+/* name argument is not used yet. */
+#define VT_DRIVER_DECLARE(name, drv) DATA_SET(vt_drv_set, drv)
+ * Fonts.
+ * Remapping tables are used to map Unicode points to glyphs.  They need
+ * to be sorted, because vtfont_lookup() performs a binary search.  Each
+ * font has two remapping tables, for normal and bold.  When a character
+ * is not present in bold, it uses a normal glyph.  When no glyph is
+ * available, it uses glyph 0, which is normally equal to U+FFFD.
+struct vt_font_map {
+	uint32_t		 vfm_src;
+	uint16_t		 vfm_dst;
+	uint16_t		 vfm_len;
+struct vt_font {
+	struct vt_font_map	*vf_map[VFNT_MAPS];
+	uint8_t			*vf_bytes;
+	unsigned int		 vf_height, vf_width;
+	unsigned int		 vf_map_count[VFNT_MAPS];
+	unsigned int		 vf_refcount;
+struct vt_mouse_cursor {
+	uint8_t map[64 * 64 / 8];
+	uint8_t mask[64 * 64 / 8];
+	uint8_t width;
+	uint8_t height;
+#endif
+const uint8_t	*vtfont_lookup(const struct vt_font *vf, term_char_t c);
+struct vt_font	*vtfont_ref(struct vt_font *vf);
+void		 vtfont_unref(struct vt_font *vf);
+int		 vtfont_load(vfnt_t *f, struct vt_font **ret);
+/* Sysmouse. */
+void sysmouse_process_event(mouse_info_t *mi);
+void vt_mouse_event(int type, int x, int y, int event, int cnt, int mlevel);
+void vt_mouse_state(int show);
+#endif
+#define	VT_MOUSE_SHOW 1
+#define	VT_MOUSE_HIDE 0
+/* Utilities. */
+void	vt_compute_drawable_area(struct vt_window *);
+void	vt_determine_colors(term_char_t c, int cursor,
+	    term_color_t *fg, term_color_t *bg);
+int	vt_is_cursor_in_area(const struct vt_device *vd,
+void	vt_termsize(struct vt_device *, struct vt_font *, term_pos_t *);
+void	vt_winsize(struct vt_device *, struct vt_font *, struct winsize *);
+/* Logos-on-boot. */
+#define	VT_LOGOS_DRAW_BEASTIE		0
+#define	VT_LOGOS_DRAW_ALT_BEASTIE	1
+#define	VT_LOGOS_DRAW_ORB		2
+extern int vt_draw_logo_cpus;
+extern int vt_splash_cpu;
+extern int vt_splash_ncpu;
+extern int vt_splash_cpu_style;
+extern int vt_splash_cpu_duration;
+extern const unsigned int vt_logo_sprite_height;
+extern const unsigned int vt_logo_sprite_width;
+void vtterm_draw_cpu_logos(struct vt_device *);
+#endif /* !_DEV_VT_VT_H_ */
diff --git a/freebsd/sys/sys/consio.h b/freebsd/sys/sys/consio.h
index 00000000..5dfedc4b
--- /dev/null
+++ b/freebsd/sys/sys/consio.h
@@ -0,0 +1,468 @@
+ * Copyright (c) 1991-1996 Søren Schmidt
+ * are met:
+ *    in this position and unchanged.
+ * $FreeBSD$
+#ifndef	_SYS_CONSIO_H_
+#define	_SYS_CONSIO_H_
+#ifndef _KERNEL
+#include <sys/types.h>
+#endif
+#include <sys/ioccom.h>
+ * Console ioctl commands.  Some commands are named as KDXXXX, GIO_XXX, and
+ * PIO_XXX, rather than CONS_XXX, for historical and compatibility reasons.
+ * Some other CONS_XXX commands are works as wrapper around frame buffer
+ * ioctl commands FBIO_XXX.  Do not try to change all these commands,
+ * otherwise we shall have compatibility problems.
+/* get/set video mode */
+#define KD_TEXT		0		/* set text mode restore fonts  */
+#define KD_TEXT0	0		/* ditto			*/
+#define KD_GRAPHICS	1		/* set graphics mode 		*/
+#define KD_TEXT1	2		/* set text mode !restore fonts */
+#define KD_PIXEL	3		/* set pixel mode		*/
+#define KDGETMODE	_IOR('K', 9, int)
+#define KDSETMODE	_IOWINT('K', 10)
+/* set border color */
+#define KDSBORDER	_IOWINT('K', 13)
+/* set up raster(pixel) text mode */
+struct _scr_size {
+	int		scr_size[3];
+typedef struct _scr_size	scr_size_t;
+#define KDRASTER	_IOW('K', 100, scr_size_t)
+/* get/set screen char map */
+struct _scrmap {
+	char		scrmap[256];
+typedef struct _scrmap	scrmap_t;
+#define GIO_SCRNMAP	_IOR('k', 2, scrmap_t)
+#define PIO_SCRNMAP	_IOW('k', 3, scrmap_t)
+/* get the current text attribute */
+#define GIO_ATTR	_IOR('a', 0, int)
+/* get the current text color */
+#define GIO_COLOR	_IOR('c', 0, int)
+/* get the adapter type (equivalent to FBIO_ADPTYPE) */
+#define CONS_CURRENT	_IOR('c', 1, int)
+/* get the current video mode (equivalent to FBIO_GETMODE) */
+#define CONS_GET	_IOR('c', 2, int)
+/* not supported? */
+#define CONS_IO		_IO('c', 3)
+/* set blank time interval */
+#define CONS_BLANKTIME	_IOW('c', 4, int)
+/* set/get the screen saver (these ioctls are current noop) */
+struct ssaver	{
+#define MAXSSAVER	16
+	char		name[MAXSSAVER];
+	int		num;
+	long		time;
+typedef struct ssaver	ssaver_t;
+#define CONS_SSAVER	_IOW('c', 5, ssaver_t)
+#define CONS_GSAVER	_IOWR('c', 6, ssaver_t)
+ * Set the text cursor type.
+ * This is an old interface extended to support the CONS_HIDDEN_CURSOR bit.
+ * New code should use CONS_CURSORSHAPE.  CONS_CURSOR_ATTRS gives the 3
+ * bits supported by the (extended) old interface.  The old interface is
+ * especially unusable for hiding the cursor (even with its extension)
+ * since it changes the cursor on all vtys.
+#define CONS_CURSORTYPE	_IOW('c', 7, int)
+/* set the bell type to audible or visual */
+#define CONS_VISUAL_BELL (1 << 0)
+#define CONS_QUIET_BELL	(1 << 1)
+#define CONS_BELLTYPE	_IOW('c', 8, int)
+/* set the history (scroll back) buffer size (in lines) */
+#define CONS_HISTORY	_IOW('c', 9, int)
+/* clear the history (scroll back) buffer */
+#define CONS_CLRHIST	_IO('c', 10)
+/* mouse cursor ioctl */
+struct mouse_data {
+	int		x;
+	int 		y;
+	int 		z;
+	int 		buttons;
+typedef struct mouse_data mouse_data_t;
+struct mouse_mode {
+	int		mode;
+	int		signal;
+typedef struct mouse_mode mouse_mode_t;
+struct mouse_event {
+	int		id;			/* one based */
+	int		value;
+typedef struct mouse_event mouse_event_t;
+struct mouse_info {
+	int		operation;
+#define MOUSE_SHOW	0x01
+#define MOUSE_HIDE	0x02
+#define MOUSE_MOVEABS	0x03
+#define MOUSE_MOVEREL	0x04
+#define MOUSE_GETINFO	0x05
+#define MOUSE_MODE	0x06
+#define MOUSE_ACTION	0x07
+#define MOUSE_MOTION_EVENT	0x08
+#define MOUSE_BUTTON_EVENT	0x09
+#define MOUSE_MOUSECHAR	0x0a
+	union {
+		mouse_data_t	data;
+		mouse_mode_t	mode;
+		mouse_event_t	event;
+		int		mouse_char;
+	}		u;
+typedef struct mouse_info mouse_info_t;
+#define CONS_MOUSECTL	_IOWR('c', 10, mouse_info_t)
+/* see if the vty has been idle */
+#define CONS_IDLE	_IOR('c', 11, int)
+/* set the screen saver mode */
+#define CONS_NO_SAVER	(-1)
+#define CONS_LKM_SAVER	0
+#define CONS_USR_SAVER	1
+#define CONS_SAVERMODE	_IOW('c', 12, int)
+/* start the screen saver */
+#define CONS_SAVERSTART	_IOW('c', 13, int)
+/* set the text cursor shape (see also CONS_CURSORTYPE above) */
+#define CONS_BLINK_CURSOR	(1 << 0)
+#define CONS_CHAR_CURSOR	(1 << 1)
+#define CONS_HIDDEN_CURSOR	(1 << 2)
+#define CONS_CURSOR_ATTRS	(CONS_BLINK_CURSOR | CONS_CHAR_CURSOR |	\
+				 CONS_HIDDEN_CURSOR)
+#define CONS_CHARCURSOR_COLORS	(1 << 26)
+#define CONS_MOUSECURSOR_COLORS	(1 << 27)
+#define CONS_DEFAULT_CURSOR	(1 << 28)
+#define CONS_SHAPEONLY_CURSOR	(1 << 29)
+#define CONS_RESET_CURSOR	(1 << 30)
+#define CONS_LOCAL_CURSOR	(1U << 31)
+struct cshape {
+	/* shape[0]: flags, shape[1]: base, shape[2]: height */
+	int		shape[3];
+#define CONS_GETCURSORSHAPE _IOWR('c', 14, struct cshape)
+#define CONS_SETCURSORSHAPE _IOW('c', 15, struct cshape)
+/* set/get font data */
+struct fnt8 {
+	char		fnt8x8[8*256];
+typedef struct fnt8	fnt8_t;
+struct fnt14 {
+	char		fnt8x14[14*256];
+typedef struct fnt14	fnt14_t;
+struct fnt16 {
+	char		fnt8x16[16*256];
+typedef struct fnt16	fnt16_t;
+struct vfnt_map {
+	uint32_t	src;
+	uint16_t	dst;
+	uint16_t	len;
+typedef struct vfnt_map	vfnt_map_t;
+#define VFNT_MAP_NORMAL		0
+#define VFNT_MAP_NORMAL_RIGHT	1
+#define VFNT_MAP_BOLD		2
+#define VFNT_MAP_BOLD_RIGHT	3
+#define VFNT_MAPS		4
+struct vfnt {
+	vfnt_map_t	*map[VFNT_MAPS];
+	uint8_t		*glyphs;
+	unsigned int	map_count[VFNT_MAPS];
+	unsigned int	glyph_count;
+	unsigned int	width;
+	unsigned int	height;
+typedef struct vfnt	vfnt_t;
+#define PIO_FONT8x8	_IOW('c', 64, fnt8_t)
+#define GIO_FONT8x8	_IOR('c', 65, fnt8_t)
+#define PIO_FONT8x14	_IOW('c', 66, fnt14_t)
+#define GIO_FONT8x14	_IOR('c', 67, fnt14_t)
+#define PIO_FONT8x16	_IOW('c', 68, fnt16_t)
+#define GIO_FONT8x16	_IOR('c', 69, fnt16_t)
+#define PIO_VFONT	_IOW('c', 70, vfnt_t)
+#define GIO_VFONT	_IOR('c', 71, vfnt_t)
+#define PIO_VFONT_DEFAULT _IO('c', 72)
+/* get video mode information */
+struct colors	{
+	char		fore;
+	char		back;
+struct vid_info {
+	short		size;
+	short		m_num;
+	u_short		font_size;
+	u_short		mv_row, mv_col;
+	u_short		mv_rsz, mv_csz;
+	u_short		mv_hsz;
+	struct colors	mv_norm,
+			mv_rev,
+			mv_grfc;
+	u_char		mv_ovscan;
+	u_char		mk_keylock;
+typedef struct vid_info vid_info_t;
+#define CONS_GETINFO    _IOWR('c', 73, vid_info_t)
+/* get version */
+#define CONS_GETVERS	_IOR('c', 74, int)
+/* get the video adapter index (equivalent to FBIO_ADAPTER) */
+#define CONS_CURRENTADP	_IOR('c', 100, int)
+/* get the video adapter information (equivalent to FBIO_ADPINFO) */
+#define CONS_ADPINFO	_IOWR('c', 101, video_adapter_info_t)
+/* get the video mode information (equivalent to FBIO_MODEINFO) */
+#define CONS_MODEINFO	_IOWR('c', 102, video_info_t)
+/* find a video mode (equivalent to FBIO_FINDMODE) */
+#define CONS_FINDMODE	_IOWR('c', 103, video_info_t)
+/* set the frame buffer window origin (equivalent to FBIO_SETWINORG) */
+#define CONS_SETWINORG	_IOWINT('c', 104)
+/* use the specified keyboard */
+#define CONS_SETKBD	_IOWINT('c', 110)
+/* release the current keyboard */
+#define CONS_RELKBD	_IO('c', 111)
+struct scrshot {
+	int		x;
+	int		y;
+	int		xsize;
+	int		ysize;
+	u_int16_t*	buf;
+typedef struct scrshot scrshot_t;
+/* Snapshot the current video buffer */
+#define CONS_SCRSHOT	_IOWR('c', 105, scrshot_t)
+/* get/set the current terminal emulator info. */
+#define TI_NAME_LEN	32
+#define TI_DESC_LEN	64
+struct term_info {
+	int		ti_index;
+	int		ti_flags;
+	u_char		ti_name[TI_NAME_LEN];
+	u_char		ti_desc[TI_DESC_LEN];
+typedef struct term_info term_info_t;
+#define CONS_GETTERM	_IOWR('c', 112, term_info_t)
+#define CONS_SETTERM	_IOW('c', 113, term_info_t)
+ * Vty switching ioctl commands.
+/* get the next available vty */
+#define VT_OPENQRY	_IOR('v', 1, int)
+/* set/get vty switching mode */
+#ifndef _VT_MODE_DECLARED
+#define	_VT_MODE_DECLARED
+struct vt_mode {
+	char		mode;
+	char		waitv;		/* not implemented yet 	SOS	*/
+	short		relsig;
+	short		acqsig;
+	short		frsig;		/* not implemented yet	SOS	*/
+typedef struct vt_mode vtmode_t;
+#endif /* !_VT_MODE_DECLARED */
+#define VT_SETMODE	_IOW('v', 2, vtmode_t)
+#define VT_GETMODE	_IOR('v', 3, vtmode_t)
+/* acknowledge release or acquisition of a vty */
+#define VT_FALSE	0
+#define VT_TRUE		1
+#define VT_ACKACQ	2
+#define VT_RELDISP	_IOWINT('v', 4)
+/* activate the specified vty */
+#define VT_ACTIVATE	_IOWINT('v', 5)
+/* wait until the specified vty is activate */
+#define VT_WAITACTIVE	_IOWINT('v', 6)
+/* get the currently active vty */
+#define VT_GETACTIVE	_IOR('v', 7, int)
+/* get the index of the vty */
+#define VT_GETINDEX	_IOR('v', 8, int)
+/* prevent switching vtys */
+#define VT_LOCKSWITCH	_IOW('v', 9, int)
+ * Video mode switching ioctl.  See sys/fbio.h for mode numbers.
+#define SW_B40x25 	_IO('S', M_B40x25)
+#define SW_C40x25  	_IO('S', M_C40x25)
+#define SW_B80x25  	_IO('S', M_B80x25)
+#define SW_C80x25  	_IO('S', M_C80x25)
+#define SW_BG320   	_IO('S', M_BG320)
+#define SW_CG320   	_IO('S', M_CG320)
+#define SW_BG640   	_IO('S', M_BG640)
+#define SW_EGAMONO80x25 _IO('S', M_EGAMONO80x25)
+#define SW_CG320_D    	_IO('S', M_CG320_D)
+#define SW_CG640_E    	_IO('S', M_CG640_E)
+#define SW_EGAMONOAPA 	_IO('S', M_EGAMONOAPA)
+#define SW_CG640x350  	_IO('S', M_CG640x350)
+#define SW_ENH_MONOAPA2 _IO('S', M_ENHMONOAPA2)
+#define SW_ENH_CG640  	_IO('S', M_ENH_CG640)
+#define SW_ENH_B40x25  	_IO('S', M_ENH_B40x25)
+#define SW_ENH_C40x25  	_IO('S', M_ENH_C40x25)
+#define SW_ENH_B80x25  	_IO('S', M_ENH_B80x25)
+#define SW_ENH_C80x25  	_IO('S', M_ENH_C80x25)
+#define SW_ENH_B80x43  	_IO('S', M_ENH_B80x43)
+#define SW_ENH_C80x43  	_IO('S', M_ENH_C80x43)
+#define SW_MCAMODE    	_IO('S', M_MCA_MODE)
+#define SW_VGA_C40x25	_IO('S', M_VGA_C40x25)
+#define SW_VGA_C80x25	_IO('S', M_VGA_C80x25)
+#define SW_VGA_C80x30	_IO('S', M_VGA_C80x30)
+#define SW_VGA_C80x50	_IO('S', M_VGA_C80x50)
+#define SW_VGA_C80x60	_IO('S', M_VGA_C80x60)
+#define SW_VGA_M80x25	_IO('S', M_VGA_M80x25)
+#define SW_VGA_M80x30	_IO('S', M_VGA_M80x30)
+#define SW_VGA_M80x50	_IO('S', M_VGA_M80x50)
+#define SW_VGA_M80x60	_IO('S', M_VGA_M80x60)
+#define SW_VGA11	_IO('S', M_VGA11)
+#define SW_BG640x480	_IO('S', M_VGA11)
+#define SW_VGA12	_IO('S', M_VGA12)
+#define SW_CG640x480	_IO('S', M_VGA12)
+#define SW_VGA13	_IO('S', M_VGA13)
+#define SW_VGA_CG320	_IO('S', M_VGA13)
+#define SW_VGA_CG640	_IO('S', M_VGA_CG640)
+#define SW_VGA_MODEX	_IO('S', M_VGA_MODEX)
+#define SW_VGA_C90x25	_IO('S', M_VGA_C90x25)
+#define SW_VGA_M90x25	_IO('S', M_VGA_M90x25)
+#define SW_VGA_C90x30	_IO('S', M_VGA_C90x30)
+#define SW_VGA_M90x30	_IO('S', M_VGA_M90x30)
+#define SW_VGA_C90x43	_IO('S', M_VGA_C90x43)
+#define SW_VGA_M90x43	_IO('S', M_VGA_M90x43)
+#define SW_VGA_C90x50	_IO('S', M_VGA_C90x50)
+#define SW_VGA_M90x50	_IO('S', M_VGA_M90x50)
+#define SW_VGA_C90x60	_IO('S', M_VGA_C90x60)
+#define SW_VGA_M90x60	_IO('S', M_VGA_M90x60)
+#define SW_TEXT_80x25	_IO('S', M_TEXT_80x25)
+#define SW_TEXT_80x30	_IO('S', M_TEXT_80x30)
+#define SW_TEXT_80x43	_IO('S', M_TEXT_80x43)
+#define SW_TEXT_80x50	_IO('S', M_TEXT_80x50)
+#define SW_TEXT_80x60	_IO('S', M_TEXT_80x60)
+#define SW_TEXT_132x25	_IO('S', M_TEXT_132x25)
+#define SW_TEXT_132x30	_IO('S', M_TEXT_132x30)
+#define SW_TEXT_132x43	_IO('S', M_TEXT_132x43)
+#define SW_TEXT_132x50	_IO('S', M_TEXT_132x50)
+#define SW_TEXT_132x60	_IO('S', M_TEXT_132x60)
+#define SW_VESA_CG640x400	_IO('V', M_VESA_CG640x400 - M_VESA_BASE)
+#define SW_VESA_CG640x480	_IO('V', M_VESA_CG640x480 - M_VESA_BASE)
+#define SW_VESA_800x600		_IO('V', M_VESA_800x600 - M_VESA_BASE)
+#define SW_VESA_CG800x600	_IO('V', M_VESA_CG800x600 - M_VESA_BASE)
+#define SW_VESA_1024x768	_IO('V', M_VESA_1024x768 - M_VESA_BASE)
+#define SW_VESA_CG1024x768	_IO('V', M_VESA_CG1024x768 - M_VESA_BASE)
+#define SW_VESA_1280x1024	_IO('V', M_VESA_1280x1024 - M_VESA_BASE)
+#define SW_VESA_CG1280x1024	_IO('V', M_VESA_CG1280x1024 - M_VESA_BASE)
+#define SW_VESA_C80x60		_IO('V', M_VESA_C80x60 - M_VESA_BASE)
+#define SW_VESA_C132x25		_IO('V', M_VESA_C132x25 - M_VESA_BASE)
+#define SW_VESA_C132x43		_IO('V', M_VESA_C132x43 - M_VESA_BASE)
+#define SW_VESA_C132x50		_IO('V', M_VESA_C132x50 - M_VESA_BASE)
+#define SW_VESA_C132x60		_IO('V', M_VESA_C132x60 - M_VESA_BASE)
+#define SW_VESA_32K_320		_IO('V', M_VESA_32K_320 - M_VESA_BASE)
+#define SW_VESA_64K_320		_IO('V', M_VESA_64K_320 - M_VESA_BASE)
+#define SW_VESA_FULL_320	_IO('V', M_VESA_FULL_320 - M_VESA_BASE)
+#define SW_VESA_32K_640		_IO('V', M_VESA_32K_640 - M_VESA_BASE)
+#define SW_VESA_64K_640		_IO('V', M_VESA_64K_640 - M_VESA_BASE)
+#define SW_VESA_FULL_640	_IO('V', M_VESA_FULL_640 - M_VESA_BASE)
+#define SW_VESA_32K_800		_IO('V', M_VESA_32K_800 - M_VESA_BASE)
+#define SW_VESA_64K_800		_IO('V', M_VESA_64K_800 - M_VESA_BASE)
+#define SW_VESA_FULL_800	_IO('V', M_VESA_FULL_800 - M_VESA_BASE)
+#define SW_VESA_32K_1024	_IO('V', M_VESA_32K_1024 - M_VESA_BASE)
+#define SW_VESA_64K_1024	_IO('V', M_VESA_64K_1024 - M_VESA_BASE)
+#define SW_VESA_FULL_1024	_IO('V', M_VESA_FULL_1024 - M_VESA_BASE)
+#define SW_VESA_32K_1280	_IO('V', M_VESA_32K_1280 - M_VESA_BASE)
+#define SW_VESA_64K_1280	_IO('V', M_VESA_64K_1280 - M_VESA_BASE)
+#define SW_VESA_FULL_1280	_IO('V', M_VESA_FULL_1280 - M_VESA_BASE)
+#endif /* !_SYS_CONSIO_H_ */
diff --git a/freebsd/sys/sys/fbio.h b/freebsd/sys/sys/fbio.h
index 00000000..4cc0cc6d
--- /dev/null
+++ b/freebsd/sys/sys/fbio.h
@@ -0,0 +1,622 @@
+ * Copyright (c) 1992, 1993
+ *	The Regents of the University of California.  All rights reserved.
+ * This code is derived from software developed by the Computer Systems
+ * Engineering group at Lawrence Berkeley Laboratory under DARPA
+ * contract BG 91-66 and contributed to Berkeley.
+ * are met:
+ * 3. Neither the name of the University nor the names of its contributors
+ *    may be used to endorse or promote products derived from this software
+ *    without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * SUCH DAMAGE.
+ *	@(#)fbio.h	8.2 (Berkeley) 10/30/93
+ * $FreeBSD$
+#ifndef _SYS_FBIO_H_
+#define _SYS_FBIO_H_
+#ifndef _KERNEL
+#else
+#include <sys/systm.h>
+#include <sys/eventhandler.h>
+#endif
+ * Frame buffer ioctls (from Sprite, trimmed to essentials for X11).
+ * Frame buffer type codes.
+#define	FBTYPE_SUN1BW		0	/* multibus mono */
+#define	FBTYPE_SUN1COLOR	1	/* multibus color */
+#define	FBTYPE_SUN2BW		2	/* memory mono */
+#define	FBTYPE_SUN2COLOR	3	/* color w/rasterop chips */
+#define	FBTYPE_SUN2GP		4	/* GP1/GP2 */
+#define	FBTYPE_SUN5COLOR	5	/* RoadRunner accelerator */
+#define	FBTYPE_SUN3COLOR	6	/* memory color */
+#define	FBTYPE_MEMCOLOR		7	/* memory 24-bit */
+#define	FBTYPE_SUN4COLOR	8	/* memory color w/overlay */
+#define	FBTYPE_NOTSUN1		9	/* reserved for customer */
+#define	FBTYPE_NOTSUN2		10	/* reserved for customer */
+#define	FBTYPE_PCIMISC		11	/* (generic) PCI misc. disp. */
+#define	FBTYPE_SUNFAST_COLOR	12	/* accelerated 8bit */
+#define	FBTYPE_SUNROP_COLOR	13	/* MEMCOLOR with rop h/w */
+#define	FBTYPE_SUNFB_VIDEO	14	/* Simple video mixing */
+#define	FBTYPE_RESERVED5	15	/* reserved, do not use */
+#define	FBTYPE_RESERVED4	16	/* reserved, do not use */
+#define	FBTYPE_SUNGP3		17
+#define	FBTYPE_SUNGT		18
+#define	FBTYPE_SUNLEO		19	/* zx Leo */
+#define	FBTYPE_MDA		20
+#define	FBTYPE_HERCULES		21
+#define	FBTYPE_CGA		22
+#define	FBTYPE_EGA		23
+#define	FBTYPE_VGA		24
+#define	FBTYPE_TGA		26
+#define	FBTYPE_TGA2		27
+#define	FBTYPE_MDICOLOR		28	/* cg14 */
+#define	FBTYPE_TCXCOLOR		29	/* SUNW,tcx */
+#define	FBTYPE_CREATOR		30
+#define	FBTYPE_LASTPLUSONE	31	/* max number of fbs (change as add) */
+ * Frame buffer descriptor as returned by FBIOGTYPE.
+struct fbtype {
+	int	fb_type;	/* as defined above */
+	int	fb_height;	/* in pixels */
+	int	fb_width;	/* in pixels */
+	int	fb_depth;	/* bits per pixel */
+	int	fb_cmsize;	/* size of color map (entries) */
+	int	fb_size;	/* total size in bytes */
+#define	FBIOGTYPE	_IOR('F', 0, struct fbtype)
+#define	FBTYPE_GET_STRIDE(_fb)	((_fb)->fb_size / (_fb)->fb_height)
+#define	FBTYPE_GET_BPP(_fb)	((_fb)->fb_bpp)
+#define	FBTYPE_GET_BYTESPP(_fb)	((_fb)->fb_bpp / 8)
+#ifdef	_KERNEL
+struct fb_info;
+typedef int fb_enter_t(void *priv);
+typedef int fb_leave_t(void *priv);
+typedef int fb_setblankmode_t(void *priv, int mode);
+struct fb_info {
+	/* Raw copy of fbtype. Do not change. */
+	int		fb_depth;	/* bits to define color */
+	struct cdev 	*fb_cdev;
+	device_t	 fb_fbd_dev;	/* "fbd" device. */
+	device_t	 fb_video_dev;	/* Video adapter. */
+	fb_enter_t	*enter;
+	fb_leave_t	*leave;
+	fb_setblankmode_t *setblankmode;
+	uintptr_t	fb_pbase;	/* For FB mmap. */
+	uintptr_t	fb_vbase;	/* if NULL, use fb_write/fb_read. */
+	void		*fb_priv;	/* First argument for read/write. */
+	const char	*fb_name;
+	uint32_t	fb_flags;
+#define	FB_FLAG_NOMMAP		1	/* mmap unsupported. */
+#define	FB_FLAG_NOWRITE		2	/* disable writes for the time being */
+#define	FB_FLAG_MEMATTR		4	/* override memattr for mmap */
+	vm_memattr_t	fb_memattr;
+	int		fb_stride;
+	int		fb_bpp;		/* bits per pixel */
+	uint32_t	fb_cmap[16];
+int fbd_list(void);
+int fbd_register(struct fb_info *);
+int fbd_unregister(struct fb_info *);
+static inline int
+register_framebuffer(struct fb_info *info)
+	EVENTHANDLER_INVOKE(register_framebuffer, info);
+	return (0);
+static inline int
+unregister_framebuffer(struct fb_info *info)
+	EVENTHANDLER_INVOKE(unregister_framebuffer, info);
+	return (0);
+#endif
+#ifdef notdef
+ * General purpose structure for passing info in and out of frame buffers
+ * (used for gp1) -- unsupported.
+struct fbinfo {
+	int	fb_physaddr;	/* physical frame buffer address */
+	int	fb_hwwidth;	/* fb board width */
+	int	fb_hwheight;	/* fb board height */
+	int	fb_addrdelta;	/* phys addr diff between boards */
+	u_char	*fb_ropaddr;	/* fb virtual addr */
+	int	fb_unit;	/* minor devnum of fb */
+#define	FBIOGINFO	_IOR('F', 2, struct fbinfo)
+#endif
+ * Color map I/O.
+struct fbcmap {
+	int	index;		/* first element (0 origin) */
+	int	count;		/* number of elements */
+	u_char	*red;		/* red color map elements */
+	u_char	*green;		/* green color map elements */
+	u_char	*blue;		/* blue color map elements */
+#define	FBIOPUTCMAP	_IOW('F', 3, struct fbcmap)
+#define	FBIOGETCMAP	_IOW('F', 4, struct fbcmap)
+ * Set/get attributes.
+#define	FB_ATTR_NDEVSPECIFIC	8	/* no. of device specific values */
+#define	FB_ATTR_NEMUTYPES	4	/* no. of emulation types */
+struct fbsattr {
+	int	flags;			/* flags; see below */
+	int	emu_type;		/* emulation type (-1 if unused) */
+	int	dev_specific[FB_ATTR_NDEVSPECIFIC];	/* catchall */
+#define	FB_ATTR_AUTOINIT	1	/* emulation auto init flag */
+#define	FB_ATTR_DEVSPECIFIC	2	/* dev. specific stuff valid flag */
+struct fbgattr {
+	int	real_type;		/* real device type */
+	int	owner;			/* PID of owner, 0 if myself */
+	struct	fbtype fbtype;		/* fbtype info for real device */
+	struct	fbsattr sattr;		/* see above */
+	int	emu_types[FB_ATTR_NEMUTYPES];	/* possible emulations */
+						/* (-1 if unused) */
+#define	FBIOSATTR	_IOW('F', 5, struct fbsattr)
+#define	FBIOGATTR	_IOR('F', 6, struct fbgattr)
+ * Video control.
+#define	FBVIDEO_OFF		0
+#define	FBVIDEO_ON		1
+#define	FBIOSVIDEO	_IOW('F', 7, int)
+#define	FBIOGVIDEO	_IOR('F', 8, int)
+/* vertical retrace */
+#define	FBIOVERTICAL	_IO('F', 9)
+ * Hardware cursor control (for, e.g., CG6).  A rather complex and icky
+ * interface that smells like VMS, but there it is....
+struct fbcurpos {
+	short	x;
+	short	y;
+struct fbcursor {
+	short	set;		/* flags; see below */
+	short	enable;		/* nonzero => cursor on, 0 => cursor off */
+	struct	fbcurpos pos;	/* position on display */
+	struct	fbcurpos hot;	/* hot-spot within cursor */
+	struct	fbcmap cmap;	/* cursor color map */
+	struct	fbcurpos size;	/* number of valid bits in image & mask */
+	caddr_t	image;		/* cursor image bits */
+	caddr_t	mask;		/* cursor mask bits */
+#define	FB_CUR_SETCUR	0x01	/* set on/off (i.e., obey fbcursor.enable) */
+#define	FB_CUR_SETPOS	0x02	/* set position */
+#define	FB_CUR_SETHOT	0x04	/* set hot-spot */
+#define	FB_CUR_SETCMAP	0x08	/* set cursor color map */
+#define	FB_CUR_SETSHAPE	0x10	/* set size & bits */
+#define	FB_CUR_SETALL	(FB_CUR_SETCUR | FB_CUR_SETPOS | FB_CUR_SETHOT | \
+			 FB_CUR_SETCMAP | FB_CUR_SETSHAPE)
+/* controls for cursor attributes & shape (including position) */
+#define	FBIOSCURSOR	_IOW('F', 24, struct fbcursor)
+#define	FBIOGCURSOR	_IOWR('F', 25, struct fbcursor)
+/* controls for cursor position only */
+#define	FBIOSCURPOS	_IOW('F', 26, struct fbcurpos)
+#define	FBIOGCURPOS	_IOW('F', 27, struct fbcurpos)
+/* get maximum cursor size */
+#define	FBIOGCURMAX	_IOR('F', 28, struct fbcurpos)
+ * Video board information
+struct brd_info {
+	u_short		accessible_width; /* accessible bytes in scanline */
+	u_short		accessible_height; /* number of accessible scanlines */
+	u_short		line_bytes;	/* number of bytes/scanline */
+	u_short		hdb_capable;	/* can this thing hardware db? */
+	u_short		vmsize;		/* video memory size */
+	u_char		boardrev;	/* board revision # */
+	u_char		pad0;
+	u_long		pad1;
+#define	FBIOGXINFO	_IOR('F', 39, struct brd_info)
+ * Monitor information
+struct mon_info {
+	u_long		mon_type;	/* bit array */
+#define MON_TYPE_STEREO		0x8	/* stereo display */
+#define MON_TYPE_0_OFFSET	0x4	/* black level 0 ire instead of 7.5 */
+#define MON_TYPE_OVERSCAN	0x2	/* overscan */
+#define MON_TYPE_GRAY		0x1	/* greyscale monitor */
+	u_long		pixfreq;	/* pixel frequency in Hz */
+	u_long		hfreq;		/* horizontal freq in Hz */
+	u_long		vfreq;		/* vertical freq in Hz */
+	u_long		vsync;		/* vertical sync in scanlines */
+	u_long		hsync;		/* horizontal sync in pixels */
+	/* these are in pixel units */
+	u_short		hfporch;	/* horizontal front porch */
+	u_short		hbporch;	/* horizontal back porch */
+	u_short		vfporch;	/* vertical front porch */
+	u_short		vbporch;	/* vertical back porch */
+#define	FBIOMONINFO	_IOR('F', 40, struct mon_info)
+ * Color map I/O.
+struct fbcmap_i {
+	unsigned int	flags;
+#define	FB_CMAP_BLOCK	(1 << 0)	/* wait for vertical refresh */
+#define	FB_CMAP_KERNEL	(1 << 1)	/* called within kernel */
+	int		id;		/* color map id */
+#define	FBIOPUTCMAPI	_IOW('F', 41, struct fbcmap_i)
+#define	FBIOGETCMAPI	_IOW('F', 42, struct fbcmap_i)
+/* The new style frame buffer ioctls. */
+/* video mode information block */
+struct video_info {
+    int			vi_mode;	/* mode number, see below */
+    int			vi_flags;
+#define V_INFO_COLOR	(1 << 0)
+#define V_INFO_GRAPHICS	(1 << 1)
+#define V_INFO_LINEAR	(1 << 2)
+#define V_INFO_VESA	(1 << 3)
+#define	V_INFO_NONVGA	(1 << 4)
+#define	V_INFO_CWIDTH9	(1 << 5)
+    int			vi_width;
+    int			vi_height;
+    int			vi_cwidth;
+    int			vi_cheight;
+    int			vi_depth;
+    int			vi_planes;
+    vm_offset_t		vi_window;	/* physical address */
+    size_t		vi_window_size;
+    size_t		vi_window_gran;
+    vm_offset_t		vi_buffer;	/* physical address */
+    size_t		vi_buffer_size;
+    int			vi_mem_model;
+#define V_INFO_MM_OTHER  (-1)
+#define V_INFO_MM_TEXT	 0
+#define V_INFO_MM_PLANAR 1
+#define V_INFO_MM_PACKED 2
+#define V_INFO_MM_DIRECT 3
+#define V_INFO_MM_CGA	 100
+#define V_INFO_MM_HGC	 101
+#define V_INFO_MM_VGAX	 102
+    /* for MM_PACKED and MM_DIRECT only */
+    int			vi_pixel_size;	/* in bytes */
+    /* for MM_DIRECT only */
+    int			vi_pixel_fields[4];	/* RGB and reserved fields */
+    int			vi_pixel_fsizes[4];
+    /* reserved */
+    u_char		vi_reserved[64];
+    vm_offset_t		vi_registers;	/* physical address */
+    vm_offset_t		vi_registers_size;
+typedef struct video_info video_info_t;
+/* adapter infromation block */
+struct video_adapter {
+    int			va_index;
+    int			va_type;
+#define KD_OTHER	0		/* unknown */
+#define KD_MONO		1		/* monochrome adapter */
+#define KD_HERCULES	2		/* hercules adapter */
+#define KD_CGA		3		/* color graphics adapter */
+#define KD_EGA		4		/* enhanced graphics adapter */
+#define KD_VGA		5		/* video graphics adapter */
+#define KD_TGA		7		/* TGA */
+#define KD_TGA2		8		/* TGA2 */
+    char		*va_name;
+    int			va_unit;
+    int			va_minor;
+    int			va_flags;
+#define V_ADP_COLOR	(1 << 0)
+#define V_ADP_MODECHANGE (1 << 1)
+#define V_ADP_STATESAVE	(1 << 2)
+#define V_ADP_STATELOAD	(1 << 3)
+#define V_ADP_FONT	(1 << 4)
+#define V_ADP_PALETTE	(1 << 5)
+#define V_ADP_BORDER	(1 << 6)
+#define V_ADP_VESA	(1 << 7)
+#define V_ADP_BOOTDISPLAY (1 << 8)
+#define V_ADP_PROBED	(1 << 16)
+#define V_ADP_INITIALIZED (1 << 17)
+#define V_ADP_REGISTERED (1 << 18)
+#define V_ADP_ATTACHED	(1 << 19)
+#define	V_ADP_DAC8	(1 << 20)
+#define	V_ADP_CWIDTH9	(1 << 21)
+    vm_offset_t		va_io_base;
+    int			va_io_size;
+    vm_offset_t		va_crtc_addr;
+    vm_offset_t		va_mem_base;
+    int			va_mem_size;
+    vm_offset_t		va_window;	/* virtual address */
+    size_t		va_window_size;
+    size_t		va_window_gran;
+    u_int		va_window_orig;
+    vm_offset_t		va_buffer;	/* virtual address */
+    size_t		va_buffer_size;
+    int			va_initial_mode;
+    int			va_initial_bios_mode;
+    int			va_mode;
+    struct video_info	va_info;
+    int			va_line_width;
+    struct {
+	int		x;
+	int		y;
+    } 			va_disp_start;
+    void		*va_token;
+    int			va_model;
+    int			va_little_bitian;
+    int			va_little_endian;
+    int			va_buffer_alias;
+    vm_offset_t		va_registers;	/* virtual address */
+    vm_offset_t		va_registers_size;
+typedef struct video_adapter video_adapter_t;
+struct video_adapter_info {
+    int			va_index;
+    int			va_type;
+    char		va_name[16];
+    int			va_unit;
+    int			va_flags;
+    int			va_io_size;
+    int			va_mem_size;
+    vm_offset_t		va_unused0;
+    int			va_mode;
+    struct {
+	int		x;
+	int		y;
+    } 			va_disp_start;
+    /* reserved */
+    u_char		va_reserved[64];
+typedef struct video_adapter_info video_adapter_info_t;
+/* some useful video adapter index */
+#define V_ADP_PRIMARY	0
+#define V_ADP_SECONDARY	1
+/* video mode numbers */
+#define M_B40x25	0	/* black & white 40 columns */
+#define M_C40x25	1	/* color 40 columns */
+#define M_B80x25	2	/* black & white 80 columns */
+#define M_C80x25	3	/* color 80 columns */
+#define M_BG320		4	/* black & white graphics 320x200 */
+#define M_CG320		5	/* color graphics 320x200 */
+#define M_BG640		6	/* black & white graphics 640x200 hi-res */
+#define M_EGAMONO80x25  7       /* ega-mono 80x25 */
+#define M_CG320_D	13	/* ega mode D */
+#define M_CG640_E	14	/* ega mode E */
+#define M_EGAMONOAPA	15	/* ega mode F */
+#define M_CG640x350	16	/* ega mode 10 */
+#define M_ENHMONOAPA2	17	/* ega mode F with extended memory */
+#define M_ENH_CG640	18	/* ega mode 10* */
+#define M_ENH_B40x25    19      /* ega enhanced black & white 40 columns */
+#define M_ENH_C40x25    20      /* ega enhanced color 40 columns */
+#define M_ENH_B80x25    21      /* ega enhanced black & white 80 columns */
+#define M_ENH_C80x25    22      /* ega enhanced color 80 columns */
+#define M_VGA_C40x25	23	/* vga 8x16 font on color */
+#define M_VGA_C80x25	24	/* vga 8x16 font on color */
+#define M_VGA_M80x25	25	/* vga 8x16 font on mono */
+#define M_VGA11		26	/* vga 640x480 2 colors */
+#define M_BG640x480	26
+#define M_VGA12		27	/* vga 640x480 16 colors */
+#define M_CG640x480	27
+#define M_VGA13		28	/* vga 320x200 256 colors */
+#define M_VGA_CG320	28
+#define M_VGA_C80x50	30	/* vga 8x8 font on color */
+#define M_VGA_M80x50	31	/* vga 8x8 font on color */
+#define M_VGA_C80x30	32	/* vga 8x16 font on color */
+#define M_VGA_M80x30	33	/* vga 8x16 font on color */
+#define M_VGA_C80x60	34	/* vga 8x8 font on color */
+#define M_VGA_M80x60	35	/* vga 8x8 font on color */
+#define M_VGA_CG640	36	/* vga 640x400 256 color */
+#define M_VGA_MODEX	37	/* vga 320x240 256 color */
+#define M_VGA_C90x25	40	/* vga 8x16 font on color */
+#define M_VGA_M90x25	41	/* vga 8x16 font on mono */
+#define M_VGA_C90x30	42	/* vga 8x16 font on color */
+#define M_VGA_M90x30	43	/* vga 8x16 font on mono */
+#define M_VGA_C90x43	44	/* vga 8x8 font on color */
+#define M_VGA_M90x43	45	/* vga 8x8 font on mono */
+#define M_VGA_C90x50	46	/* vga 8x8 font on color */
+#define M_VGA_M90x50	47	/* vga 8x8 font on mono */
+#define M_VGA_C90x60	48	/* vga 8x8 font on color */
+#define M_VGA_M90x60	49	/* vga 8x8 font on mono */
+#define M_ENH_B80x43	0x70	/* ega black & white 80x43 */
+#define M_ENH_C80x43	0x71	/* ega color 80x43 */
+#define M_HGC_P0	0xe0	/* hercules graphics - page 0 @ B0000 */
+#define M_HGC_P1	0xe1	/* hercules graphics - page 1 @ B8000 */
+#define M_MCA_MODE	0xff	/* monochrome adapter mode */
+#define M_TEXT_80x25	200	/* generic text modes */
+#define M_TEXT_80x30	201
+#define M_TEXT_80x43	202
+#define M_TEXT_80x50	203
+#define M_TEXT_80x60	204
+#define M_TEXT_132x25	205
+#define M_TEXT_132x30	206
+#define M_TEXT_132x43	207
+#define M_TEXT_132x50	208
+#define M_TEXT_132x60	209
+#define M_VESA_BASE		0x100	/* VESA mode number base */
+#define M_VESA_CG640x400	0x100	/* 640x400, 256 color */
+#define M_VESA_CG640x480	0x101	/* 640x480, 256 color */
+#define M_VESA_800x600		0x102	/* 800x600, 16 color */
+#define M_VESA_CG800x600	0x103	/* 800x600, 256 color */
+#define M_VESA_1024x768		0x104	/* 1024x768, 16 color */
+#define M_VESA_CG1024x768	0x105	/* 1024x768, 256 color */
+#define M_VESA_1280x1024	0x106	/* 1280x1024, 16 color */
+#define M_VESA_CG1280x1024	0x107	/* 1280x1024, 256 color */
+#define M_VESA_C80x60		0x108	/* 8x8 font */
+#define M_VESA_C132x25		0x109	/* 8x16 font */
+#define M_VESA_C132x43		0x10a	/* 8x14 font */
+#define M_VESA_C132x50		0x10b	/* 8x8 font */
+#define M_VESA_C132x60		0x10c	/* 8x8 font */
+#define M_VESA_32K_320		0x10d	/* 320x200, 5:5:5 */
+#define M_VESA_64K_320		0x10e	/* 320x200, 5:6:5 */
+#define M_VESA_FULL_320		0x10f	/* 320x200, 8:8:8 */
+#define M_VESA_32K_640		0x110	/* 640x480, 5:5:5 */
+#define M_VESA_64K_640		0x111	/* 640x480, 5:6:5 */
+#define M_VESA_FULL_640		0x112	/* 640x480, 8:8:8 */
+#define M_VESA_32K_800		0x113	/* 800x600, 5:5:5 */
+#define M_VESA_64K_800		0x114	/* 800x600, 5:6:5 */
+#define M_VESA_FULL_800		0x115	/* 800x600, 8:8:8 */
+#define M_VESA_32K_1024		0x116	/* 1024x768, 5:5:5 */
+#define M_VESA_64K_1024		0x117	/* 1024x768, 5:6:5 */
+#define M_VESA_FULL_1024	0x118	/* 1024x768, 8:8:8 */
+#define M_VESA_32K_1280		0x119	/* 1280x1024, 5:5:5 */
+#define M_VESA_64K_1280		0x11a	/* 1280x1024, 5:6:5 */
+#define M_VESA_FULL_1280	0x11b	/* 1280x1024, 8:8:8 */
+#define M_VESA_MODE_MAX		0x1ff
+struct video_display_start {
+	int		x;
+	int		y;
+typedef struct video_display_start video_display_start_t;
+struct video_color_palette {
+	int		index;		/* first element (zero-based) */
+	u_char		*red;		/* red */
+	u_char		*green;		/* green */
+	u_char		*blue;		/* blue */
+	u_char		*transparent;	/* may be NULL */
+typedef struct video_color_palette video_color_palette_t;
+/* adapter info. */
+#define FBIO_ADAPTER	_IOR('F', 100, int)
+#define FBIO_ADPTYPE	_IOR('F', 101, int)
+#define FBIO_ADPINFO	_IOR('F', 102, struct video_adapter_info)
+/* video mode control */
+#define FBIO_MODEINFO	_IOWR('F', 103, struct video_info)
+#define FBIO_FINDMODE	_IOWR('F', 104, struct video_info)
+#define FBIO_GETMODE	_IOR('F', 105, int)
+#define FBIO_SETMODE	_IOW('F', 106, int)
+/* get/set frame buffer window origin */
+#define FBIO_GETWINORG	_IOR('F', 107, u_int)
+#define FBIO_SETWINORG	_IOW('F', 108, u_int)
+/* get/set display start address */
+#define FBIO_GETDISPSTART	_IOR('F', 109, video_display_start_t)
+#define FBIO_SETDISPSTART	_IOW('F', 110, video_display_start_t)
+/* get/set scan line width */
+#define FBIO_GETLINEWIDTH	_IOR('F', 111, u_int)
+#define FBIO_SETLINEWIDTH	_IOW('F', 112, u_int)
+/* color palette control */
+#define FBIO_GETPALETTE	_IOW('F', 113, video_color_palette_t)
+#define FBIO_SETPALETTE	_IOW('F', 114, video_color_palette_t)
+/* blank display */
+#define V_DISPLAY_ON		0
+#define V_DISPLAY_BLANK		1
+#define V_DISPLAY_STAND_BY	2
+#define V_DISPLAY_SUSPEND	3
+#define FBIO_BLANK	_IOW('F', 115, int)
+#endif /* !_SYS_FBIO_H_ */
diff --git a/freebsd/sys/sys/terminal.h b/freebsd/sys/sys/terminal.h
index 00000000..e3413a79
--- /dev/null
+++ b/freebsd/sys/sys/terminal.h
@@ -0,0 +1,240 @@
+ * Copyright (c) 2009 The FreeBSD Foundation
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _SYS_TERMINAL_H_
+#define	_SYS_TERMINAL_H_
+#include <sys/_lock.h>
+#include <sys/_mutex.h>
+#include <sys/cons.h>
+#include <sys/linker_set.h>
+#include <sys/ttycom.h>
+#include <teken/teken.h>
+#include <rtems/bsd/local/opt_teken.h>
+struct terminal;
+struct thread;
+struct tty;
+ * The terminal layer is an abstraction on top of the TTY layer and the
+ * console interface.  It can be used by system console drivers to
+ * easily interact with the kernel console and TTYs.
+ * Terminals contain terminal emulators, which means console drivers
+ * don't need to implement their own terminal emulator. The terminal
+ * emulator deals with UTF-8 exclusively. This means that term_char_t,
+ * the data type used to store input/output characters will always
+ * contain Unicode codepoints.
+ * To save memory usage, the top bits of term_char_t will contain other
+ * attributes, like colors. Right now term_char_t is composed as
+ * follows:
+ *  Bits  Meaning
+ *  0-20: Character value
+ * 21-25: Bold, underline, blink, reverse, right part of CJK fullwidth character
+ * 26-28: Foreground color
+ * 29-31: Background color
+typedef uint32_t term_char_t;
+#define	TCHAR_CHARACTER(c)	((c) & 0x1fffff)
+#define	TCHAR_FORMAT(c)		(((c) >> 21) & 0x1f)
+#define	TCHAR_FGCOLOR(c)	(((c) >> 26) & 0x7)
+#define	TCHAR_BGCOLOR(c)	(((c) >> 29) & 0x7)
+typedef teken_attr_t term_attr_t;
+typedef teken_color_t term_color_t;
+#define	TCOLOR_FG(c)	(((c) & 0x7) << 26)
+#define	TCOLOR_BG(c)	(((c) & 0x7) << 29)
+#define	TCOLOR_LIGHT(c)	((c) | 0x8)
+#define	TCOLOR_DARK(c)	((c) & ~0x8)
+#define	TFORMAT(c)	(((c) & 0x1f) << 21)
+/* syscons(4) compatible color attributes for foreground text */
+#define	FG_BLACK		TCOLOR_FG(TC_BLACK)
+#define	FG_BLUE			TCOLOR_FG(TC_BLUE)
+#define	FG_GREEN		TCOLOR_FG(TC_GREEN)
+#define	FG_CYAN			TCOLOR_FG(TC_CYAN)
+#define	FG_RED			TCOLOR_FG(TC_RED)
+#define	FG_MAGENTA		TCOLOR_FG(TC_MAGENTA)
+#define	FG_BROWN		TCOLOR_FG(TC_BROWN)
+#define	FG_LIGHTGREY		TCOLOR_FG(TC_WHITE)
+#define	FG_DARKGREY		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_BLACK))
+#define	FG_LIGHTBLUE		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_BLUE))
+#define	FG_LIGHTGREEN		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_GREEN))
+#define	FG_LIGHTCYAN		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_CYAN))
+#define	FG_LIGHTRED		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_RED))
+#define	FG_LIGHTMAGENTA		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_MAGENTA))
+#define	FG_YELLOW		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_BROWN))
+#define	FG_WHITE		(TFORMAT(TF_BOLD) | TCOLOR_FG(TC_WHITE))
+#define	FG_BLINK		TFORMAT(TF_BLINK)
+/* syscons(4) compatible color attributes for text background */
+#define	BG_BLACK		TCOLOR_BG(TC_BLACK)
+#define	BG_BLUE			TCOLOR_BG(TC_BLUE)
+#define	BG_GREEN		TCOLOR_BG(TC_GREEN)
+#define	BG_CYAN			TCOLOR_BG(TC_CYAN)
+#define	BG_RED			TCOLOR_BG(TC_RED)
+#define	BG_MAGENTA		TCOLOR_BG(TC_MAGENTA)
+#define	BG_BROWN		TCOLOR_BG(TC_BROWN)
+#define	BG_LIGHTGREY		TCOLOR_BG(TC_WHITE)
+#define	BG_DARKGREY		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_BLACK))
+#define	BG_LIGHTBLUE		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_BLUE))
+#define	BG_LIGHTGREEN		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_GREEN))
+#define	BG_LIGHTCYAN		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_CYAN))
+#define	BG_LIGHTRED		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_RED))
+#define	BG_LIGHTMAGENTA		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_MAGENTA))
+#define	BG_YELLOW		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_BROWN))
+#define	BG_WHITE		(TFORMAT(TF_BOLD) | TCOLOR_BG(TC_WHITE))
+#ifndef TERMINAL_NORM_ATTR
+#ifdef SC_NORM_ATTR
+#define	TERMINAL_NORM_ATTR	SC_NORM_ATTR
+#else
+#define	TERMINAL_NORM_ATTR	(FG_LIGHTGREY | BG_BLACK)
+#endif
+#endif
+#ifndef TERMINAL_KERN_ATTR
+#ifdef SC_KERNEL_CONS_ATTR
+#define	TERMINAL_KERN_ATTR	SC_KERNEL_CONS_ATTR
+#else
+#define	TERMINAL_KERN_ATTR	(FG_WHITE | BG_BLACK)
+#endif
+#endif
+typedef teken_pos_t term_pos_t;
+typedef teken_rect_t term_rect_t;
+typedef void tc_cursor_t(struct terminal *tm, const term_pos_t *p);
+typedef void tc_putchar_t(struct terminal *tm, const term_pos_t *p,
+    term_char_t c);
+typedef void tc_fill_t(struct terminal *tm, const term_rect_t *r,
+    term_char_t c);
+typedef void tc_copy_t(struct terminal *tm, const term_rect_t *r,
+    const term_pos_t *p);
+typedef void tc_pre_input_t(struct terminal *tm);
+typedef void tc_post_input_t(struct terminal *tm);
+typedef void tc_param_t(struct terminal *tm, int cmd, unsigned int arg);
+typedef void tc_done_t(struct terminal *tm);
+typedef void tc_cnprobe_t(struct terminal *tm, struct consdev *cd);
+typedef int tc_cngetc_t(struct terminal *tm);
+typedef void tc_cngrab_t(struct terminal *tm);
+typedef void tc_cnungrab_t(struct terminal *tm);
+typedef void tc_opened_t(struct terminal *tm, int opened);
+typedef int tc_ioctl_t(struct terminal *tm, u_long cmd, caddr_t data,
+typedef int tc_mmap_t(struct terminal *tm, vm_ooffset_t offset,
+    vm_paddr_t * paddr, int nprot, vm_memattr_t *memattr);
+typedef void tc_bell_t(struct terminal *tm);
+struct terminal_class {
+	/* Terminal emulator. */
+	tc_cursor_t	*tc_cursor;
+	tc_putchar_t	*tc_putchar;
+	tc_fill_t	*tc_fill;
+	tc_copy_t	*tc_copy;
+	tc_pre_input_t	*tc_pre_input;
+	tc_post_input_t	*tc_post_input;
+	tc_param_t	*tc_param;
+	tc_done_t	*tc_done;
+	/* Low-level console interface. */
+	tc_cnprobe_t	*tc_cnprobe;
+	tc_cngetc_t	*tc_cngetc;
+	/* DDB & panic handling. */
+	tc_cngrab_t	*tc_cngrab;
+	tc_cnungrab_t	*tc_cnungrab;
+	/* Misc. */
+	tc_opened_t	*tc_opened;
+	tc_ioctl_t	*tc_ioctl;
+	tc_mmap_t	*tc_mmap;
+	tc_bell_t	*tc_bell;
+struct terminal {
+	const struct terminal_class *tm_class;
+	void		*tm_softc;
+	struct mtx	 tm_mtx;
+	struct tty	*tm_tty;
+	teken_t		 tm_emulator;
+	struct winsize	 tm_winsize;
+	unsigned int	 tm_flags;
+#define	TF_MUTE		0x1	/* Drop incoming data. */
+#define	TF_BELL		0x2	/* Bell needs to be sent. */
+#define	TF_CONS		0x4	/* Console device (needs spinlock). */
+	struct consdev	*consdev;
+#ifdef _KERNEL
+struct terminal *terminal_alloc(const struct terminal_class *tc, void *softc);
+void	terminal_maketty(struct terminal *tm, const char *fmt, ...);
+void	terminal_set_cursor(struct terminal *tm, const term_pos_t *pos);
+void	terminal_set_winsize_blank(struct terminal *tm,
+    const struct winsize *size, int blank, const term_attr_t *attr);
+void	terminal_set_winsize(struct terminal *tm, const struct winsize *size);
+void	terminal_mute(struct terminal *tm, int yes);
+void	terminal_input_char(struct terminal *tm, term_char_t c);
+void	terminal_input_raw(struct terminal *tm, char c);
+void	terminal_input_special(struct terminal *tm, unsigned int k);
+void	termcn_cnregister(struct terminal *tm);
+/* Kernel console helper interface. */
+extern const struct consdev_ops termcn_cnops;
+#define	TERMINAL_DECLARE_EARLY(name, class, softc)			\
+	static struct terminal name = {					\
+		.tm_class = &class,					\
+		.tm_softc = softc,					\
+		.tm_flags = TF_CONS,					\
+	CONSOLE_DEVICE(name ## _consdev, termcn_cnops, &name)
+#endif /* _KERNEL */
+#endif /* !_SYS_TERMINAL_H_ */
diff --git a/freebsd/sys/teken/teken.h b/freebsd/sys/teken/teken.h
index 00000000..0a3928a9
--- /dev/null
+++ b/freebsd/sys/teken/teken.h
@@ -0,0 +1,221 @@
+ * Copyright (c) 2008-2009 Ed Schouten <ed at FreeBSD.org>
+ * are met:
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _TEKEN_H_
+#define	_TEKEN_H_
+ * libteken: terminal emulation library.
+ * This library converts an UTF-8 stream of bytes to terminal drawing
+ * commands.
+typedef uint32_t teken_char_t;
+typedef unsigned short teken_unit_t;
+typedef unsigned char teken_format_t;
+#define	TF_BOLD		0x01	/* Bold character. */
+#define	TF_UNDERLINE	0x02	/* Underline character. */
+#define	TF_BLINK	0x04	/* Blinking character. */
+#define	TF_REVERSE	0x08	/* Reverse rendered character. */
+#define	TF_CJK_RIGHT	0x10	/* Right-hand side of CJK character. */
+typedef unsigned char teken_color_t;
+#define	TC_BLACK	0
+#define	TC_RED		1
+#define	TC_GREEN	2
+#define	TC_BROWN	3
+#define	TC_BLUE		4
+#define	TC_MAGENTA	5
+#define	TC_CYAN		6
+#define	TC_WHITE	7
+#define	TC_NCOLORS	8
+#define	TC_LIGHT	8	/* ORed with the others. */
+typedef struct {
+	teken_unit_t	tp_row;
+	teken_unit_t	tp_col;
+} teken_pos_t;
+typedef struct {
+	teken_pos_t	tr_begin;
+	teken_pos_t	tr_end;
+} teken_rect_t;
+typedef struct {
+	teken_format_t	ta_format;
+	teken_color_t	ta_fgcolor;
+	teken_color_t	ta_bgcolor;
+} teken_attr_t;
+typedef struct {
+	teken_unit_t	ts_begin;
+	teken_unit_t	ts_end;
+} teken_span_t;
+typedef struct __teken teken_t;
+typedef void teken_state_t(teken_t *, teken_char_t);
+ * Drawing routines supplied by the user.
+typedef void tf_bell_t(void *);
+typedef void tf_cursor_t(void *, const teken_pos_t *);
+typedef void tf_putchar_t(void *, const teken_pos_t *, teken_char_t,
+    const teken_attr_t *);
+typedef void tf_fill_t(void *, const teken_rect_t *, teken_char_t,
+typedef void tf_copy_t(void *, const teken_rect_t *, const teken_pos_t *);
+typedef void tf_pre_input_t(void *);
+typedef void tf_post_input_t(void *);
+typedef void tf_param_t(void *, int, unsigned int);
+#define	TP_SHOWCURSOR	0
+#define	TP_KEYPADAPP	1
+#define	TP_AUTOREPEAT	2
+#define	TP_SWITCHVT	3
+#define	TP_132COLS	4
+#define	TP_SETBELLPD	5
+#define	TP_SETBELLPD_PITCH(pd)		((pd) >> 16)
+#define	TP_SETBELLPD_DURATION(pd)	((pd) & 0xffff)
+#define	TP_MOUSE	6
+#define	TP_SETBORDER	7
+#define	TP_SETLOCALCURSOR	8
+#define	TP_SETGLOBALCURSOR	9
+typedef void tf_respond_t(void *, const void *, size_t);
+typedef struct {
+	tf_bell_t	*tf_bell;
+	tf_cursor_t	*tf_cursor;
+	tf_putchar_t	*tf_putchar;
+	tf_fill_t	*tf_fill;
+	tf_copy_t	*tf_copy;
+	tf_pre_input_t	*tf_pre_input;
+	tf_post_input_t	*tf_post_input;
+	tf_param_t	*tf_param;
+	tf_respond_t	*tf_respond;
+} teken_funcs_t;
+typedef teken_char_t teken_scs_t(const teken_t *, teken_char_t);
+ * Terminal state.
+struct __teken {
+	const teken_funcs_t *t_funcs;
+	void		*t_softc;
+	teken_state_t	*t_nextstate;
+	unsigned int	 t_stateflags;
+#define T_NUMSIZE	8
+	unsigned int	 t_nums[T_NUMSIZE];
+	unsigned int	 t_curnum;
+	teken_pos_t	 t_cursor;
+	teken_attr_t	 t_curattr;
+	teken_pos_t	 t_saved_cursor;
+	teken_attr_t	 t_saved_curattr;
+	teken_attr_t	 t_defattr;
+	teken_pos_t	 t_winsize;
+	/* For DECSTBM. */
+	teken_span_t	 t_scrollreg;
+	/* For DECOM. */
+	teken_span_t	 t_originreg;
+#define	T_NUMCOL	160
+	unsigned int	 t_tabstops[T_NUMCOL / (sizeof(unsigned int) * 8)];
+	unsigned int	 t_utf8_left;
+	teken_char_t	 t_utf8_partial;
+	teken_char_t	 t_last;
+	unsigned int	 t_curscs;
+	teken_scs_t	*t_saved_curscs;
+	teken_scs_t	*t_scs[2];
+/* Initialize teken structure. */
+void	teken_init(teken_t *, const teken_funcs_t *, void *);
+/* Deliver character input. */
+void	teken_input(teken_t *, const void *, size_t);
+/* Get/set teken attributes. */
+const teken_pos_t *teken_get_cursor(const teken_t *);
+const teken_attr_t *teken_get_curattr(const teken_t *);
+const teken_attr_t *teken_get_defattr(const teken_t *);
+void	teken_get_defattr_cons25(const teken_t *, int *, int *);
+const teken_pos_t *teken_get_winsize(const teken_t *);
+void	teken_set_cursor(teken_t *, const teken_pos_t *);
+void	teken_set_curattr(teken_t *, const teken_attr_t *);
+void	teken_set_defattr(teken_t *, const teken_attr_t *);
+void	teken_set_winsize(teken_t *, const teken_pos_t *);
+void	teken_set_winsize_noreset(teken_t *, const teken_pos_t *);
+/* Key input escape sequences. */
+#define	TKEY_UP		0x00
+#define	TKEY_DOWN	0x01
+#define	TKEY_LEFT	0x02
+#define	TKEY_RIGHT	0x03
+#define	TKEY_HOME	0x04
+#define	TKEY_END	0x05
+#define	TKEY_INSERT	0x06
+#define	TKEY_DELETE	0x07
+#define	TKEY_PAGE_UP	0x08
+#define	TKEY_PAGE_DOWN	0x09
+#define	TKEY_F1		0x0a
+#define	TKEY_F2		0x0b
+#define	TKEY_F3		0x0c
+#define	TKEY_F4		0x0d
+#define	TKEY_F5		0x0e
+#define	TKEY_F6		0x0f
+#define	TKEY_F7		0x10
+#define	TKEY_F8		0x11
+#define	TKEY_F9		0x12
+#define	TKEY_F10	0x13
+#define	TKEY_F11	0x14
+#define	TKEY_F12	0x15
+const char *teken_get_sequence(const teken_t *, unsigned int);
+/* Legacy features. */
+void	teken_set_8bit(teken_t *);
+void	teken_set_cons25(teken_t *);
+void	teken_set_cons25keys(teken_t *);
+/* Color conversion. */
+teken_color_t teken_256to16(teken_color_t);
+teken_color_t teken_256to8(teken_color_t);
+#endif /* !_TEKEN_H_ */
2.20.1
