[PATCH 06/10] fbd : Port to RTEMS
Vijay Kumar Banerjee vijaykumar9597 at gmail.com
Fri Jul 26 11:22:52 UTC 2019
 freebsd/sys/dev/fb/fbd.c                      |  3 ++
 libbsd.py                                     |  4 +++
 rtemsbsd/include/bsp/nexus-devices.h          |  3 ++
 .../machine/rtems-bsd-kernel-namespace.h      | 35 +++++++++++++++++++
 rtemsbsd/include/rtems/bsd/local/opt_fb.h     |  0
 5 files changed, 45 insertions(+)
 create mode 100644 rtemsbsd/include/rtems/bsd/local/opt_fb.h
diff --git a/freebsd/sys/dev/fb/fbd.c b/freebsd/sys/dev/fb/fbd.c
index 60ce4bc3..33cdc348 100644
--- a/freebsd/sys/dev/fb/fbd.c
+++ b/freebsd/sys/dev/fb/fbd.c
@@ -59,6 +59,9 @@ __FBSDID("$FreeBSD$");
 #include <vm/pmap.h>
 #include <rtems/bsd/local/fb_if.h>
+#ifdef __rtems__
+#define vtophys(a) (a)
+#endif /* __rtems__ */
 LIST_HEAD(fb_list_head_t, fb_list_entry) fb_list_head =
     LIST_HEAD_INITIALIZER(fb_list_head);
diff --git a/libbsd.py b/libbsd.py
index 4808105b..71eb3577 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -807,6 +807,8 @@ class display(builder.Module):
                 'sys/sys/fbio.h',
                 'sys/sys/consio.h',
                 'sys/sys/terminal.h',
+                'sys/dev/vt/hw/fb/vt_fb.h',
+                'sys/dev/vt/colors/vt_termcolors.h',
         self.addKernelSpaceSourceFiles(
@@ -821,6 +823,8 @@ class display(builder.Module):
                 'sys/arm/ti/am335x/am335x_lcd.c',
                 'sys/arm/ti/am335x/am335x_pwmss.c',
                 'sys/arm/ti/am335x/am335x_ecap.c',
+                'sys/dev/fb/fb.c',
+                'sys/dev/fb/fbd.c',
             mm.generator['source']()
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index 2c718295..313c40d4 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -68,6 +68,9 @@ SYSINIT_DRIVER_REFERENCE(ofw_iicbus, rtems_i2c);
 SYSINIT_DRIVER_REFERENCE(iic, iicbus);
 SYSINIT_DRIVER_REFERENCE(tda, iicbus);
 SYSINIT_DRIVER_REFERENCE(iicbus, rtems_i2c);
+SYSINIT_DRIVER_REFERENCE(fbd, fb);
+SYSINIT_DRIVER_REFERENCE(fb, fb_mod);
+SYSINIT_MODULE_REFERENCE(fb_mod);
 #ifdef RTEMS_BSD_MODULE_NET80211
 SYSINIT_DRIVER_REFERENCE(rtwn_usb, uhub);
 SYSINIT_MODULE_REFERENCE(wlan_ratectl_none);
diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
index 3951da79..d796d3d1 100644
--- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
+++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
@@ -1266,6 +1266,16 @@
 #define	eventhandler_find_list _bsd_eventhandler_find_list
 #define	eventhandler_prune_list _bsd_eventhandler_prune_list
 #define	eventhandler_register _bsd_eventhandler_register
+#define	fb_commonioctl _bsd_fb_commonioctl
+#define	fbd_devclass _bsd_fbd_devclass
+#define	fbd_driver _bsd_fbd_driver
+#define	fbd_list _bsd_fbd_list
+#define	fbd_register _bsd_fbd_register
+#define	fb_dump_adp_info _bsd_fb_dump_adp_info
+#define	fb_dump_mode_info _bsd_fb_dump_mode_info
+#define	fbd_unregister _bsd_fbd_unregister
+#define	fb_list_head _bsd_fb_list_head
+#define	fb_type _bsd_fb_type
 #define	fdt_addrsize_cells _bsd_fdt_addrsize_cells
 #define	fdt_data_get _bsd_fdt_data_get
 #define	fdt_data_to_res _bsd_fdt_data_to_res
@@ -5515,8 +5525,18 @@
 #define	vht80_chan_ranges _bsd_vht80_chan_ranges
 #define	vesagtf_mode _bsd_vesagtf_mode
 #define	vesagtf_mode_params _bsd_vesagtf_mode_params
+#define	vid_allocate _bsd_vid_allocate
+#define	vid_configure _bsd_vid_configure
 #define	videomode_count _bsd_videomode_count
 #define	videomode_list _bsd_videomode_list
+#define	vid_find_adapter _bsd_vid_find_adapter
+#define	vid_get_adapter _bsd_vid_get_adapter
+#define	vid_get_switch _bsd_vid_get_switch
+#define	vid_init_struct _bsd_vid_init_struct
+#define	vid_register _bsd_vid_register
+#define	vid_release _bsd_vid_release
+#define	vidsw _bsd_vidsw
+#define	vid_unregister _bsd_vid_unregister
 #define	vlan_cookie_p _bsd_vlan_cookie_p
 #define	vlan_devat_p _bsd_vlan_devat_p
 #define	vlan_input_p _bsd_vlan_input_p
@@ -5533,6 +5553,21 @@
 #define	vsnprintf _bsd_vsnprintf
 #define	vsnrprintf _bsd_vsnrprintf
 #define	vsprintf _bsd_vsprintf
+#define	vt_fb_attach _bsd_vt_fb_attach
+#define	vt_fb_bitblt_bitmap _bsd_vt_fb_bitblt_bitmap
+#define	vt_fb_bitblt_text _bsd_vt_fb_bitblt_text
+#define	vt_fb_blank _bsd_vt_fb_blank
+#define	vt_fb_detach _bsd_vt_fb_detach
+#define	vt_fb_drawrect _bsd_vt_fb_drawrect
+#define	vt_fb_fini _bsd_vt_fb_fini
+#define	vt_fb_init _bsd_vt_fb_init
+#define	vt_fb_invalidate_text _bsd_vt_fb_invalidate_text
+#define	vt_fb_ioctl _bsd_vt_fb_ioctl
+#define	vt_fb_mmap _bsd_vt_fb_mmap
+#define	vt_fb_postswitch _bsd_vt_fb_postswitch
+#define	vt_fb_resume _bsd_vt_fb_resume
+#define	vt_fb_setpixel _bsd_vt_fb_setpixel
+#define	vt_fb_suspend _bsd_vt_fb_suspend
 #define	wakeup _bsd_wakeup
 #define	wakeup_one _bsd_wakeup_one
 #define	window_deflate _bsd_window_deflate
diff --git a/rtemsbsd/include/rtems/bsd/local/opt_fb.h b/rtemsbsd/include/rtems/bsd/local/opt_fb.h
new file mode 100644
index 00000000..e69de29b
2.20.1
