[PATCH 06/10] fbd : Port to RTEMS
Christian Mauderer list at c-mauderer.de
Sat Jul 27 13:15:57 UTC 2019
On 26/07/2019 13:22, Vijay Kumar Banerjee wrote:
>  freebsd/sys/dev/fb/fbd.c                      |  3 ++
>  libbsd.py                                     |  4 +++
>  rtemsbsd/include/bsp/nexus-devices.h          |  3 ++
>  .../machine/rtems-bsd-kernel-namespace.h      | 35 +++++++++++++++++++
>  rtemsbsd/include/rtems/bsd/local/opt_fb.h     |  0
>  5 files changed, 45 insertions(+)
>  create mode 100644 rtemsbsd/include/rtems/bsd/local/opt_fb.h
> diff --git a/freebsd/sys/dev/fb/fbd.c b/freebsd/sys/dev/fb/fbd.c
> index 60ce4bc3..33cdc348 100644
> --- a/freebsd/sys/dev/fb/fbd.c
> +++ b/freebsd/sys/dev/fb/fbd.c
> @@ -59,6 +59,9 @@ __FBSDID("$FreeBSD$");
>  #include <vm/pmap.h>
>  #include <rtems/bsd/local/fb_if.h>
> +#ifdef __rtems__
> +#define vtophys(a) (a)
> +#endif /* __rtems__ */
That seems to be already defined in rtemsbsd/include/machine/vm.h which
should be included via <vm/vm.h>. Why is it necessary?
>  LIST_HEAD(fb_list_head_t, fb_list_entry) fb_list_head =
>      LIST_HEAD_INITIALIZER(fb_list_head);
> diff --git a/libbsd.py b/libbsd.py
> index 4808105b..71eb3577 100644
> --- a/libbsd.py
> +++ b/libbsd.py
> @@ -807,6 +807,8 @@ class display(builder.Module):
>                  'sys/sys/fbio.h',
>                  'sys/sys/consio.h',
>                  'sys/sys/terminal.h',
> +                'sys/dev/vt/hw/fb/vt_fb.h',
> +                'sys/dev/vt/colors/vt_termcolors.h',
>          self.addKernelSpaceSourceFiles(
> @@ -821,6 +823,8 @@ class display(builder.Module):
>                  'sys/arm/ti/am335x/am335x_lcd.c',
>                  'sys/arm/ti/am335x/am335x_pwmss.c',
>                  'sys/arm/ti/am335x/am335x_ecap.c',
> +                'sys/dev/fb/fb.c',
> +                'sys/dev/fb/fbd.c',
>              mm.generator['source']()
> diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
> index 2c718295..313c40d4 100644
> --- a/rtemsbsd/include/bsp/nexus-devices.h
> +++ b/rtemsbsd/include/bsp/nexus-devices.h
> @@ -68,6 +68,9 @@ SYSINIT_DRIVER_REFERENCE(ofw_iicbus, rtems_i2c);
>  SYSINIT_DRIVER_REFERENCE(iic, iicbus);
>  SYSINIT_DRIVER_REFERENCE(tda, iicbus);
>  SYSINIT_DRIVER_REFERENCE(iicbus, rtems_i2c);
> +SYSINIT_DRIVER_REFERENCE(fbd, fb);
> +SYSINIT_DRIVER_REFERENCE(fb, fb_mod);
> +SYSINIT_MODULE_REFERENCE(fb_mod);
>  #ifdef RTEMS_BSD_MODULE_NET80211
>  SYSINIT_DRIVER_REFERENCE(rtwn_usb, uhub);
>  SYSINIT_MODULE_REFERENCE(wlan_ratectl_none);
> diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> index 3951da79..d796d3d1 100644
> --- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> +++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
> @@ -1266,6 +1266,16 @@
>  #define	eventhandler_find_list _bsd_eventhandler_find_list
>  #define	eventhandler_prune_list _bsd_eventhandler_prune_list
>  #define	eventhandler_register _bsd_eventhandler_register
> +#define	fb_commonioctl _bsd_fb_commonioctl
> +#define	fbd_devclass _bsd_fbd_devclass
> +#define	fbd_driver _bsd_fbd_driver
> +#define	fbd_list _bsd_fbd_list
> +#define	fbd_register _bsd_fbd_register
> +#define	fb_dump_adp_info _bsd_fb_dump_adp_info
> +#define	fb_dump_mode_info _bsd_fb_dump_mode_info
> +#define	fbd_unregister _bsd_fbd_unregister
> +#define	fb_list_head _bsd_fb_list_head
> +#define	fb_type _bsd_fb_type
>  #define	fdt_addrsize_cells _bsd_fdt_addrsize_cells
>  #define	fdt_data_get _bsd_fdt_data_get
>  #define	fdt_data_to_res _bsd_fdt_data_to_res
> @@ -5515,8 +5525,18 @@
>  #define	vht80_chan_ranges _bsd_vht80_chan_ranges
>  #define	vesagtf_mode _bsd_vesagtf_mode
>  #define	vesagtf_mode_params _bsd_vesagtf_mode_params
> +#define	vid_allocate _bsd_vid_allocate
> +#define	vid_configure _bsd_vid_configure
>  #define	videomode_count _bsd_videomode_count
>  #define	videomode_list _bsd_videomode_list
> +#define	vid_find_adapter _bsd_vid_find_adapter
> +#define	vid_get_adapter _bsd_vid_get_adapter
> +#define	vid_get_switch _bsd_vid_get_switch
> +#define	vid_init_struct _bsd_vid_init_struct
> +#define	vid_register _bsd_vid_register
> +#define	vid_release _bsd_vid_release
> +#define	vidsw _bsd_vidsw
> +#define	vid_unregister _bsd_vid_unregister
>  #define	vlan_cookie_p _bsd_vlan_cookie_p
>  #define	vlan_devat_p _bsd_vlan_devat_p
>  #define	vlan_input_p _bsd_vlan_input_p
> @@ -5533,6 +5553,21 @@
>  #define	vsnprintf _bsd_vsnprintf
>  #define	vsnrprintf _bsd_vsnrprintf
>  #define	vsprintf _bsd_vsprintf
> +#define	vt_fb_attach _bsd_vt_fb_attach
> +#define	vt_fb_bitblt_bitmap _bsd_vt_fb_bitblt_bitmap
> +#define	vt_fb_bitblt_text _bsd_vt_fb_bitblt_text
> +#define	vt_fb_blank _bsd_vt_fb_blank
> +#define	vt_fb_detach _bsd_vt_fb_detach
> +#define	vt_fb_drawrect _bsd_vt_fb_drawrect
> +#define	vt_fb_fini _bsd_vt_fb_fini
> +#define	vt_fb_init _bsd_vt_fb_init
> +#define	vt_fb_invalidate_text _bsd_vt_fb_invalidate_text
> +#define	vt_fb_ioctl _bsd_vt_fb_ioctl
> +#define	vt_fb_mmap _bsd_vt_fb_mmap
> +#define	vt_fb_postswitch _bsd_vt_fb_postswitch
> +#define	vt_fb_resume _bsd_vt_fb_resume
> +#define	vt_fb_setpixel _bsd_vt_fb_setpixel
> +#define	vt_fb_suspend _bsd_vt_fb_suspend
>  #define	wakeup _bsd_wakeup
>  #define	wakeup_one _bsd_wakeup_one
>  #define	window_deflate _bsd_window_deflate
> diff --git a/rtemsbsd/include/rtems/bsd/local/opt_fb.h b/rtemsbsd/include/rtems/bsd/local/opt_fb.h
> new file mode 100644
> index 00000000..e69de29b
