[PATCH 03/10] am335x display drivers: Import from FreeBSD
Christian Mauderer list at c-mauderer.de
Sat Jul 27 13:09:43 UTC 2019
On 26/07/2019 13:22, Vijay Kumar Banerjee wrote:
>  freebsd/sys/arm/ti/am335x/am335x_ecap.c  |  202 ++++
>  freebsd/sys/arm/ti/am335x/am335x_lcd.c   | 1085 ++++++++++++++++++++++
>  freebsd/sys/arm/ti/am335x/am335x_lcd.h   |   60 ++
>  freebsd/sys/arm/ti/am335x/am335x_pwm.h   |   35 +
>  freebsd/sys/arm/ti/am335x/am335x_pwmss.c |  165 ++++
>  freebsd/sys/dev/fb/fbreg.h               |  345 +++++++
>  freebsd/sys/dev/syscons/syscons.h        |  693 ++++++++++++++
>  freebsd/sys/dev/vt/vt.h                  |  474 ++++++++++
Wouldn't that belong to the VT part? If that header is included here I
would say VT is a prerequisite for am335x_lcd.
Regarding the whole order stuff: I already mentioned, that (as long as
each patch is compilable) I more or less will accept any order. The
current one is just a bit odd.
With your current order, the am335x_lcd wouldn't be useable before the
later fbd and VT is imported. So in that patch version there is a driver
that would not run. On the other hand VT could be used with some other
driver too (for example if someone forks from that version). So in my
eyes, VT and fbd are prerequisites for am335x_lcd.
>  freebsd/sys/sys/consio.h                 |  468 ++++++++++
>  freebsd/sys/sys/fbio.h                   |  622 +++++++++++++
>  freebsd/sys/sys/terminal.h               |  240 +++++
>  freebsd/sys/teken/teken.h                |  221 +++++
>  12 files changed, 4610 insertions(+)
>  create mode 100644 freebsd/sys/arm/ti/am335x/am335x_ecap.c
>  create mode 100644 freebsd/sys/arm/ti/am335x/am335x_lcd.c
>  create mode 100644 freebsd/sys/arm/ti/am335x/am335x_lcd.h
>  create mode 100644 freebsd/sys/arm/ti/am335x/am335x_pwm.h
>  create mode 100644 freebsd/sys/arm/ti/am335x/am335x_pwmss.c
>  create mode 100644 freebsd/sys/dev/fb/fbreg.h
>  create mode 100644 freebsd/sys/dev/syscons/syscons.h
>  create mode 100644 freebsd/sys/dev/vt/vt.h
>  create mode 100644 freebsd/sys/sys/consio.h
>  create mode 100644 freebsd/sys/sys/fbio.h
>  create mode 100644 freebsd/sys/sys/terminal.h
>  create mode 100644 freebsd/sys/teken/teken.h
