GSoC Project | Basic Support for Trace Compass
Tue Jul 30 05:54:26 UTC 2019
Hello Ravindra,
On 29/07/2019 08:14, Ravindra Kumar Meena wrote:
> *Plan of the week:*
> Last week I added the sched_switch in client-side. Trace compass can now
> show more details of the trace now. I will continue to continue to work
> on client-side.
I checked in the RTEMS patch to add some basic support for thread names.
Please update your RTEMS to the current master branch.
I check in some patches for the rtems-record program in your rtems-tools
branch.
Please run your tests with new raw input data:
../../build/misc/rtems-record --input=../record/qoriq_e6500_64.bin
The next tasks are:
1. Detect if we switch to/from an idle thread. In this case set the
corresponding state to TASK_IDLE == 1026.
2. The program should learn the thread names corresponding to a thread
identifier. Build up a thread identifier to thread name map. Use the map
to emit thread names in the sched_switch event.
You can use C++ if this makes it easier for you.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
