GSoC Project | Basic Support for Trace Compass
Wed Jul 31 05:30:57 UTC 2019
On 30/07/2019 18:32, Ravindra Kumar Meena wrote:
>      >     The next tasks are:
>      >     1. Detect if we switch to/from an idle thread. In this case
>     set the
>      >     corresponding state to TASK_IDLE == 1026.
>      > I tried to work on this task. I am not sure how to detect it without
>      > calling pthread_*.
>      > Does this have to do something with rtems_task_is_suspended?
>     https://docs.rtems.org/branches/master/c-user/task_manager.html#rtems-task-is-suspended
>     On the host you cannot call any RTEMS functions on the target. All
>     information you have is in the record items. For a start, you can
>     identify the idle threads via the identifier API:
>     https://docs.rtems.org/branches/master/c-user/key_concepts.html#object-ids
>     The API value for idle threads is 1.
> Have made changes in metadata to sync with RTEMS:
> https://github.com/rmeena840/rtems-tools/commit/4bc050227dd3055af99bd73b667015a620c259d4
Since this enum is not defined by LTTNG, we should remove it.
> Have added the prev_state in client-side:
> https://github.com/rmeena840/rtems-tools/commit/43ae797ba3c6123cc51a6244a62912c999f69a1e
The bit field is documented in the manual. I would simplify this to:
cctx->switch_out_int[ item->cpu ].prev_state = ( ( ( item->data >> 24 )
& 0x7 ) == 1 ) ? TASK_IDLE : TASK_RUNNING;
> Have a look
>      >     2. The program should learn the thread names corresponding to
>     a thread
>      >     identifier. Build up a thread identifier to thread name map.
>     Use the
>      >     map
>      >     to emit thread names in the sched_switch event.
>      > Mapping should be like this:
>      > [thread_id]->[thread_name] or [thread_name]->[thread_id]?
>     In the RTEMS_RECORD_THREAD_SWITCH_OUT and RTEMS_RECORD_THREAD_SWITCH_IN
>     record events you have the thread id. So, the mapping must be
>     [thread_id]->[thread_name].
>      > the thread name can be obtained by:
>      > rtems_record_event_text( item->event )
>      >     You can use C++ if this makes it easier for you.
>      > I will have to create separate c++ file for this.
>     Please convert the entire record-main.c file to C++.
> Okay. I will work on it after the previous task.
Did the previous task keep you busy for 8 hours?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
