GSoC PRU: simplebus vs nexus
Nils Hölscher nilhoel1 at gmail.com
Mon Jul 22 14:46:43 UTC 2019
Hi,
Thank you, I have got everything sorted out now.
Best,
Nils
On Mon, 22 Jul 2019 at 13:45, Sebastian Huber <
> On 22/07/2019 13:30, Nils Hölscher wrote:
> >      > I found the simplebus files in the rtems-libbsd repository, but
> when
> >      > building the compiler is not able to resolve the following
> include:
> >      > #include<dev/fdt/simplebus.h>
> >     Not all header files are installed with a "./waf install". You can
> add
> >     libbsd based drivers to "rtemsbsd/sys/dev".
> > This worked for simplebus.h, thank you.
> > But currently I need to add  tree/freebsd/sys/arm/ti/ti_prcm.h and other
> > files located here.
> > My include would be:" #include <arm/ti/ti_prcm.h>"
> > Simply copying them to "rtemsbsd/sys/dev" doesn't work for these files.
> > Any suggestions?
> If you don't find some header files, then make sure the header files are
> present in the tree and the included paths are present.  Maybe the
> --show-commands option for waf config is helpful. The include paths are
> in libbsd.py.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190722/a4c89d88/attachment-0002.html>
