Change Control Board (CCB) proposal for requirements
Joel Sherrill
joel at rtems.org
Tue Jul 23 15:30:00 UTC 2019
One random thought is how to ensure that patches from people with
hardware who submit patches to fix bugs get through the process.
We have generally trusted people who have hardware. This is common
for boards none of us have.
Also we have relied on a timeout rule and a level of significance. Like
yesterday
I committed a one-character fix for an error message in ticker.
There is also a level of significance where a ticket is required.
Yes we generally want an independent review but we have generally
all had a threshold where that's needed.
--joel
On Tue, Jul 23, 2019 at 8:30 AM Sebastian Huber <
> Hello Gedare,
> thanks for the review, here is a second version. The final review can
> later when I submit the patch for the RTEMS Software Engineering manual.
> Working with requirements usually involves a Change Control Board
> (:term:`CCB`). The CCB of the RTEMS project is the
> `RTEMS developer mailing list
> <https://lists.rtems.org/mailman/listinfo/devel>`_.
> There are the following actors involved:
> * *RTEMS users*: Everyone using the RTEMS real-time operating system to
> design,
> develop and build an application on top of it.
> * *RTEMS developers*: The persons developing and maintaining RTEMS.
> They write
> patches to add or modify code, requirements, tests and documentation.
> * *RTEMS requirement approvers*: Persons which registered their public
> key in
> the RTEMS project. They can create approval signatures with their
> private
> key. Their public key can be used by everyone to verify the approval
> signatures.
> * *RTEMS maintainers*: They are listed in the
> `MAINTAINERS <https://git.rtems.org/rtems/tree/MAINTAINERS>`_ file
> and have
> write access to the project repositories.
> .. TODO: Make a reference to the "normal patch review process".
> Adding and changing requirements follows the normal patch review process.
> Reviews and comments may be submitted by anyone, but a maintainer review is
> required to approve *significant* changes. In addition, there should be at
> least one reviewer with a sufficient independence from the author which
> proposes a new requirement or a change of an existing requirement.
> Working in
> another company on different projects is sufficiently independent.
> Patches can
> be sent at anytime, so controlling changes in RTEMS requires a permanent
> involvement on the RTEMS developer mailing list.
> For a qualification of RTEMS according to certain standards, the
> requirements
> may be approved by an RTEMS user. The approval by RTEMS users is not the
> concern of the RTEMS project, however, the RTEMS project should enable
> RTEMS
> users to manage the approval of requirements easily. This information
> may be
> also used by a independent authority which comes into play with an
> Independent
> Software Verification and Validation (:term:`ISVV`). It could be used to
> select a subset of requirements, e.g. look only at the ones approved by a
> certain user.
> * Users should be able to register their public key in the RTEMS project to
> become an RTEMS requirement approver. The RTEMS maintainer decide
> over the
> registration.
> * Requirement approvers should be able to attach their approval to
> requirements, test procedures, test cases and justification reports.
> * Attaching an approval should be independent of the normal development
> work
> flow, e.g. it should be possible to commit an approval long after
> requirements are committed.
> * Please note that disapproval must be done at the time of the initial
> patch
> review. If an approver needs changes in a requirement to approve it,
> then
> the normal development process must be followed, e.g. the approver
> can make a
> patch with the change and send it for review to the developer mailing
> list.
> * Other users should be able to figure out which part of RTEMS is
> approved by
> which requirement approver.
> * The integrity of approvals should be ensured by digital signatures (PGP).
> * Changes in RTEMS should invalidate automatically all approvals which are
> affected by the change (on a best-effort basis).
> .. topic:: Doorstop
> In Doorstop some values of an item (generalization of a requirement)
> contribute to a
> `fingerprint of the item
> https://github.com/jacebrowning/doorstop/blob/develop/docs/reference/items.md#reviewed
> >`_.
> Changing a value, e.g. the text of a requirement, changes the
> fingerprint.
> The links from one item to another include the fingerprint, so the
> impact
> of changes is also visible to dependent items. The service to manage
> approvals can be done with a new Doorstop feature, see
> `#375 <https://github.com/jacebrowning/doorstop/issues/375>`_,
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190723/f6e943d3/attachment-0002.html>
