[PATCH v6] ndbm test suite
Vaibhav Gupta vaibhavgupta40 at gmail.com
Mon Jul 29 18:56:19 UTC 2019
On Tue, Jul 30, 2019 at 12:11 AM Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Jul 29, 2019 at 1:07 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> On Mon, Jul 29, 2019 at 10:44 PM Joel Sherrill <joel at rtems.org> wrote:
>>> On Mon, Jul 29, 2019 at 11:35 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>>> wrote:
>>>> Thanks Joel!
>>>> Now when the testsuite patch is successfully accepted, I would like
>>>> to add an example in:
>>>> https://devel.rtems.org/wiki/Developer/Coding/80_characters_per_line,
>>>> about wrapping a "function call" in "80 characters per line".
>>> Pull. I pushed the test. It just won't get built unless your toolset has
>>> ndbm.h
>>> Thanks
>>> This sounds like helpful guidance.
>>> What's next for fenv?
>> I am following what You and Gedare suggested me. I won't directly import
>> fenv files,
>> as sources are mixed (FreeBSD and NetBSD), I am trying to unify them.
> One newlib patch per architecture even if you are merging implementations.
>> I will be approaching in this manner:
>>    1. I will make a header file     `libc/include/fenv.h`. All function
>>    definitons will be mentioned. All definitons/macros which are architecture
>>    specific will be kept between  #if /  #elif  /  #else  directives.
> Avoid adding if's to the main fenv.h if you are doing bodies of the
> implementation. As one example, RISC-V has its own fenv.h in
> libc/machine/riscv/include and bodies of the methods in libm/machine/riscv.
Okay.
>  fenv.h looks to be portable if sys/fenv.h is "machine" dependent. Your
> if's could be factored out into machine/ARCH/include/fenv.h. Then the
> portable method prototypes are in libc/include/fenv.h.
> Let me ask about that on the newlib list.
Yeah, I saw your mail on newlib just now, So you are proposing same
structure as followed by
NetBSD. They too have general fenv.h present in incliude :
https://github.com/NetBSD/src/blob/trunk/include/fenv.h
and a minimal working header which is architecture dependent.:
https://github.com/NetBSD/src/blob/trunk/sys/arch/sparc/include/fenv.h
I wasn't sure if this approach can applied in newlib too, so I was going
for if's directive thing.
Thanks
Vaibhav Gupta
>>    1. Make architecture specific folders where I will Place   `fenv.c`
>>    files.
>> - Vaibhav  Gupta
>>>> Gedare and me discussed about it on a thread. That time he guided me
>>>> for this
>>>> as there is no example about in on the trac pag.
>>>> Vaibhav Gupta
>>>> On Mon, Jul 29, 2019 at 9:33 PM Joel Sherrill <joel at rtems.org> wrote:
>>>>> Hi
>>>>> Now pushed. Thanks.
>>>>> I finally got a local sparc tool chain built with the git master of
>>>>> newlib to build and run this test. It was a bit more complicated than I
>>>>> expected.
>>>>> I did add a bit of logic to the psxtests configure.ac and Makefile.am
>>>>> to ensure the test was not built unless the toolset included <ndbm.h>. This
>>>>> ensures that builds don't break when the toolset doesn't include it and
>>>>> that git bisect will continue to work.
>>>>> The RSB will need to be bumped to the git master once the github
>>>>> mirror updates to include my push to libm.
>>>>> On Thu, Jul 25, 2019 at 2:34 PM Joel Sherrill <joel at rtems.org> wrote:
>>>>>> Hi
>>>>>> I just wanted to let everyone know that I have this pending on a
>>>>>> branch and can build it using the current but there is a problem linking
>>>>>> libm on the newlib git master. Once I have the RSB updated, I will look at
>>>>>> pushing this.
>>>>>> To let Vaibhav continue pushing on fenv, if we decide the
>>>>>> configure.ac should check for the newly added dbm methods before
>>>>>> building the test, I will merge that into the patch.
>>>>>> --joel
>>>>>> On Tue, Jul 23, 2019 at 8:42 AM Vaibhav Gupta <
>>>>>> vaibhavgupta40 at gmail.com> wrote:
>>>>>>>  testsuites/psxtests/Makefile.am             |   9 +
>>>>>>>  testsuites/psxtests/configure.ac            |   1 +
>>>>>>>  testsuites/psxtests/psxndbm01/init.c        | 299
>>>>>>>  testsuites/psxtests/psxndbm01/psxndbm01.doc |  36 +++
>>>>>>>  testsuites/psxtests/psxndbm01/psxndbm01.scn |  29 ++
>>>>>>>  5 files changed, 374 insertions(+)
>>>>>>>  create mode 100644 testsuites/psxtests/psxndbm01/init.c
>>>>>>>  create mode 100644 testsuites/psxtests/psxndbm01/psxndbm01.doc
>>>>>>>  create mode 100644 testsuites/psxtests/psxndbm01/psxndbm01.scn
>>>>>>> diff --git a/testsuites/psxtests/Makefile.am
>>>>>>> b/testsuites/psxtests/Makefile.am
>>>>>>> index 59c9f2085b..36da591ccc 100755
>>>>>>> --- a/testsuites/psxtests/Makefile.am
>>>>>>> +++ b/testsuites/psxtests/Makefile.am
>>>>>>> @@ -694,6 +694,15 @@ psxmutexattr01_CPPFLAGS = $(AM_CPPFLAGS)
>>>>>>> $(TEST_FLAGS_psxmutexattr01) \
>>>>>>>         $(support_includes) -I$(top_srcdir)/include
>>>>>>>  endif
>>>>>>> +if TEST_psxndbm01
>>>>>>> +psx_tests += psxndbm01
>>>>>>> +psx_screens += psxndbm01/psxndbm01.scn
>>>>>>> +psx_docs += psxndbm01/psxndbm01.doc
>>>>>>> +psxndbm01_SOURCES = psxndbm01/init.c
>>>>>>> +psxndbm01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxndbm01) \
>>>>>>> +       $(support_includes)
>>>>>>> +endif
>>>>>>>  if TEST_psxobj01
>>>>>>>  psx_tests += psxobj01
>>>>>>>  psx_screens += psxobj01/psxobj01.scn
>>>>>>> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
>>>>>>> configure.ac
>>>>>>> index 85559e4aa5..07d7ccaf55 100644
>>>>>>> --- a/testsuites/psxtests/configure.ac
>>>>>>> +++ b/testsuites/psxtests/configure.ac
>>>>>>> @@ -110,6 +110,7 @@ RTEMS_TEST_CHECK([psxmsgq02])
>>>>>>>  RTEMS_TEST_CHECK([psxmsgq03])
>>>>>>>  RTEMS_TEST_CHECK([psxmsgq04])
>>>>>>>  RTEMS_TEST_CHECK([psxmutexattr01])
>>>>>>> +RTEMS_TEST_CHECK([psxndbm01])
>>>>>>>  RTEMS_TEST_CHECK([psxobj01])
>>>>>>>  RTEMS_TEST_CHECK([psxonce01])
>>>>>>>  RTEMS_TEST_CHECK([psxpasswd01])
>>>>>>> diff --git a/testsuites/psxtests/psxndbm01/init.c
>>>>>>> b/testsuites/psxtests/psxndbm01/init.c
>>>>>>> new file mode 100644
>>>>>>> index 0000000000..a1eff4bd67
>>>>>>> --- /dev/null
>>>>>>> +++ b/testsuites/psxtests/psxndbm01/init.c
>>>>>>> @@ -0,0 +1,299 @@
>>>>>>> + *  @file
>>>>>>> + *  @brief Test suite for ndbm.h methods
>>>>>>> + * SPDX-License-Identifier: BSD-2-Clause
>>>>>>> + * Copyright (C) 2019 Vaibhav Gupta
>>>>>>> + * Redistribution and use in source and binary forms, with or
>>>>>>> without
>>>>>>> + * modification, are permitted provided that the following
>>>>>>> conditions
>>>>>>> + * are met:
>>>>>>> + * 1. Redistributions of source code must retain the above copyright
>>>>>>> + *    notice, this list of conditions and the following disclaimer.
>>>>>>> + * 2. Redistributions in binary form must reproduce the above
>>>>>>> copyright
>>>>>>> in the
>>>>>>> + *    documentation and/or other materials provided with the
>>>>>>> distribution.
>>>>>>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>>> CONTRIBUTORS "AS IS"
>>>>>>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>>>>>>> LIMITED TO, THE
>>>>>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>>>> PARTICULAR PURPOSE
>>>>>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>>>>>>> CONTRIBUTORS BE
>>>>>>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
>>>>>>> OR
>>>>>>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>>>>>>> PROCUREMENT OF
>>>>>>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>>>>> BUSINESS
>>>>>>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>>>> WHETHER IN
>>>>>>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>>>> OTHERWISE)
>>>>>>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>>>> ADVISED OF THE
>>>>>>> + * POSSIBILITY OF SUCH DAMAGE.
>>>>>>> +#ifdef HAVE_CONFIG_H
>>>>>>> +#include "config.h"
>>>>>>> +#endif
>>>>>>> +/* header files are listed in lexical/lexicographical/alphabetical
>>>>>>> order */
>>>>>>> +#include <errno.h>
>>>>>>> +#include <fcntl.h>      /* contains definitions of 'open_flags' */
>>>>>>> +#include <limits.h>
>>>>>>> +#include <ndbm.h>       /* contains declarations of ndbm methods */
>>>>>>> +#include <stddef.h>
>>>>>>> +#include <stdint.h>
>>>>>>> +#include <stdio.h>
>>>>>>> +#include <sys/stat.h>   /* contains definitions of 'file_mode' */
>>>>>>> +#include <string.h>
>>>>>>> +#include <rtems/test.h>
>>>>>>> +#include <tmacros.h>
>>>>>>> +const char rtems_test_name[] = "PSXNDBM 01";
>>>>>>> +#define NAME      "VARoDeK"
>>>>>>> +#define PHONE_NO  "123-321-777-888"
>>>>>>> +#define DB_NAME   "phones_test"
>>>>>>> +#define NAME2     "VG"
>>>>>>> +#define PHONE_NO2 "321-123-888-777"
>>>>>>> +/* forward declarations to avoid warnings */
>>>>>>> +rtems_task Init(rtems_task_argument ignored);
>>>>>>> +* This Function takes DBM* as a argument and count the number of
>>>>>>> records in the
>>>>>>> +* database pointed by it.
>>>>>>> +static int count_no_of_records( DBM *db_local )
>>>>>>> +  int count = 0;
>>>>>>> +  datum temp;
>>>>>>> +  for (
>>>>>>> +    temp = dbm_firstkey( db_local );
>>>>>>> +    temp.dptr != NULL;
>>>>>>> +    temp = dbm_nextkey( db_local ), count++
>>>>>>> +  return count;
>>>>>>> +/* Test Function Begins */
>>>>>>> +  datum name          = { NAME, sizeof( NAME ) };
>>>>>>> +  datum put_phone_no  = { PHONE_NO, sizeof( PHONE_NO ) };
>>>>>>> +  datum name2         = { NAME2, sizeof( NAME2 ) };
>>>>>>> +  datum put_phone_no2 = { PHONE_NO2, sizeof( PHONE_NO2 ) };
>>>>>>> +  datum get_phone_no, key;
>>>>>>> +  int i;
>>>>>>> +  char *test_strings;
>>>>>>> +  DBM *db;
>>>>>>> +  TEST_BEGIN();
>>>>>>> +/* A Simple test to check if ndbm methods are call-able */
>>>>>>> + * A Simple test to check if NDBM methods are call-able
>>>>>>> + * We will try to open a database and then close it.
>>>>>>> + * If it successful, hence we can have further tests.
>>>>>>> + * Also, while opening it for first time, will create that database,
>>>>>>> + * hence we will be able to test for 'O_RDWR | O_EXCL' case later.
>>>>>>> + * Meanwhile we will also store one record, this record will be
>>>>>>> helpful in
>>>>>>> + * further tests.
>>>>>>> + * And fetch it, to make sure if basic NDBM methods are working
>>>>>>> correctly.
>>>>>>> +  puts( "\nOpen Database." );
>>>>>>> +  db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_TRUNC, S_IRWXU );
>>>>>>> +  rtems_test_assert( db != NULL );
>>>>>>> +  /* This data will be useful in further tests */
>>>>>>> +  puts( "Store Records in Database." );
>>>>>>> +  dbm_store( db, name, put_phone_no, DBM_INSERT );
>>>>>>> +  puts( "Fetch Records from Database and check." );
>>>>>>> +  get_phone_no = dbm_fetch( db, name );
>>>>>>> +  rtems_test_assert( strcmp( (const char*)get_phone_no.dptr,
>>>>>>> PHONE_NO ) == 0 );
>>>>>>> +  puts( "Close Database." );
>>>>>>> +  dbm_close( db );
>>>>>>> +/* dbm_open() */
>>>>>>> +  puts( "\nTestcases for 'dbm_open()'." );
>>>>>>> +/* The 'DB_NAME' is already created, hence 'O_RDWR | O_EXCL' should
>>>>>>> fail. */
>>>>>>> +  puts( "Use 'O_CREAT | O_EXCL' to open existing file and confirm
>>>>>>> error." );
>>>>>>> +  db = dbm_open( DB_NAME, O_RDWR | O_CREAT | O_EXCL, S_IRWXU );
>>>>>>> +  rtems_test_assert( db == NULL );
>>>>>>> +  rtems_test_assert( errno == EEXIST );
>>>>>>> +/* Some implementations use 3 characters for the suffix and others
>>>>>>> use
>>>>>>> + * 4 characters for the suffix, applications should ensure that the
>>>>>>> maximum
>>>>>>> + * portable pathname length passed to dbm_open() is no greater than
>>>>>>> + * {PATH_MAX}-4 bytes, with the last component of the pathname no
>>>>>>> greater
>>>>>>> + * than {NAME_MAX}-4 bytes.
>>>>>>> +/* inside 'ndbm.h' ; '#define  DBM_SUFFIX      ".db"' ;
>>>>>>> + * 2 alphabets and 1 period, hence 3 characters are used for suffix
>>>>>>> + * in this implementation.
>>>>>>> +  puts( "Use path name larger than '{PATH_MAX}-3 bytes.' and
>>>>>>> confirm error." );
>>>>>>> +  test_strings = (char*)malloc( PATH_MAX - 2 );
>>>>>>> +  for ( i = 0; i < PATH_MAX - 3; i++ ) {
>>>>>>> +    test_strings[i] = 'r';
>>>>>>> +  test_strings[i] = '\0';
>>>>>>> +  db = dbm_open(
>>>>>>> +                (const char*)test_strings,
>>>>>>> +                O_RDWR | O_CREAT | O_TRUNC,
>>>>>>> +                S_IRWXU
>>>>>>> +  rtems_test_assert( errno == ENAMETOOLONG );
>>>>>>> +  free( test_strings );
>>>>>>> +/* database opened for write-only access opens the files for read
>>>>>>> and
>>>>>>> + * write access or it will fail.
>>>>>>> +/* Implementation of __hash_open in newlib does not support
>>>>>>> `O_WRONLY` */
>>>>>>> +  puts( "Open file with write access only and confirm error." );
>>>>>>> +  db = dbm_open( DB_NAME, O_WRONLY, S_IRWXU );
>>>>>>> +  rtems_test_assert( errno == EINVAL );
>>>>>>> +/* dbm_store() */
>>>>>>> +  puts( "\nTestcases for 'dbm_store()'" );
>>>>>>> +  db = dbm_open( DB_NAME, O_RDWR, S_IRWXU );
>>>>>>> +  puts( "Insert new record with same key using 'DBM_INSERT' mode
>>>>>>> and "
>>>>>>> +        "confirm error." );
>>>>>>> +  rtems_test_assert( dbm_store( db, name, put_phone_no2, DBM_INSERT
>>>>>>> ) == 1 );
>>>>>>> PHONE_NO ) == 0 );
>>>>>>> +  puts( "Insert new record with same key using 'DBM_REPLACE' mode
>>>>>>> and "
>>>>>>> +        "confirm changes." );
>>>>>>> DBM_REPLACE ) == 0 );
>>>>>>> PHONE_NO2 ) == 0 );
>>>>>>> +/* Revert for next tests */
>>>>>>> +  rtems_test_assert( dbm_store( db, name, put_phone_no, DBM_REPLACE
>>>>>>> ) == 0 );
>>>>>>> +  puts( "Store a new record and "
>>>>>>> +        "confirm that total number of records is successful 2." );
>>>>>>> +  rtems_test_assert( dbm_store( db, name2, put_phone_no2,
>>>>>>> DBM_INSERT ) == 0 );
>>>>>>> +/* Confirm number of records */
>>>>>>> +  rtems_test_assert( count_no_of_records( db ) == 2 );
>>>>>>> +  dbm_close( db );
>>>>>>> +/* dbm_fetch() */
>>>>>>> +  puts( "\nTestcases for 'dbm_fetch()'" );
>>>>>>> +  db = dbm_open( DB_NAME, O_RDONLY, S_IRWXU );
>>>>>>> +  puts( "Fetch existing records and confirm results." );
>>>>>>> PHONE_NO ) == 0 );
>>>>>>> +  get_phone_no = dbm_fetch( db, name2 );
>>>>>>> PHONE_NO2 ) == 0 );
>>>>>>> +  puts( "Fetch non-existing record and confirm error." );
>>>>>>> +  test_strings = (char*)malloc(6);
>>>>>>> +  strncpy( test_strings, "Hello", 5 );
>>>>>>> +  test_strings[5] = '\0';
>>>>>>> +/* The data pointed by test_string is now pointed by key.dptr */
>>>>>>> +  key.dptr = test_strings;
>>>>>>> +  key.dsize = sizeof( test_strings );
>>>>>>> +  get_phone_no = dbm_fetch( db, key );
>>>>>>> +  rtems_test_assert( get_phone_no.dptr == NULL );
>>>>>>> +  dbm_close( db );
>>>>>>> +/* We need the 'key' object, hence we cannot free 'test_strings'
>>>>>>> +/* dbm_delete() */
>>>>>>> +  puts( "\nTestcases for 'dbm_delete()'" );
>>>>>>> +  puts( "Delete non-existing record and confirm error." );
>>>>>>> +  rtems_test_assert( dbm_delete( db, key ) != 0 );
>>>>>>> +  rtems_test_assert( count_no_of_records( db ) == 2);
>>>>>>> +  puts( "Delete existing record and "
>>>>>>> +        "confirm that total number of records is successful 1." );
>>>>>>> +  rtems_test_assert( dbm_delete( db, name ) == 0 );
>>>>>>> +  rtems_test_assert( count_no_of_records( db ) == 1);
>>>>>>> +  puts( "Confirm if correct record is deleted." );
>>>>>>> +/* record returned by 'dbm_firstkey()' should be the only record
>>>>>>> + * left, this should be checked to confirm correct working of
>>>>>>> + * 'dbm_firstkey()'.
>>>>>>> + * Check if the data is not corrupted after usage of 'dbm_delete()'
>>>>>>> +  puts( "Check if the data is not corrupted after usage of
>>>>>>> 'dbm_delete()'." );
>>>>>>> +  get_phone_no = dbm_fetch( db, dbm_firstkey( db ) );
>>>>>>> PHONE_NO2 ) == 0 );
>>>>>>> +/* Empty the database and then try to use 'dbm_firstkey()', the
>>>>>>> + * dptr pointer should point to NULL.
>>>>>>> +  puts( "Empty records in database and check results of
>>>>>>> 'dbm_firstkey()'." );
>>>>>>> +  rtems_test_assert( dbm_delete( db, dbm_firstkey( db ) ) == 0 );
>>>>>>> +  key = dbm_firstkey( db );
>>>>>>> +  rtems_test_assert( key.dptr == NULL );
>>>>>>> +  dbm_close( db );
>>>>>>> +* All cases for 'dbm_firstkey()' and 'dbm_nextkey()' were tested
>>>>>>> while
>>>>>>> +* performing other tests.
>>>>>>> +* One such case be found in count_number_of_records() function.
>>>>>>> +  TEST_END();
>>>>>>> +  rtems_test_exit(0);
>>>>>>> +/* NOTICE: the clock driver is explicitly disabled */
>>>>>>> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>>>>>>> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>>>>>>> +#define CONFIGURE_MAXIMUM_TASKS                  1
>>>>>>> +#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 6
>>>>>>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>>>>>> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>>>>>>> +#include <rtems/confdefs.h>
>>>>>>> +/* end of file */
>>>>>>> diff --git a/testsuites/psxtests/psxndbm01/psxndbm01.doc
>>>>>>> b/testsuites/psxtests/psxndbm01/psxndbm01.doc
>>>>>>> index 0000000000..cdaeb40911
>>>>>>> --- /dev/null
>>>>>>> +++ b/testsuites/psxtests/psxndbm01/psxndbm01.doc
>>>>>>> @@ -0,0 +1,36 @@
>>>>>>> +This File describes the concepts tested by this test suite.
>>>>>>> +ndbm.h - routines to manage data files that contain key/data pairs.
>>>>>>> +test suite name: PSXNDBM 01
>>>>>>> +- A Simple test to check if NDBM methods are call-able.
>>>>>>> +  - Check if able to run the routine to Open Database.
>>>>>>> +  - Check if able to run the routine to store a record in database.
>>>>>>> +  - Check if able to run the routine to fetch a record from
>>>>>>> database.
>>>>>>> +  - Check if able to run the routine to close the database.
>>>>>>> +- Test Cases for 'dbm_open()'.
>>>>>>> +  - Verify the error when trying to open existing file with 'O_RDWR
>>>>>>> | O_EXCL'
>>>>>>> +    flags.
>>>>>>> +  - Verify the error when trying to open file with pathname longer
>>>>>>> than
>>>>>>> +    {PATHMAX}-3 bytes.
>>>>>>> +  - Verify the error when trying to open file with only write
>>>>>>> access.
>>>>>>> +- Test Cases for 'dbm_store()'.
>>>>>>> +  - Verify the error when trying to insert a record using same key
>>>>>>> with
>>>>>>> +    'DBM_INSERT' mode.
>>>>>>> +  - Verify the updated record when trying to insert a record using
>>>>>>> same key
>>>>>>> +    with 'DBM_REPLACE' mode.
>>>>>>> +  - Verify if able to save more than one record in database.
>>>>>>> +- Test Cases for 'dbm_fetch()'.
>>>>>>> +  - Verify the data fetched from database.
>>>>>>> +  - Verify the error when tring to fetch non-existing record.
>>>>>>> +- Test Cases for 'dbm_delete()'.
>>>>>>> +  - Veriy the error when trying to delete non-existing record.
>>>>>>> +  - Delete one record and verify results.
>>>>>>> +  - Check if correct record is deleted.
>>>>>>> +  - Verify if other data is not corrupted during delete.
>>>>>>> +  - Empty the databse and verify the value returned by
>>>>>>> 'dbm_firstkey()'.
>>>>>>> \ No newline at end of file
>>>>>>> diff --git a/testsuites/psxtests/psxndbm01/psxndbm01.scn
>>>>>>> b/testsuites/psxtests/psxndbm01/psxndbm01.scn
>>>>>>> index 0000000000..3fa386630a
>>>>>>> --- /dev/null
>>>>>>> +++ b/testsuites/psxtests/psxndbm01/psxndbm01.scn
>>>>>>> @@ -0,0 +1,29 @@
>>>>>>> +*** PSXNDBM 01 Test ***
>>>>>>> +Open Database.
>>>>>>> +Store Records in Database.
>>>>>>> +Fetch Records from Database and check.
>>>>>>> +Close Database.
>>>>>>> +Testcases for 'dbm_open()'.
>>>>>>> +Use 'O_CREAT | O_EXCL' to open existing file and confirm error.
>>>>>>> +Use path name larger than '{PATH_MAX}-3 bytes.' and confirm error.
>>>>>>> +Open file with write access only and confirm error.
>>>>>>> +Testcases for 'dbm_store()'
>>>>>>> +Insert new record with same key using 'DBM_INSERT' mode and confirm
>>>>>>> error.
>>>>>>> +Insert new record with same key using 'DBM_REPLACE' mode and
>>>>>>> confirm changes.
>>>>>>> +Store a new record and confirm that total number of records is
>>>>>>> successful 2.
>>>>>>> +Testcases for 'dbm_fetch()'
>>>>>>> +Fetch existing records and confirm results.
>>>>>>> +Fetch non-existing record and confirm error.
>>>>>>> +Testcases for 'dbm_delete()'
>>>>>>> +Delete non-existing record and confirm error.
>>>>>>> +Delete existing record and confirm that total number of records is
>>>>>>> successful 1.
>>>>>>> +Confirm if correct record is deleted.
>>>>>>> +Check if the data is not corrupted after usage of 'dbm_delete()'.
>>>>>>> +Empty records in database and check results of 'dbm_firstkey()'.
>>>>>>> +*** END OF TEST PSXNDBM 01 ***
>>>>>>> 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190730/7539b51d/attachment-0002.html>
