[PATCH] Add Test suite for inttypes.h (psxinttypes.exe) in testsuites/psxtests
Gedare Bloom
gedare at rtems.org
Sat Jun 1 16:51:58 UTC 2019
On Sat, Jun 1, 2019, 8:29 AM Aditya Upadhyay <aadit0402 at gmail.com> wrote:
> On Sat, Jun 1, 2019 at 5:03 AM Gedare Bloom <gedare at rtems.org> wrote:
> > On Fri, May 31, 2019 at 10:17 AM Aditya Upadhyay <aadit0402 at gmail.com>
> wrote:
> > > Hi VARoDeK,
> > > This looks fine to me. I would love to see other's responses.
> > This test is not right, it needs to be rethought. Let me know if you
> > need further guidance.
> Yeah, Gedare !! I need some further guidance. I had written this test
> 1 year ago, but could not send it on devel.
> I was writing this testsuite for the very first time.
If you wrote the test, your name should belong in the copyright info.
Could you please point me an example?
Which psxtest was this derived from? Is there a psxtest that considers
string conversions? That would be a good start. Do some digging.
The logic of the test needs to be thought out. What is the expected
behavior being tested? How do you isolate correct/incorrect behavior?
Gedare
Although I have gone through
> open group POSIX
> Page and looked into some previously made testsuites in the psxtests
> directory.
> While configuring, I had used --enable-tests=yes option, but I do not
> see any generated .exe file.
> or Can we generate the .exe file manually?
> > > On Thu, May 30, 2019 at 8:47 PM VARoDeK <vaibhavgupta40 at gmail.com>
> wrote:
> > > > testsuites/psxtests/Makefile.am | 7 +
> > > > testsuites/psxtests/configure.ac | 1 +
> > > > testsuites/psxtests/psxinttypes01/init.c | 154
> > > > .../psxtests/psxinttypes01/psxinttypes01.doc | 57 +++++++
> > > > .../psxtests/psxinttypes01/psxinttypes01.scn | 28 ++++
> > > > 5 files changed, 247 insertions(+)
> > > > create mode 100644 testsuites/psxtests/psxinttypes01/init.c
> > > > create mode 100644
> testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> > > > create mode 100644
> testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> > > > diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> > > > index 749258cc0c..f619dd9ae9 100644
> > > > --- a/testsuites/psxtests/Makefile.am
> > > > +++ b/testsuites/psxtests/Makefile.am
> > > > @@ -22,6 +22,13 @@ psx01_CPPFLAGS = $(AM_CPPFLAGS)
> $(TEST_FLAGS_psx01) \
> > > > $(support_includes) -I$(top_srcdir)/include
> > > > endif
> > > > +if TEST_psxinttypes01
> > > > +psx_tests += psxinttypes01
> > > > +psxinttypes01_SOURCES = psxinttypes01/init.c
> > > > +psxinttypes01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxinttypes01)
> > > > + $(support_includes)
> > > > +endif
> > > > if HAS_POSIX
> > > > if TEST_psx02
> > > > psx_tests += psx02
> > > > diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
> configure.ac
> > > > index cdd6ee7e4e..e032a6f5ec 100644
> > > > --- a/testsuites/psxtests/configure.ac
> > > > +++ b/testsuites/psxtests/configure.ac
> > > > @@ -140,6 +140,7 @@ RTEMS_TEST_CHECK([psxtimes01])
> > > > RTEMS_TEST_CHECK([psxualarm])
> > > > RTEMS_TEST_CHECK([psxusleep])
> > > > RTEMS_TEST_CHECK([lib_a])
> > > > +RTEMS_TEST_CHECK([psxinttypes01])
> > > > AC_CONFIG_FILES([Makefile])
> > > > AC_OUTPUT
> > > > diff --git a/testsuites/psxtests/psxinttypes01/init.c
> b/testsuites/psxtests/psxinttypes01/init.c
> > > > new file mode 100644
> > > > index 0000000000..1c6340afe2
> > > > --- /dev/null
> > > > +++ b/testsuites/psxtests/psxinttypes01/init.c
> > > > @@ -0,0 +1,154 @@
> > > > + * @file
> > > > + * @brief Test suite for inttypes.h methods
> > > > + * SPDX-License-Identifier: BSD-2-Clause
> > > > + * Copyright (C) 2019, Vaibhav Gupta
> > > > + * Redistribution and use in source and binary forms, with or
> without
> > > > + * modification, are permitted provided that the following
> conditions
> > > > + * are met:
> > > > + * 1. Redistributions of source code must retain the above copyright
> > > > + * notice, this list of conditions and the following disclaimer.
> > > > + * 2. Redistributions in binary form must reproduce the above
> copyright
> in the
> > > > + * documentation and/or other materials provided with the
> distribution.
> > > > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
> CONTRIBUTORS "AS IS"
> > > > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
> LIMITED TO, THE
> > > > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> PARTICULAR PURPOSE
> > > > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > > > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
> OR
> > > > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
> PROCUREMENT OF
> > > > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > > > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
> WHETHER IN
> > > > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > > > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
> ADVISED OF THE
> > > > + * POSSIBILITY OF SUCH DAMAGE.
> > > > +#ifdef HAVE_CONFIG_H
> > > > +#include "config.h"
> > > > +#endif
> > > > +#include <rtems/test.h>
> > > > +#include <inttypes.h>
> > > > +#include <stdio.h>
> > > > +#include <errno.h>
> > > > +#include <tmacros.h>
> > > > +#include <stdint.h>
> > > > +#include <stddef.h>
> > > > +const char rtems_test_name[] = "PSXINTTYPE 01";
> > > > +/* forward declarations to avoid warnings */
> > > > +rtems_task Init(rtems_task_argument ignored);
> > > > + int base = 10;
> > > > + char *nptr1 = "123abc";
> > > > + char *endptr1 = NULL;
> > > > + wchar_t *nptr2 = L"-123junk";
> > > > + wchar_t *endptr2 = NULL;
> > > > + intmax_t status1;
> > > > + uintmax_t status2;
> > > > + TEST_BEGIN();
> > > > + puts( "\nChecking invalid base value" );
> > > > + rtems_test_assert( base >=2 && base <= 36 );
> > > > + /*Test for strtoimax */
> > > > + puts( "Strtoimax Testcases...." );
> > > > + puts( "Generating Status" );
> > > > + status1 = strtoimax( nptr1, &endptr1, base );
> > > > + rtems_test_assert( status1 != 0);
> > > > + rtems_test_assert( base != EINVAL);
> > > > + puts( "Checking Garbage end of endptr" );
> > > > + rtems_test_assert( *endptr1 != '\0' );
> > > > + puts( "Checking Underflow Case" );
> > > > + rtems_test_assert( status1 >= INTMAX_MIN );
> > > > + puts( "Checking Overflow Case" );
> > > > + rtems_test_assert( status1 <= INTMAX_MAX ) ;
> > > > + printf( "status = %jd \n" , status1 );
> > > > + /*Test for strtoumax */
> > > > + puts( "Strtoumax Testcases...." );
> > > > + status2 = strtoumax( nptr1, &endptr1, base );
> > > > + rtems_test_assert( status2 != 0);
> > > > + rtems_test_assert( status2 <= UINTMAX_MAX );
> > > > + printf( "status = %ju \n", status2 );
> > > > + /*Test for wcstoimax */
> > > > + puts( "Wcstoimax Testcases...." );
> > > > + status1 = wcstoimax( nptr2, &endptr2, base );
> > > > + rtems_test_assert( *endptr2 != '\0' );
> > > > + printf( "status = %jd \n", status1 );
> > > > + /*Test for wcstoumax */
> > > > + puts( "wcstoumax Testcases...." );
> > > > + status2 = wcstoumax( nptr2, &endptr2, base );
> > > > + TEST_END();
> > > > + rtems_test_exit(0);
> > > > +/* NOTICE: the clock driver is explicitly disabled */
> > > > +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> > > > +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> > > > +#define CONFIGURE_MAXIMUM_TASKS 1
> > > > +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > > > +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> > > > +#include <rtems/confdefs.h>
> > > > diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> > > > index 0000000000..f9e0951786
> > > > --- /dev/null
> > > > +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> > > > @@ -0,0 +1,57 @@
> > > > + * @file
> > > > + * @brief Doc for Test suite for inttypes.h methods
> without
> conditions
> > > > + * are met:
> copyright
> in the
> distribution.
> LIMITED TO, THE
> PARTICULAR PURPOSE
> CONTRIBUTORS BE
> OR
> PROCUREMENT OF
> BUSINESS
> WHETHER IN
> OTHERWISE)
> ADVISED OF THE
> > > > +This File describes the concepts tested by this test suite.
> > > > +inttypes.h - fixed size integer types
> > > > +test suite name: PSXINTTYPE 01
> > > > +- Checks for invalid base value
> > > > +- Checks for Strtoimax Testcases
> > > > + - checks for Garbage end of endptr
> > > > + - checks for Underflow Case
> > > > + - checks for Overflow Case
> > > > +- Checks for Strtoumax Test Cases
> > > > +- Checks for Wcstoimax Testcases
> > > > +- Checks for Wcstoumax Testcases
> > > > diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> > > > index 0000000000..cdd56b327d
> > > > --- /dev/null
> > > > +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> > > > @@ -0,0 +1,28 @@
> > > > +*** PSXINTTYPE 01 TEST ***
> > > > +Checking invalid base value
> > > > +Strtoimax Testcases....
> > > > +Generating Status
> > > > +Checking Garbage end of endptr
> > > > +Checking Underflow Case
> > > > +Checking Overflow Case
> > > > +status = 123
> > > > +Strtoumax Testcases....
> > > > +Generating Status
> > > > +status = 123
> > > > +Wcstoimax Testcases....
> > > > +Generating Status
> > > > +status = -123
> > > > +wcstoumax Testcases....
> > > > +Generating Status
> > > > +status = 18446744073709551493
> > > > +*** END OF PSXINTTYPE 01 TEST ***
> > > > 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190601/82d39f55/attachment-0001.html>
