[PATCH] Add Test suite for inttypes.h (psxinttypes.exe) in testsuites/psxtests
Aditya Upadhyay aadit0402 at gmail.com
Mon Jun 3 14:37:31 UTC 2019
On Sat, Jun 1, 2019 at 10:22 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Sat, Jun 1, 2019, 8:29 AM Aditya Upadhyay <aadit0402 at gmail.com> wrote:
>> On Sat, Jun 1, 2019 at 5:03 AM Gedare Bloom <gedare at rtems.org> wrote:
>> > On Fri, May 31, 2019 at 10:17 AM Aditya Upadhyay <aadit0402 at gmail.com> wrote:
>> > > Hi VARoDeK,
>> > > This looks fine to me. I would love to see other's responses.
>> > This test is not right, it needs to be rethought. Let me know if you
>> > need further guidance.
>> Yeah, Gedare !! I need some further guidance. I had written this test
>> 1 year ago, but could not send it on devel.
>> I was writing this testsuite for the very first time.
> If you wrote the test, your name should belong in the copyright info.
I had handed over this code to Vaibhav for sake of learning purposes.
If Community
does not allow this, Then I would take it back. I would appreciate
your thought on that.
>> Could you please point me an example?
> Which psxtest was this derived from? Is there a psxtest that considers string conversions? That would be a good start. Do some digging.
Thanks for pointing it out. Though I am working on a needed
correction. Would It be a wise choice to test cases
for each inttypes methods?
> The logic of the test needs to be thought out. What is the expected behavior being tested? How do you isolate correct/incorrect behavior?
I had used hardcoded input only for the success of the operation. I
will also consider the expected behavior for Invalid inputs.
> Gedare
>> Although I have gone through
>> open group POSIX
>> Page and looked into some previously made testsuites in the psxtests directory.
>> While configuring, I had used --enable-tests=yes option, but I do not
>> see any generated .exe file.
>> or Can we generate the .exe file manually?
>> > > On Thu, May 30, 2019 at 8:47 PM VARoDeK <vaibhavgupta40 at gmail.com> wrote:
>> > > >  testsuites/psxtests/Makefile.am               |   7 +
>> > > >  testsuites/psxtests/configure.ac              |   1 +
>> > > >  testsuites/psxtests/psxinttypes01/init.c      | 154 ++++++++++++++++++
>> > > >  .../psxtests/psxinttypes01/psxinttypes01.doc  |  57 +++++++
>> > > >  .../psxtests/psxinttypes01/psxinttypes01.scn  |  28 ++++
>> > > >  5 files changed, 247 insertions(+)
>> > > >  create mode 100644 testsuites/psxtests/psxinttypes01/init.c
>> > > >  create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.doc
>> > > >  create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.scn
>> > > > diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
>> > > > index 749258cc0c..f619dd9ae9 100644
>> > > > --- a/testsuites/psxtests/Makefile.am
>> > > > +++ b/testsuites/psxtests/Makefile.am
>> > > > @@ -22,6 +22,13 @@ psx01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psx01) \
>> > > >         $(support_includes) -I$(top_srcdir)/include
>> > > >  endif
>> > > > +if TEST_psxinttypes01
>> > > > +psx_tests += psxinttypes01
>> > > > +psxinttypes01_SOURCES = psxinttypes01/init.c
>> > > > +psxinttypes01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxinttypes01) \
>> > > > +       $(support_includes)
>> > > > +endif
>> > > >  if HAS_POSIX
>> > > >  if TEST_psx02
>> > > >  psx_tests += psx02
>> > > > diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
>> > > > index cdd6ee7e4e..e032a6f5ec 100644
>> > > > --- a/testsuites/psxtests/configure.ac
>> > > > +++ b/testsuites/psxtests/configure.ac
>> > > > @@ -140,6 +140,7 @@ RTEMS_TEST_CHECK([psxtimes01])
>> > > >  RTEMS_TEST_CHECK([psxualarm])
>> > > >  RTEMS_TEST_CHECK([psxusleep])
>> > > >  RTEMS_TEST_CHECK([lib_a])
>> > > > +RTEMS_TEST_CHECK([psxinttypes01])
>> > > >  AC_CONFIG_FILES([Makefile])
>> > > >  AC_OUTPUT
>> > > > diff --git a/testsuites/psxtests/psxinttypes01/init.c b/testsuites/psxtests/psxinttypes01/init.c
>> > > > new file mode 100644
>> > > > index 0000000000..1c6340afe2
>> > > > --- /dev/null
>> > > > +++ b/testsuites/psxtests/psxinttypes01/init.c
>> > > > @@ -0,0 +1,154 @@
>> > > > + *  @file
>> > > > + *  @brief Test suite for inttypes.h methods
>> > > > + * SPDX-License-Identifier: BSD-2-Clause
>> > > > + * Copyright (C) 2019, Vaibhav Gupta
>> > > > + * Redistribution and use in source and binary forms, with or without
>> > > > + * modification, are permitted provided that the following conditions
>> > > > + * are met:
>> > > > + * 1. Redistributions of source code must retain the above copyright
>> > > > + *    notice, this list of conditions and the following disclaimer.
>> > > > + * 2. Redistributions in binary form must reproduce the above copyright
>> > > > + *    notice, this list of conditions and the following disclaimer in the
>> > > > + *    documentation and/or other materials provided with the distribution.
>> > > > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
>> > > > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
>> > > > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
>> > > > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
>> > > > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> > > > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> > > > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
>> > > > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
>> > > > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
>> > > > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
>> > > > + * POSSIBILITY OF SUCH DAMAGE.
>> > > > +#ifdef HAVE_CONFIG_H
>> > > > +#include "config.h"
>> > > > +#endif
>> > > > +#include <rtems/test.h>
>> > > > +#include <inttypes.h>
>> > > > +#include <stdio.h>
>> > > > +#include <errno.h>
>> > > > +#include <tmacros.h>
>> > > > +#include <stdint.h>
>> > > > +#include <stddef.h>
>> > > > +const char rtems_test_name[] = "PSXINTTYPE 01";
>> > > > +/* forward declarations to avoid warnings */
>> > > > +rtems_task Init(rtems_task_argument ignored);
>> > > > +  int       base     = 10;
>> > > > +  char     *nptr1    = "123abc";
>> > > > +  char     *endptr1  = NULL;
>> > > > +  wchar_t  *nptr2    = L"-123junk";
>> > > > +  wchar_t  *endptr2  = NULL;
>> > > > +  intmax_t  status1;
>> > > > +  uintmax_t status2;
>> > > > +  TEST_BEGIN();
>> > > > +  puts( "\nChecking invalid base value" );
>> > > > +  rtems_test_assert( base >=2 && base <= 36 );
>> > > > +  /*Test for strtoimax  */
>> > > > +  puts( "Strtoimax Testcases...." );
>> > > > +  puts( "Generating Status" );
>> > > > +  status1 = strtoimax( nptr1, &endptr1, base );
>> > > > +  rtems_test_assert( status1 != 0);
>> > > > +  rtems_test_assert( base != EINVAL);
>> > > > +  puts( "Checking Garbage end of endptr" );
>> > > > +  rtems_test_assert( *endptr1 != '\0' );
>> > > > +  puts( "Checking Underflow Case" );
>> > > > +  rtems_test_assert( status1 >= INTMAX_MIN );
>> > > > +  puts( "Checking Overflow Case" );
>> > > > +  rtems_test_assert( status1 <= INTMAX_MAX ) ;
>> > > > +  printf( "status = %jd \n" , status1 );
>> > > > +  /*Test for strtoumax  */
>> > > > +  puts( "Strtoumax Testcases...." );
>> > > > +  status2 = strtoumax( nptr1, &endptr1, base );
>> > > > +  rtems_test_assert( status2 != 0);
>> > > > +  rtems_test_assert( status2 <= UINTMAX_MAX );
>> > > > +  printf( "status = %ju \n", status2 );
>> > > > +  /*Test for wcstoimax  */
>> > > > +  puts( "Wcstoimax Testcases...." );
>> > > > +  status1 = wcstoimax( nptr2, &endptr2, base );
>> > > > +  rtems_test_assert( *endptr2 != '\0' );
>> > > > +  printf( "status = %jd \n", status1 );
>> > > > +  /*Test for wcstoumax  */
>> > > > +  puts( "wcstoumax Testcases...." );
>> > > > +  status2 = wcstoumax( nptr2, &endptr2, base );
>> > > > +  TEST_END();
>> > > > +  rtems_test_exit(0);
>> > > > +/* NOTICE: the clock driver is explicitly disabled */
>> > > > +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>> > > > +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> > > > +#define CONFIGURE_MAXIMUM_TASKS            1
>> > > > +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> > > > +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> > > > +#include <rtems/confdefs.h>
>> > > > diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
>> > > > index 0000000000..f9e0951786
>> > > > --- /dev/null
>> > > > +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
>> > > > @@ -0,0 +1,57 @@
>> > > > + *  @file
>> > > > + *  @brief Doc for Test suite for inttypes.h methods
>> > > > + * are met:
>> > > > +This File describes the concepts tested by this test suite.
>> > > > +inttypes.h - fixed size integer types
>> > > > +test suite name: PSXINTTYPE 01
>> > > > +- Checks for invalid base value
>> > > > +- Checks for Strtoimax Testcases
>> > > > +       - checks for Garbage end of endptr
>> > > > +       - checks for Underflow Case
>> > > > +       - checks for Overflow Case
>> > > > +- Checks for Strtoumax Test Cases
>> > > > +- Checks for Wcstoimax Testcases
>> > > > +- Checks for Wcstoumax Testcases
>> > > > diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
>> > > > index 0000000000..cdd56b327d
>> > > > --- /dev/null
>> > > > +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
>> > > > @@ -0,0 +1,28 @@
>> > > > +*** PSXINTTYPE 01 TEST ***
>> > > > +Checking invalid base value
>> > > > +Strtoimax Testcases....
>> > > > +Generating Status
>> > > > +Checking Garbage end of endptr
>> > > > +Checking Underflow Case
>> > > > +Checking Overflow Case
>> > > > +status = 123
>> > > > +Strtoumax Testcases....
>> > > > +Generating Status
>> > > > +status = 123
>> > > > +Wcstoimax Testcases....
>> > > > +Generating Status
>> > > > +status = -123
>> > > > +wcstoumax Testcases....
>> > > > +Generating Status
>> > > > +status = 18446744073709551493
>> > > > +*** END OF PSXINTTYPE 01 TEST ***
>> > > > 2.21.0
