[PATCH] Add iicbus drivers to RTEMS-libbsd
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sat Jun 1 19:20:09 UTC 2019
Hello everyone,
The patch set adds the iicbus drivers to the libbsd.
- The first two patches add the iicbus drivers to libbsd.
- The third path adds a generic rtems i2c adaptation driver to the libbsd. This
will enable the libbsd applications to use the rtems-i2c drivers. This
adaptation layer has been tested on Beaglebone Black RevC.
The adaptation layer has been tested using a sample application that reads the
eeprom and prints the data to the screen.
- The last two patches add the i2c tool to the libbsd. This tool can be used to
read/write through the i2c bus. This is currently not working because the tool
lacks the transfer method used in the dirver. However, this has been fixed in
FreeBSD upstream with the following commit :
https://svnweb.freebsd.org/base?view=revision&revision=348120
I have tested the tool to be working with the i2c drivers using the above patch.
So, after the updates to libbsd this will work.
Here's a link the the sample application that I wrote outside of libbsd, this
uses the adaptation layer to read from eeprom:
https://github.com/thelunatic/rtems-bbb/tree/master/apps/i2c-adaptation-sample
Thank You,
Vijay
