[PATCH] Add Test suite for inttypes.h (psxinttypes.exe) in testsuites/psxtests
Vaibhav Gupta vaibhavgupta40 at gmail.com
Tue Jun 4 02:14:57 UTC 2019
On Tue, 4 Jun, 2019, 2:02 AM Gedare Bloom, <gedare at rtems.org> wrote:
> On Mon, Jun 3, 2019 at 8:37 AM Aditya Upadhyay <aadit0402 at gmail.com>
> wrote:
> > On Sat, Jun 1, 2019 at 10:22 PM Gedare Bloom <gedare at rtems.org> wrote:
> > > On Sat, Jun 1, 2019, 8:29 AM Aditya Upadhyay <aadit0402 at gmail.com>
> wrote:
> > >> On Sat, Jun 1, 2019 at 5:03 AM Gedare Bloom <gedare at rtems.org> wrote:
> > >> > On Fri, May 31, 2019 at 10:17 AM Aditya Upadhyay <
> aadit0402 at gmail.com> wrote:
> > >> > > Hi VARoDeK,
> > >> > > This looks fine to me. I would love to see other's responses.
> > >> > This test is not right, it needs to be rethought. Let me know if you
> > >> > need further guidance.
> > >> Yeah, Gedare !! I need some further guidance. I had written this test
> > >> 1 year ago, but could not send it on devel.
> > >> I was writing this testsuite for the very first time.
> > > If you wrote the test, your name should belong in the copyright info.
> > I had handed over this code to Vaibhav for sake of learning purposes.
> > If Community
> > does not allow this, Then I would take it back. I would appreciate
> > your thought on that.
> It is perfectly acceptable (and normal) for a student to carry-on with
> someone else's code, but the original author's contribution (and
> copyright) need to be maintained.  Usually, what we prefer is to have
> a commit with the original author's code, and then additional commits
> to change it as needed.
Yes, actually we discussed about same, and then he asked me to add my name
as i was going to send it to devel. Things were new for me too. I will put
his name only now on copyright info.
> > >> Could you please point me an example?
> > > Which psxtest was this derived from? Is there a psxtest that considers
> string conversions? That would be a good start. Do some digging.
> > Thanks for pointing it out. Though I am working on a needed
> > correction. Would It be a wise choice to test cases
> > for each inttypes methods?
> > > The logic of the test needs to be thought out. What is the expected
> behavior being tested? How do you isolate correct/incorrect behavior?
> > I had used hardcoded input only for the success of the operation. I
> > will also consider the expected behavior for Invalid inputs.
> > > Gedare
> > >> Although I have gone through
> > >> open group POSIX
> > >> Page and looked into some previously made testsuites in the psxtests
> directory.
> > >> While configuring, I had used --enable-tests=yes option, but I do not
> > >> see any generated .exe file.
> > >> or Can we generate the .exe file manually?
> > >> > > On Thu, May 30, 2019 at 8:47 PM VARoDeK <vaibhavgupta40 at gmail.com>
> wrote:
> > >> > > >  testsuites/psxtests/Makefile.am               |   7 +
> > >> > > >  testsuites/psxtests/configure.ac              |   1 +
> > >> > > >  testsuites/psxtests/psxinttypes01/init.c      | 154
> > >> > > >  .../psxtests/psxinttypes01/psxinttypes01.doc  |  57 +++++++
> > >> > > >  .../psxtests/psxinttypes01/psxinttypes01.scn  |  28 ++++
> > >> > > >  5 files changed, 247 insertions(+)
> > >> > > >  create mode 100644 testsuites/psxtests/psxinttypes01/init.c
> > >> > > >  create mode 100644
> testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> > >> > > >  create mode 100644
> testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> > >> > > > diff --git a/testsuites/psxtests/Makefile.am
> b/testsuites/psxtests/Makefile.am
> > >> > > > index 749258cc0c..f619dd9ae9 100644
> > >> > > > --- a/testsuites/psxtests/Makefile.am
> > >> > > > +++ b/testsuites/psxtests/Makefile.am
> > >> > > > @@ -22,6 +22,13 @@ psx01_CPPFLAGS = $(AM_CPPFLAGS)
> $(TEST_FLAGS_psx01) \
> > >> > > >         $(support_includes) -I$(top_srcdir)/include
> > >> > > >  endif
> > >> > > > +if TEST_psxinttypes01
> > >> > > > +psx_tests += psxinttypes01
> > >> > > > +psxinttypes01_SOURCES = psxinttypes01/init.c
> > >> > > > +psxinttypes01_CPPFLAGS = $(AM_CPPFLAGS)
> $(TEST_FLAGS_psxinttypes01) \
> > >> > > > +       $(support_includes)
> > >> > > > +endif
> > >> > > >  if HAS_POSIX
> > >> > > >  if TEST_psx02
> > >> > > >  psx_tests += psx02
> > >> > > > diff --git a/testsuites/psxtests/configure.ac
> b/testsuites/psxtests/configure.ac
> > >> > > > index cdd6ee7e4e..e032a6f5ec 100644
> > >> > > > --- a/testsuites/psxtests/configure.ac
> > >> > > > +++ b/testsuites/psxtests/configure.ac
> > >> > > > @@ -140,6 +140,7 @@ RTEMS_TEST_CHECK([psxtimes01])
> > >> > > >  RTEMS_TEST_CHECK([psxualarm])
> > >> > > >  RTEMS_TEST_CHECK([psxusleep])
> > >> > > >  RTEMS_TEST_CHECK([lib_a])
> > >> > > > +RTEMS_TEST_CHECK([psxinttypes01])
> > >> > > >  AC_CONFIG_FILES([Makefile])
> > >> > > >  AC_OUTPUT
> > >> > > > diff --git a/testsuites/psxtests/psxinttypes01/init.c
> b/testsuites/psxtests/psxinttypes01/init.c
> > >> > > > new file mode 100644
> > >> > > > index 0000000000..1c6340afe2
> > >> > > > --- /dev/null
> > >> > > > +++ b/testsuites/psxtests/psxinttypes01/init.c
> > >> > > > @@ -0,0 +1,154 @@
> > >> > > > + *  @file
> > >> > > > + *  @brief Test suite for inttypes.h methods
> > >> > > > + * SPDX-License-Identifier: BSD-2-Clause
> > >> > > > + * Copyright (C) 2019, Vaibhav Gupta
> > >> > > > + * Redistribution and use in source and binary forms, with or
> without
> > >> > > > + * modification, are permitted provided that the following
> conditions
> > >> > > > + * are met:
> > >> > > > + * 1. Redistributions of source code must retain the above
> copyright
> > >> > > > + *    notice, this list of conditions and the following
> disclaimer.
> > >> > > > + * 2. Redistributions in binary form must reproduce the above
> copyright
> disclaimer in the
> > >> > > > + *    documentation and/or other materials provided with the
> distribution.
> > >> > > > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
> CONTRIBUTORS "AS IS"
> > >> > > > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
> LIMITED TO, THE
> > >> > > > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
> PARTICULAR PURPOSE
> > >> > > > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > >> > > > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
> EXEMPLARY, OR
> > >> > > > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
> PROCUREMENT OF
> > >> > > > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
> PROFITS; OR BUSINESS
> > >> > > > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
> LIABILITY, WHETHER IN
> > >> > > > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
> OR OTHERWISE)
> > >> > > > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
> ADVISED OF THE
> > >> > > > + * POSSIBILITY OF SUCH DAMAGE.
> > >> > > > +#ifdef HAVE_CONFIG_H
> > >> > > > +#include "config.h"
> > >> > > > +#endif
> > >> > > > +#include <rtems/test.h>
> > >> > > > +#include <inttypes.h>
> > >> > > > +#include <stdio.h>
> > >> > > > +#include <errno.h>
> > >> > > > +#include <tmacros.h>
> > >> > > > +#include <stdint.h>
> > >> > > > +#include <stddef.h>
> > >> > > > +const char rtems_test_name[] = "PSXINTTYPE 01";
> > >> > > > +/* forward declarations to avoid warnings */
> > >> > > > +rtems_task Init(rtems_task_argument ignored);
> > >> > > > +  int       base     = 10;
> > >> > > > +  char     *nptr1    = "123abc";
> > >> > > > +  char     *endptr1  = NULL;
> > >> > > > +  wchar_t  *nptr2    = L"-123junk";
> > >> > > > +  wchar_t  *endptr2  = NULL;
> > >> > > > +  intmax_t  status1;
> > >> > > > +  uintmax_t status2;
> > >> > > > +  TEST_BEGIN();
> > >> > > > +  puts( "\nChecking invalid base value" );
> > >> > > > +  rtems_test_assert( base >=2 && base <= 36 );
> > >> > > > +  /*Test for strtoimax  */
> > >> > > > +  puts( "Strtoimax Testcases...." );
> > >> > > > +  puts( "Generating Status" );
> > >> > > > +  status1 = strtoimax( nptr1, &endptr1, base );
> > >> > > > +  rtems_test_assert( status1 != 0);
> > >> > > > +  rtems_test_assert( base != EINVAL);
> > >> > > > +  puts( "Checking Garbage end of endptr" );
> > >> > > > +  rtems_test_assert( *endptr1 != '\0' );
> > >> > > > +  puts( "Checking Underflow Case" );
> > >> > > > +  rtems_test_assert( status1 >= INTMAX_MIN );
> > >> > > > +  puts( "Checking Overflow Case" );
> > >> > > > +  rtems_test_assert( status1 <= INTMAX_MAX ) ;
> > >> > > > +  printf( "status = %jd \n" , status1 );
> > >> > > > +  /*Test for strtoumax  */
> > >> > > > +  puts( "Strtoumax Testcases...." );
> > >> > > > +  status2 = strtoumax( nptr1, &endptr1, base );
> > >> > > > +  rtems_test_assert( status2 != 0);
> > >> > > > +  rtems_test_assert( status2 <= UINTMAX_MAX );
> > >> > > > +  printf( "status = %ju \n", status2 );
> > >> > > > +  /*Test for wcstoimax  */
> > >> > > > +  puts( "Wcstoimax Testcases...." );
> > >> > > > +  status1 = wcstoimax( nptr2, &endptr2, base );
> > >> > > > +  rtems_test_assert( *endptr2 != '\0' );
> > >> > > > +  printf( "status = %jd \n", status1 );
> > >> > > > +  /*Test for wcstoumax  */
> > >> > > > +  puts( "wcstoumax Testcases...." );
> > >> > > > +  status2 = wcstoumax( nptr2, &endptr2, base );
> > >> > > > +  TEST_END();
> > >> > > > +  rtems_test_exit(0);
> > >> > > > +/* NOTICE: the clock driver is explicitly disabled */
> > >> > > > +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> > >> > > > +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> > >> > > > +#define CONFIGURE_MAXIMUM_TASKS            1
> > >> > > > +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > >> > > > +#define CONFIGURE_INITIAL_EXTENSIONS
> RTEMS_TEST_INITIAL_EXTENSION
> > >> > > > +#include <rtems/confdefs.h>
> > >> > > > diff --git
> a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> > >> > > > index 0000000000..f9e0951786
> > >> > > > --- /dev/null
> > >> > > > +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> > >> > > > @@ -0,0 +1,57 @@
> > >> > > > + *  @file
> > >> > > > + *  @brief Doc for Test suite for inttypes.h methods
> without
> conditions
> > >> > > > + * are met:
> copyright
> disclaimer.
> copyright
> disclaimer in the
> distribution.
> LIMITED TO, THE
> PARTICULAR PURPOSE
> CONTRIBUTORS BE
> EXEMPLARY, OR
> PROCUREMENT OF
> OR OTHERWISE)
> ADVISED OF THE
> > >> > > > +This File describes the concepts tested by this test suite.
> > >> > > > +inttypes.h - fixed size integer types
> > >> > > > +test suite name: PSXINTTYPE 01
> > >> > > > +- Checks for invalid base value
> > >> > > > +- Checks for Strtoimax Testcases
> > >> > > > +       - checks for Garbage end of endptr
> > >> > > > +       - checks for Underflow Case
> > >> > > > +       - checks for Overflow Case
> > >> > > > +- Checks for Strtoumax Test Cases
> > >> > > > +- Checks for Wcstoimax Testcases
> > >> > > > +- Checks for Wcstoumax Testcases
> > >> > > > diff --git
> a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> > >> > > > index 0000000000..cdd56b327d
> > >> > > > --- /dev/null
> > >> > > > +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> > >> > > > @@ -0,0 +1,28 @@
> > >> > > > +*** PSXINTTYPE 01 TEST ***
> > >> > > > +Checking invalid base value
> > >> > > > +Strtoimax Testcases....
> > >> > > > +Generating Status
> > >> > > > +Checking Garbage end of endptr
> > >> > > > +Checking Underflow Case
> > >> > > > +Checking Overflow Case
> > >> > > > +status = 123
> > >> > > > +Strtoumax Testcases....
> > >> > > > +Generating Status
> > >> > > > +status = 123
> > >> > > > +Wcstoimax Testcases....
> > >> > > > +Generating Status
> > >> > > > +status = -123
> > >> > > > +wcstoumax Testcases....
> > >> > > > +Generating Status
> > >> > > > +status = 18446744073709551493
> > >> > > > +*** END OF PSXINTTYPE 01 TEST ***
> > >> > > > 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190604/69088682/attachment-0002.html>
