GSoC Project | Basic Support for Trace Compass
Tue Jun 11 06:29:29 UTC 2019
Hello Ravindra,
thanks for the update.
On 11/06/2019 08:18, Ravindra Kumar Meena wrote:
> Plan for the week:
> 1. Update the event recording documentation(sent the patches)
> 2. Build a custom converter that can transform TCP streams and files
> with record items into CTF.
> For 2nd point of the plan, we have to write the decoder(source plugin).
> This would involve understanding the current rtems trace format
With "rtems trace format" I guess you mean the format used by the Event
Recording. Could you please elaborate this a bit more what you mean with
understanding. The format is very simple. It is just a timestamp, an
event number and some event specific data.
Getting timestamps in CLOCK_MONOTONIC nanosecond values is a bit tricky,
however, this is already handled by the client:
https://github.com/rmeena840/rtems-tools/commit/0a279786b73197973dc8a5a5f7818a7669714216
Did you already work on a TSDL description of the format?
and
> codebase. I will also try out the decoder(source plugin) example shared
> by the babeltrace community.
Ok.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
