PlantUML and rtems-docs
Tue Jun 11 08:29:42 UTC 2019
On 11/6/19 4:57 pm, Sebastian Huber wrote:
> Hello,
> I built the rtems-docs with the following configuration:
> ./waf configure --pdf --plantuml
> It rebuilt several *.png files:
> Changes not staged for commit:
>   (use "git add <file>..." to update what will be committed)
>   (use "git checkout -- <file>..." to discard changes in working directory)
>         modified:   images/user/exe-app.png
>         modified:   images/user/exe-vert-stack.png
>         modified:   images/user/libdl-load.png
>         modified:   images/user/test-cfg-1.png
>         modified:   images/user/test-cfg-2.png
>         modified:   images/user/test-gdb-jtag.png
>         modified:   images/user/test-simulation.png
>         modified:   images/user/test-tftp-seq-1.png
>         modified:   images/user/test-tftp-seq-2.png
>         modified:   images/user/test-tftp-seq-3.png
>         modified:   images/user/test-tftp-seq-4.png
>         modified:   images/user/test-tftp.png
> Is this expected?
Unfortunately I think it is. If there are other better solutions I would welcome
them.
I think we need to have images in the repo as platforms like MacOS do not have
OS packages that can provide the needed tools. I cannot see an easy solution.
