PlantUML and rtems-docs
Tue Jun 11 09:33:52 UTC 2019
On 11/6/19 7:11 pm, Sebastian Huber wrote:
> On 11/06/2019 10:27, Sebastian Huber wrote:
>> On 11/06/2019 10:21, Chris Johns wrote:
>>> On 11/6/19 5:04 pm, Sebastian Huber wrote:
>>>> I noticed also that we don't use the sphinxcontrib-plantuml extension:
>>>> https://pypi.org/project/sphinxcontrib-plantuml/
>>>> Should we use it? It would enable the use of images in *.pdf format for the
>>>> Latex output. The PNGs are quite ugly in the Latex output.
>>> Sure, it looks good. Does it support ditaa?
>> I had some problems to set it up. It didn't work with the Node.js "puml"
>> command. I had to use the Java archive. I didn't test the ditaa input so far.
> Using this extension forces you to install PlantUML and its dependencies to
> build the documentation. Also debugging problems in the PlantUML content is not
> that great.
Ok and thanks.
> Maybe we should concentrate on fixing the *.puml -> *.png generation so that it
> is not always updated and doesn't depend on timestamps.
I think Waf uses a hash on files.
> We should also generate *.pdf files for the Latex output.
Sure.
