GSoC Project | Basic Support for Trace Compass
Tue Jun 18 07:19:01 UTC 2019
On 18/06/2019 08:55, Ravindra Kumar Meena wrote:
>      > About a week ago I raised a query on decoder(source plugin) examples
>      > shared by them.
>      > They suggested that if we plan to use Babeltrace 2 plugin system,
>     the
>      > metadata file
>      > will be generated based on the trace representation given by the
>     source
>      > plugin.
>      > https://lists.lttng.org/pipermail/lttng-dev/2019-June/029057.html
>      > Please have a look
>     Yes, this is why I asked about a TSDL description last week:
>     https://lists.rtems.org/pipermail/devel/2019-June/026101.html
>     Creating the metadata is one of the first actions a plugin must do
> Okay.
> I sent you one metadata file which had 1160 events. So should I add the
> rtems 512 events in metadata?
At the moment a detailed description of individual events is not
necessary. We have to get the basics in place first. So for now an 10
bit event number is enough.
> The problem I am facing here is how to relate the metadata file with
> rtems event record item?
This depends on what you want to do. It seems the babeltrace plugin is a
bit too complex to write at the moment. Maybe we should start with
something simpler.
The record client in your rtems-tools repository does the following:
target --> TCP stream with struct rtems_record_items -> client ->
conversion -> human readable text
We should turn this into:
conversion -> CTF (metadata + event stream) -> files -> babeltrace ->
human readable text
So the first thing we have to figure out is how babeltrace reads an
arbitrary CTF session (metadata + event stream).
The next thing is to look at and modify print_item() in
misc/record/record-main.c. In this function you get one client_item
after another.
typedef struct client_item {
   union {
     SLIST_ENTRY( client_item ) free_node;
     RB_ENTRY( client_item )    active_node;
   uint64_t                     ns;
   uint32_t                     cpu;
   rtems_record_event           event;
   uint64_t                     data;
   uint64_t                     counter;
} client_item;
We are only interested in ns, cpu, event and data. So just convert this to
typedef struct {
   uint64_t                     ns;
   uint32_t                     cpu;
   uint64_t                     data;
} ctf_event;
and append this item into a file (the event stream file). For this
ctf_event you need a TSDL metadata. Save this metadata file.
Import the metadata and event stream in babeltrace and let it print a
human readable form.
Does this look like something you can do?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
