Add newlib patch to RTEMS RSB
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Fri Jun 21 15:55:50 UTC 2019
On Fri, Jun 21, 2019, 9:19 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Jun 21, 2019 at 2:37 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
> > Hello,
> > I figured it out.
> > Below is the output given by shell
> > config: tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg
> > warning: rtems-gcc-7.4.0-newlib-1d35a003f.cfg:29: invalid format:
> '%setup patch newlib -p'
> > error: gcc-common-1.cfg:80: %patch already setup source: newlib -p1
> > Build FAILED
> > Build Set: Time 0:06:29.257451
> > Build FAILED
> > I realized, the name of group of my patch and the source of
> newlib-source was same in rtems-gcc-7.4.0-newlib-1d35a003f.cfg.
> Also, I had put "%patch setup" statement before "%patch add" .
> This seems odd. The "rules" around patching need to be clarified in
> the documentation.
If there is some technical modification, I am not sure. But some steps are
missing. After successful port and testsuite, I will update the
documentation.
> > Here is the new git-diff. This got compiled successfully
> > diff --git a/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg
> b/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg
> > index b28a4b1..5c5c346 100644
> > --- a/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg
> > +++ b/rtems/config/tools/rtems-gcc-7.4.0-newlib-1d35a003f.cfg
> > @@ -23,6 +23,11 @@
> > %source set newlib --rsb-file=newlib-%{newlib_version}.tar.gz
> https://codeload.github.com/RTEMS/sourceware-mirror-newlib-cygwin/tar.gz/%{newlib_version}
> > %hash sha512 newlib-%{newlib_version}.tar.gz
> eb5943b207eca05fde4497c29491bbd3d07624e4becb410640ae8e177bd9212ca06cf726ee3882d6db5758cd03daf1462715e4b9b404abcc8f7cee5f811fd48b
> > +%patch add newlib_ndbm file://0001-Port-ndbm.patch
> > +%hash sha512 0001-Port-ndbm.patch
> 0e05d97d0a6f8a436a233fe4fb3cbda7c0cfeab11cfda1c155d8aa5b80289f386896b0e8c28e5858e1d7409fd22c8d1cbaaccb181bc376845fe6d50b16359db6
> > +%patch setup newlib_ndbm -p1
> > %define isl_version 0.16.1
> > %hash sha512 isl-%{isl_version}.tar.bz2
> c188667a84dc5bdddb4ab7c35f89c91bf15a8171f4fcaf41301cf285fb7328846d9a367c096012fec4cc69d244f0bc9e95d84c09ec097394cd4093076f2a041b
> > @@ -40,3 +45,4 @@
> > %define with_iconv 1
> > %include %{_configdir}/gcc-7.2-1.cfg
> > On Fri, Jun 21, 2019 at 4:25 AM Chris Johns <chrisj at rtems.org> wrote:
> >> On 21/6/19 4:43 am, Gedare Bloom wrote:
> >> > On Thu, Jun 20, 2019 at 11:32 AM Vaibhav Gupta <
> vaibhavgupta40 at gmail.com> wrote:
> >> >> + /bin/cat
> /home/varodek/development/rtems/rsb/rtems/patches/0001-Port-ndbm.patch
> >> >> + /usr/bin/patch -p3
> >> > This is the problem, the -p3 is wrong. I don't know where this is
> >> > coming from though.
> >> This must be from a `%patch` statement. The RSB has no preset patch
> options and
> >> there is no `-p3` in my repo.
> >> I suggest you run with --trace and then look at the macro maps to see
> where is
> >> it is coming from.
> >> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190621/749532bc/attachment-0001.html>
