GSoC Project | Basic Support for Trace Compass
Mon Jun 24 17:38:02 UTC 2019
----- Am 24. Jun 2019 um 19:17 schrieb Sebastian Huber sebastian.huber at embedded-brains.de:
> ----- Am 24. Jun 2019 um 18:46 schrieb Ravindra Kumar Meena rmeena840 at gmail.com:
>> *24th June work summary:*
>> Studied the CTF documentation and tried its example. Tried to modify the
>> HEX values of the stream file generated by the QEMU target. Improved the
>> metadata file.
> Could you please keep your rtems-tools repository up to date. When you say you
> improved the metadata I would like to see this in the repository with a proper
> commit message.
To be able to better reproduce issues, could you please:
1. record a raw record item stream produced by the Qemu target via the nc tool in a file (not more than 100KiB)
2. add this file to rtems-tools
3. modify the record-client program to read from a file if a --input=<FILE> command line option is given
Is this task clear enough for you?
