GSoC Project | Basic Support for Trace Compass
Mon Jun 24 20:02:26 UTC 2019
On Mon, Jun 24, 2019 at 11:38 AM Sebastian Huber
> ----- Am 24. Jun 2019 um 19:17 schrieb Sebastian Huber sebastian.huber at embedded-brains.de:
> > ----- Am 24. Jun 2019 um 18:46 schrieb Ravindra Kumar Meena rmeena840 at gmail.com:
> >> *24th June work summary:*
> >> Studied the CTF documentation and tried its example. Tried to modify the
> >> HEX values of the stream file generated by the QEMU target. Improved the
> >> metadata file.
> > Could you please keep your rtems-tools repository up to date. When you say you
> > improved the metadata I would like to see this in the repository with a proper
> > commit message.
> To be able to better reproduce issues, could you please:
> 1. record a raw record item stream produced by the Qemu target via the nc tool in a file (not more than 100KiB)
> 2. add this file to rtems-tools
> 3. modify the record-client program to read from a file if a --input=<FILE> command line option is given
What is the command line entry point for record-client program?
> Is this task clear enough for you?
> devel mailing list
> devel at rtems.org
