GSoC Project | Basic Support for Trace Compass
Ravindra Kumar Meena rmeena840 at gmail.com
Tue Jun 25 05:12:54 UTC 2019
> Since the magic number is optional, you should see if you can
> construct a simple example metadata and stream file that does not use
> the magic number and whether it works with babeltrace or not.
Okay. It worked without magic number. I removed the magic number from both
metadata and stream file.
The babeltrace was able to read the events.
Thanks
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190625/4a88fc0e/attachment.html>
