GSoC Project | Basic Support for Trace Compass
Tue Jun 25 05:21:14 UTC 2019
On 25/06/2019 07:11, Ravindra Kumar Meena wrote:
> Hi Sebastian,
> I have sent the two patches. One is event stream file generation patch
> and another one is metadata for it. Please apply the patches.
Could you please check it in your rtems-tools repository.
> Run the following command for like 5 seconds so that it can generate
> enough event traces.
> ./build/misc/rtems-record -H 169.254.192.22 -p 1234 | head
Please change the record client to use a file in the repository. So that
we can test with the same data and without the need to run Qemu.
> you will get file named event in folder "rtems-tools". The metadata file
> is in "misc/ctf/metadata". Please move the event stream file in it.
> Now, run "babeltrace ctf/" command. Here "ctf" is folder name containing
> event stream file and metadata.
> Now you will be able to see that babeltrace is able to read the events.
> I have cross-checked the the values it is printing. All
> values(ns,cpu,data) are correct accept the value of
> events(rtems_record_event).
> I am currently figuring out why rtems_record_event is giving wrong value.
Ok, good. Nice progress.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
