GSoC Project | Basic Support for Trace Compass
Ravindra Kumar Meena
rmeena840 at gmail.com
Tue Jun 25 05:11:12 UTC 2019
Hi Sebastian,
I have sent the two patches. One is event stream file generation patch and
another one is metadata for it. Please apply the patches.
Run the following command for like 5 seconds so that it can generate enough
event traces.
./build/misc/rtems-record -H 169.254.192.22 -p 1234 | head
you will get file named event in folder "rtems-tools". The metadata file is
in "misc/ctf/metadata". Please move the event stream file in it.
Now, run "babeltrace ctf/" command. Here "ctf" is folder name containing
event stream file and metadata.
Now you will be able to see that babeltrace is able to read the events.
I have cross-checked the the values it is printing. All values(ns,cpu,data)
are correct accept the value of events(rtems_record_event).
I am currently figuring out why rtems_record_event is giving wrong value.
Thanks
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190625/d58e1d1f/attachment.html>
