GSoC Project | Basic Support for Trace Compass
Thu Jun 27 06:21:14 UTC 2019
On 27/06/2019 08:15, Ravindra Kumar Meena wrote:
> On Thu, Jun 27, 2019 at 10:53 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 26/06/2019 17:58, Ravindra Kumar Meena wrote:
>      > 26th June Work Summary:
>      > Updated the file generation code in rtems-tools with required
>     changes.
>      > Improved the metadata for the same. I have squashed the commits.
>     https://github.com/rmeena840/rtems-tools/commit/c0035feab6d99b4aeecdd0d76b049f3e2c7aa9ef
>     https://github.com/rmeena840/rtems-tools/commit/f68b5031f4e6f847239effe677701635316b12fb
>      > Attended the weekly meeting on Freenode.
>     Could you please start a new thread for each daily summary. Please also
>     don't squash the commits in your development branch. The squashing
>     makes
>     it difficult to track your work. We can do a big squash before we
>     integrate the stuff into the upstream rtems-tools.
>     How is the progress with this task:
>     https://lists.rtems.org/pipermail/devel/2019-June/026306.html
>     My time estimate for this is about one day for you. An experienced C
>     developer can do this in less than 30 minutes.
> Is there a way to set the file size for which nc should output? I can
> get around minimum 500KB of file.
> I am following this
> https://linux.die.net/man/1/nc
You can use dd to reduce the file size, e.g.
dd if=input-file of=output-file count=131072
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
