GSoC Project | Basic Support for Trace Compass
Thu Jun 27 07:02:33 UTC 2019
On 27/06/2019 08:58, Ravindra Kumar Meena wrote:
>      > Is there a way to set the file size for which nc should output? I
>     can
>      > get around minimum 500KB of file.
>      > I am following this
>      > https://linux.die.net/man/1/nc
>     You can use dd to reduce the file size, e.g.
>     dd if=input-file of=output-file count=131072
> Okay. It worked. I have placed it in mis/record directory.
> It is a binary file. So I directly made a push to my GitHub rtems-tools
> repository workplace.
> https://github.com/rmeena840/rtems-tools/commit/70d527dcf8ae8a5026dd1af79e4d27c5adcbdade
> Have a look.
For whatever reason this file has only 98304 bytes. The content looks
all right. So, the next step is to modify the client so that it can read
from a file instead of the TCP stream.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
