[PATCH 1/4] rootfs: Improve the support to build a tar file.
chrisj at rtems.org
chrisj at rtems.org
Sun Jun 30 01:54:13 UTC 2019
rootfs.py | 111 ++++++++++++++++++++++++++++++++++++++++++++++++------
1 file changed, 100 insertions(+), 11 deletions(-)
diff --git a/rootfs.py b/rootfs.py
index 26c2d1b..6fef0e4 100644
--- a/rootfs.py
+++ b/rootfs.py
@@ -24,14 +24,32 @@
# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
# OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
-def tar(ctx, name, target, root):
- top = ctx.path.get_src().find_node(root)
- source = ctx.path.get_src().ant_glob(root + '/**')
- ctx(rule = 'tar -C %s -cf ${TGT} .' % (top),
+import os
+def join(*paths):
+ path = ''
+ for p in paths:
+ path = os.path.join(path, str(p))
+ return path
+def copy(ctx, name, root, target, source):
+ '''Copy a file from the source to the target.'''
+ if isinstance(target, str):
+ target = ctx.path.make_node(target)
+ #print('copy: name=%s source=%s target=%s' % (name, source, target))
+ ctx(rule = 'cp ${SRC} ${TGT}',
+ name = name,
+ source = source,
+ target = target)
+def tar(ctx, name, root, target, source, depends_on):
+ #print('tar: name=%s root=%s target=%r source=%r' % (name, root, target, source))
+ ctx(rule = 'tar -C %s -cf ${TGT} .' % (root),
name = name,
target = target,
source = source,
- root = root,
+ root = join(ctx.path.get_bld(), root),
+ depends_on = depends_on,
color = 'CYAN')
def bin2c(ctx, name, target, source):
@@ -41,14 +59,85 @@ def bin2c(ctx, name, target, source):
source = source,
color = 'PINK')
-def build(bld, name, root):
- """ The source is the C file that includes the header file."""
- tar(bld,
+def build(ctx, name, root, files):
+ """The files are truples of the name, source and target files to put in the tar
+ file. The truple is (name, src, dst). The src is the absolute path to the
+ source and the dst is the path on the target.
+ The tar file will contain the files defined by the dst paths. These are
+ copied into the build path under the tar file's root path. Make sure the
+ desination paths are relative to the root of the tar file.
+ For example:
+ import rtems_waf.rootfs as rtems_rootfs
+ tar_files = [('shell-init', ''shell-init', 'shell-init'),
+ ('rc-conf', 'rc.conf', 'etc/rc.conf')]
+ rtems_rootfs.build(ctx, 'fs-root', 'rootfs', tar_files)
+ # The files must be a list of tuples.
+ if not isinstance(files, list):
+ ctx.fatal('rootfs build files is not a list')
+ root_abspath = join(ctx.path.get_bld().abspath(), root)
+ for f in files:
+ # Check each item in the list is a tuple with 3 elements.
+ if not isinstance(f, tuple):
+ ctx.fatal('rootfs build file is not a tuple')
+ if len(f) != 3:
+ ctx.fatal('rootfs build file tuple has 3 items (name, src, dst): %s' % (str(f)))
+ # Copy the file as a build task. The file is copied to the tar file's
+ # root.
+ #print(']]', ctx.path.make_node(join(root, f[2])).get_bld())
+ if isinstance(f[1], str):
+ source = ctx.path.make_node(f[1]).get_src()
+ else:
+ source = f[1]
+ copy(ctx,
+ name = f[0],
+ root = root,
+ target = ctx.path.make_node(join(root, f[2])).get_bld(),
+ source = source)
+ ctx.add_group()
+ # Tar build task.
+ tar(ctx,
name = name + '-tar',
target = name + '.tar',
- root = root)
- bin2c(bld,
+ source = [join(root, f[2]) for f in files],
+ depends_on = [f[0] for f in files])
+ ctx.add_group()
+ # Binary to C build task. It converts the tar file to a C file. This uses
+ # the RTEMS Tools Project's `bin2c` command.
+ bin2c(ctx,
name = name,
target = name + '-tar.c',
source = name + '.tar')
- bld.add_group()
+ ctx.add_group()
+ ctx.objects(features = 'c',
+ target = name + '-obj',
+ source = name + '-tar.c')
+def build_from_src_root(ctx, name, root):
+ root_path = ctx.path.make_node(root)
+ if not root_path.exists():
+ ctx.fatal('tar root not found: %s' % (root_path))
+ sources = [s.path_from(root_path) for s in root_path.ant_glob('**')]
+ build(ctx, name, root, [('%s-%s' % (name, os.path.basename(s)),
+ join(root, s), s) for s in sources])
2.20.1 (Apple Git-117)
