RSB SPARC gdb 8.2.1 Build Issue on MSYS2 (64-bit)
Joel Sherrill
joel at rtems.org
Tue Jun 4 22:36:43 UTC 2019
On Tue, Jun 4, 2019 at 4:13 PM Jiri Gaisler <jiri at gaisler.se> wrote:
> On 6/4/19 12:59 AM, Joel Sherrill wrote:
> > Hi
> > I was trying to build the sparc tools on MSYS2 today. SIS was enabled
> > by default and failed to build.
> > Is it expected to build?
> > Is it supposed to be disabled and the host is not properly detected by
> > the RSB?
> > Not sure which way to push on the fix.
> Did you catch any specific error output from the build?
I didn't save it but recall something used uint as a type and it was
undefined.
> Maybe it is time to switch to the standalone sis - it does build/work on
> msys2 (but has the same ctrl-c limitation as cygwin).
It would be nice to get this into the sparc RSB recipe. :)
> Jiri.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190604/5cc33769/attachment-0002.html>
