[PATCH] adding basic support for trace compass
Ravindra Kumar Meena rmeena840 at gmail.com
Thu Jun 6 11:09:59 UTC 2019
Hi Sebastian, Chris
I created the Image online on https://www.draw.io/. Is it necessary to use
Ditaa and PlantUML?
Thanks
On Thu, Jun 6, 2019 at 4:13 PM Chris Johns <chrisj at rtems.org> wrote:
> On 6/6/19 8:03 pm, Sebastian Huber wrote:
> > Hello Chris,
> > On 06/06/2019 11:54, Ravindra Meena wrote:
> >>   create mode 100644 images/user/event-recording-trace.png
> > what is the desired way to include new images in the documentation?
> Should we
> > try to use PlantUML if possible?
> https://git.rtems.org/rtems-docs/tree/README.txt#n45 ? :)
> Ditaa and PlantUML can be used. I think they are pretty good and let us
> create
> reasonable images quickly and in an open way.
> There are real examples in the User manual. You can see the source here
> https://git.rtems.org/rtems-docs/tree/images/user.
> I cover installing the tools on FreeBSD and Joel has added CentOS.
> I cannot remember what happens with git when regenerating the images. I
> suggest
> only adding the ones you create and add them. We add the .png files to
> avoid
> everyone needing to install the tools to generate them.
> Chris
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190606/183f5eb3/attachment-0002.html>
