[PATCH 2/2] sparc: Fix mistakenly cleared PSR[EF] bit.
Maksim Kozlov maksim.e.kozlov at gmail.com
Thu Jun 6 12:43:06 UTC 2019
On Thu, 6 Jun 2019 at 09:57, Sebastian Huber <
> On 05/06/2019 21:22, Maksim E. Kozlov wrote:
> >   cpukit/score/cpu/sparc/cpu_asm.S | 3 ++-
> >   1 file changed, 2 insertions(+), 1 deletion(-)
> > diff --git a/cpukit/score/cpu/sparc/cpu_asm.S
> b/cpukit/score/cpu/sparc/cpu_asm.S
> > index 2f3ad24510..69bbfb2748 100644
> > --- a/cpukit/score/cpu/sparc/cpu_asm.S
> > +++ b/cpukit/score/cpu/sparc/cpu_asm.S
> > @@ -682,10 +682,11 @@ isr_dispatch:
> >           ld      [%g6 + SPARC_PER_CPU_FP_OWNER_OFFSET], %l7
> >           cmp     %l6, %l7
> >           bne     .Ldisable_fp
> > -         andn   %l0, %l5, %l0
> > +         nop
> Wouldn't it be sufficient to change this to
> bne,a .Ldisable_fp
>   andn %l0, %l5, %l0
Yes, you are right, this is my inattentiveness, and it is enough just to set
an annul flag.
If it is needed, I attached modified patch, but if you prefer, you can just
add
this flag yourself.
MK
> >           ba      .Lthread_dispatch_done
> >            st     %g0, [%g6 + SPARC_PER_CPU_FP_OWNER_OFFSET]
> >   .Ldisable_fp:
> > +        andn   %l0, %l5, %l0
> >            st      %l0, [%fp + ISF_PSR_OFFSET]
> >   .Lnon_fp_thread_dispatch:
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190606/38c59e14/attachment-0002.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190606/38c59e14/attachment-0002.bin>
