[PATCH v2] RTEMS Boot Image, tool to create SD card images
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon Jun 10 10:17:06 UTC 2019
Hello Chris,
I'm getting the following error in python3.7:
rtems-tools $>./misc/rtems-boot-image -b u-boot-beaglebone -o .
$HOME/myimage
RTEMS Tools - Boot Image, 5 (881f7419784e modified)
Traceback (most recent call last):
File "./misc/tools/cmd-boot-image.py", line 41, in <module>
boot.run(sys.argv[1:], command_path = base)
File "/home/lunatic/development/rtems/rtems-tools/misc/tools/boot.py",
line 1020, in run
argopts.board)
line 282, in __init__
super(uboot_config, self).__init__(command_path, 'u-boot')
line 133, in __init__
self.load_config(bootloader, boot_ini)
line 292, in load_config
super(uboot_config, self).load_config(bootloader, config)
line 192, in load_config
for i in self.config.get_items(s):
File
"/home/lunatic/development/rtems/rtems-tools/rtemstoolkit/configuration.py",
line 131, in get_items
for name, value in self.config.items(section, raw = self.raw):
File "/usr/lib64/python3.7/configparser.py", line 857, in items
return [(option, value_getter(option)) for option in d.keys()]
File "/usr/lib64/python3.7/configparser.py", line 857, in <listcomp>
File "/usr/lib64/python3.7/configparser.py", line 854, in <lambda>
section, option, d[option], d)
File "/usr/lib64/python3.7/configparser.py", line 394, in before_get
self._interpolate_some(parser, option, L, value, section, defaults, 1)
File "/usr/lib64/python3.7/configparser.py", line 444, in
_interpolate_some
"found: %r" % (rest,))
configparser.InterpolationSyntaxError: '%' must be followed by '%' or '(',
found: '%{arch}-rtems%{version}-'
I tried replacing all the %{value} to %%{value} in the ini file and that
got past the error,
this however doesn't show up in python2.
after getting past this one, I'm getting another error:
$HOME/myimage
line 1020, in run
argopts.board)
line 297, in load_config
if not path.exists(self['first_stage']):
File "/home/lunatic/development/rtems/rtems-tools/rtemstoolkit/path.py",
line 162, in exists
return _exists(shell(paths))
line 154, in _exists
p = shell(join(os.getcwd(), host(p)))
line 101, in join
path += '/' + shell(arg)
TypeError: cannot concatenate 'str' and 'NoneType' objects
I didn't have a look at this one, maybe I'm missing some options in the
command line?
On Mon, Jun 10, 2019 at 12:55 PM <chrisj at rtems.org> wrote:
> Hi,
> These patches add a new command to the rtems-tools called rtems-boot-image.
> This tool creates boot images for SD cards on FreeBSD, MacOS and Linux. The
> tool lets you boot an RTEMS executable from u-boot from an SD card, or
> you can support networking options and have u-boot perform a net boot.
> The tool uses a configuration file `rtems-boot.ini` that defines the
> boards, commands and formats a board needs. Please update for your
> board and send in patches.
> V2 patches add more network support with network booting and network
> loading
> of a single FDT. I plan to add overlays once I push these patches to
> master.
> Please test and report.
> Finally,the beaglebone black running libbsd is really neat so a big thanks
> to
> everyone who has been working on this BSP and making it happen.
> Thanks
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190610/73aac6a8/attachment-0002.html>
