[PATCH v3 2/2] Add Testsuite for PSXINTTYPES01
Vaibhav Gupta vaibhavgupta40 at gmail.com
Thu Jun 13 19:16:25 UTC 2019
Okay
Just want to confirm, testsuite is fine now?
Vaibhav Gupta
On Fri, Jun 14, 2019 at 12:28 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Jun 13, 2019, 12:57 PM Gedare Bloom <gedare at rtems.org> wrote:
>> Hi Vaibhav,
>> On Thu, Jun 13, 2019, 11:51 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>> wrote:
>>> Remove comments on variable declaration.
>>> Remove licence from Doc
>>> Correct the assert condition for wcstoimax for negative errange
>>> condition.
>> Please squash (git-rebase) the commits to make one, new commit with only
>> the necessary code. Send the new commit as -v2 patch. Thanks
> Sorry, not -v2, you can use -v3 again for the squashed commit. Use -i flag
> to git-rebase. Ask if you need further guidance
>>  testsuites/psxtests/psxinttypes01/init.c      | 26 +++++++++---------
>>>  .../psxtests/psxinttypes01/psxinttypes01.doc  | 27 -------------------
>>>  2 files changed, 13 insertions(+), 40 deletions(-)
>>> diff --git a/testsuites/psxtests/psxinttypes01/init.c
>>> b/testsuites/psxtests/psxinttypes01/init.c
>>> index 8eafae11ac..94df8206c0 100644
>>> --- a/testsuites/psxtests/psxinttypes01/init.c
>>> +++ b/testsuites/psxtests/psxinttypes01/init.c
>>> @@ -52,16 +52,16 @@ rtems_task Init(rtems_task_argument ignored)
>>>    int       base            = 10;
>>>    int       invalid_base    = 40;
>>> -  char     *nptr1_p         = "123abc";
>>> //char* pointing to string with positive number
>>> -  char            *nptr1_p_errange = "9999999999999999999999";
>>>  //char* pointing to string with positive number that is out of range
>>> -  char     *nptr1_n         = "-123abc";                       //char*
>>> pointing to string with negative number
>>> -  char            *nptr1_n_errange = "-9999999999999999999999";
>>> //char* pointing to string with negative number that is out of range
>>> +  char     *nptr1_p         = "123abc";
>>> +  char            *nptr1_p_errange = "9999999999999999999999";
>>> +  char     *nptr1_n         = "-123abc";
>>> +  char            *nptr1_n_errange = "-9999999999999999999999";
>>>    char     *endptr1         = NULL;
>>> -  wchar_t  *nptr2_p         = L"123junk";
>>> //wchar_t* pointing to string with positive number
>>> -  wchar_t  *nptr2_p_errange = L"9999999999999999999999";
>>>  //wchar_t* pointing to string with positive number that is out of range
>>> -  wchar_t  *nptr2_n         = L"-123junk";
>>>  //wchar_t* pointing to string with negative number
>>> -  wchar_t  *nptr2_n_errange = L"-9999999999999999999999";
>>> //wchar_t* pointing to string with negative number that is out of range
>>> +  wchar_t  *nptr2_p         = L"123junk";
>>> +  wchar_t  *nptr2_p_errange = L"9999999999999999999999";
>>> +  wchar_t  *nptr2_n         = L"-123junk";
>>> +  wchar_t  *nptr2_n_errange = L"-9999999999999999999999";
>>>    wchar_t  *endptr2         = NULL;
>>>    intmax_t  result_strtoimax;
>>> @@ -69,7 +69,7 @@ rtems_task Init(rtems_task_argument ignored)
>>>    TEST_BEGIN();
>>> -  /*Test for strtoimax  */
>>> +  /* Test for strtoimax  */
>>>    puts( "\nstrtoimax Testcases...." );
>>>    puts( "Valid Inputs - Positive Number" );
>>>    result_strtoimax = strtoimax( nptr1_p, &endptr1, base );
>>> @@ -105,7 +105,7 @@ rtems_task Init(rtems_task_argument ignored)
>>>    rtems_test_assert( result_strtoimax == 0 );
>>>    rtems_test_assert( errno == EINVAL );
>>> -  /*Test for strtoumax  */
>>> +  /* Test for strtoumax  */
>>>    puts( "\nstrtoumax Testcases...." );
>>>    result_strtoumax = strtoumax( nptr1_p, &endptr1, base );
>>> @@ -141,7 +141,7 @@ rtems_task Init(rtems_task_argument ignored)
>>>    rtems_test_assert( result_strtoumax == 0 );
>>> -  /*Test for wcstoimax  */
>>> +  /* Test for wcstoimax  */
>>>    puts( "\nwcstoimax Testcases...." );
>>>    result_strtoimax = wcstoimax( nptr2_p, &endptr2, base );
>>> @@ -164,7 +164,7 @@ rtems_task Init(rtems_task_argument ignored)
>>>    puts( "Valid Input - Negative Number - Number out of Range" );
>>>    result_strtoimax = wcstoimax( nptr2_n_errange, &endptr2, base );
>>> -  rtems_test_assert( result_strtoimax != 0 );
>>> +  rtems_test_assert( result_strtoimax == INTMAX_MIN );
>>>    rtems_test_assert( errno == ERANGE );
>>>    puts( "Invalid Input - Send NULL Pointer" );
>>> @@ -177,7 +177,7 @@ rtems_task Init(rtems_task_argument ignored)
>>> -  /*Test for wcstoumax  */
>>> +  /* Test for wcstoumax  */
>>>    puts( "\nwcstoumax Testcases...." );
>>>    result_strtoumax = wcstoumax( nptr2_p, &endptr2, base );
>>> diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
>>> b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
>>> index b5fd8e6d0e..607d67015e 100644
>>> --- a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
>>> +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
>>> @@ -1,30 +1,3 @@
>>> - * SPDX-License-Identifier: BSD-2-Clause
>>> - * Copyright (C) 2019, Vaibhav Gupta
>>> - * Redistribution and use in source and binary forms, with or without
>>> - * modification, are permitted provided that the following conditions
>>> - * are met:
>>> - * 1. Redistributions of source code must retain the above copyright
>>> - *    notice, this list of conditions and the following disclaimer.
>>> - * 2. Redistributions in binary form must reproduce the above copyright
>>> - *    notice, this list of conditions and the following disclaimer in
>>> the
>>> - *    documentation and/or other materials provided with the
>>> distribution.
>>> - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>>> "AS IS"
>>> - * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>> TO, THE
>>> - * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>> PURPOSE
>>> - * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>>> CONTRIBUTORS BE
>>> - * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>> - * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>> - * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>> BUSINESS
>>> - * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>>> IN
>>> - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>> OTHERWISE)
>>> - * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>>> OF THE
>>> - * POSSIBILITY OF SUCH DAMAGE.
>>>  This File describes the concepts tested by this test suite.
>>>  inttypes.h - fixed size integer types
>>> 2.21.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190614/91d17456/attachment-0002.html>
