[PATCH v2] Comment added
    Ravindra Kumar Meena
    rmeena840 at gmail.com
    Mon Jun 17 10:45:50 UTC 2019
On Mon, Jun 17, 2019 at 1:45 PM Sebastian Huber <
> On 16/06/2019 20:13, Ravindra Meena wrote:
> >   misc/CTF/record-ctf.ref | 55
> >   1 file changed, 37 insertions(+), 18 deletions(-)
> > diff --git a/misc/CTF/record-ctf.ref b/misc/CTF/record-ctf.ref
> > index a27757c..bdb9648 100644
> > --- a/misc/CTF/record-ctf.ref
> > +++ b/misc/CTF/record-ctf.ref
> >   clock {
> > -    name = ctf_clock;
> > -    freq = 1000;
> > -    offset_s = 1421703448;
> > +    name = ctf_clock; /* name of montonic clock */
> > +    freq = 1000; /* frequency, in HZ */
> Why 1000Hz?
The freq field is the initial frequency of the clock, in Hz. If the freq
field is not present, the frequency is assumed to be 1000000000 (providing
clock increment of 1 ns). I set to 1000HZ just for getting started.
> > +    offset_s = 1421703448;
> What is this for an offset?
This offset is a difference between the beginning of clock and the actual
start of the clock. The event will be recorded just after the offset.
> > + *  A reference to the clock added within an integer type
> >   typealias integer {
> >       size = 64;
> >       map = clock.ctf_clock.value;
> >   } := ctf_clock_int_t;
> Why does this start with "ctf_"?
ctf_clock is the name of clock struct I created just above this. It is a
reference to the clock name.
> > + * Trace stream packet having header and context.
> > + * @param event.header includes id(unique identifier of stream) and
> timestamp.
> > + * @param packet.context includes clock timestamp, cpu id, event and
> event data.
> >   stream {
> >       id = 0;
> > +    event.header := struct {
> > +        uint32_t id;
> What is this for an id?
It is a unique identifier for stream header. There will be many streams so
in order to identify the streams I have set the id here.
> > +        ctf_clock_int_t timestamp;
> Timestamp of what?
 It is the timestamp of the stream header. It is different from event
header. The event heder can have a beginning  and ending timestamp.
> >       packet.context := struct {
> >               uint32_t cpu;
> >               uint32_t event;
> >               uint64_t data;
> > -    event.header := struct {
> > -        uint32_t id;
> > -        ctf_clock_int_t timestamp;
> >   event {
> > -    id = 0;
> > -    name = "ctf_event";
> > -    stream_id = 0;
> > +    id = 0; /* event id
> > +    name = "ctf_event"; /* event name */
> > +    stream_id = 0; /* signifies stream id which event is supposed to
> concat with events */
> >       fields := struct {
> > -        uint32_t a;
> > -        uint16_t b;
> > -        string c;
> > +        uint32_t a; /*event 1*/
> > +        uint16_t b; /*event 2*/
> > +        string c; /*event 3*/
> What are events 1, 2, 3?
I have added this event just for getting started. I thought it would be
better to get it reviewed this much TSDL code.
*Ravindra Kumar Meena*,
B. Tech. Computer Science and Engineering,
Indian Institute of Technology (Indian School of Mines)
<https://www.iitism.ac.in/>, Dhanbad
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190617/1c80501c/attachment-0002.html>
