[rtems-test] sparc/erc32: RTEMS_NETWORKING, RTEMS_POSIX_API: Passed:583 Failed:1 Timeout:1 Invalid:0 Wrong:0
Joel Sherrill
joel at rtems.org
Sat Mar 9 17:22:28 UTC 2019
On Sat, Mar 9, 2019, 11:01 AM Chris Johns <chrisj at rtems.org> wrote:
> On 10/3/19 2:18 am, joel at rtems.org wrote:
> > Testing time : 0:03:48.073542
> > Average test time: 0:00:00.384610
> > Host
> > Linux-3.10.0-862.11.6.el7.x86_64-x86_64-with-centos-7.5.1804-Core (Linux
> rtbf64c.rtems.com 3.10.0-862.11.6.el7.x86_64 #1 SMP Tue Aug 14 21:49:04
> UTC 2018 x86_64 x86_64)
> > Configuration
> > Version: 5.0.0.08ef50ff6a3b712cef5bcdeb78c531bc6a3e0f9e
> > Build : RTEMS_NETWORKING,RTEMS_POSIX_API
> > Tools : 7.4.0 20181206 (RTEMS 5, RSB
> 38241392a4f96dabf2d1aba51a43dcb623db4dfb, Newlib 1d35a003f)
> > Summary
> > Passed: 583
> > Failed: 1
> > User Input: 5
> > Expected Fail: 0
> > Indeterminate: 0
> > Benchmark: 3
> > Timeout: 1
> > Invalid: 0
> > Wrong Version: 0
> > Wrong Build: 0
> > Wrong Tools: 0
> > Total: 593
> > Failures:
> > dl09.exe
> This test needs a lot of memory to run. It loads modules 64K apart to test
> the
> trampolines. I think there is an option to increase the memory of this
> simulator
> but I am not sure.
> I am wondering if we need a file called 'disable -large-memory-tests.tcfg'
> with
> dl09.exe excluded.
Some of the tests are known to be deliberate memory pigs. This would be
good. Commonly excluded tests would be obvious candidates.
I need to investigate the impact of enabling debug and profiling on the
failures. All built for me without those enabled.
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190309/d71b7e8d/attachment.html>
