[rtems-test] sparc/erc32: RTEMS_NETWORKING, RTEMS_POSIX_API: Passed:583 Failed:1 Timeout:1 Invalid:0 Wrong:0
Gedare Bloom
gedare at rtems.org
Tue Mar 12 14:43:25 UTC 2019
Is it feasible to triage the failures for out-of-memory?
On Sat, Mar 9, 2019 at 12:22 PM Joel Sherrill <joel at rtems.org> wrote:
> On Sat, Mar 9, 2019, 11:01 AM Chris Johns <chrisj at rtems.org> wrote:
>> On 10/3/19 2:18 am, joel at rtems.org wrote:
>> > Testing time : 0:03:48.073542
>> > Average test time: 0:00:00.384610
>> > Host
>> > Linux-3.10.0-862.11.6.el7.x86_64-x86_64-with-centos-7.5.1804-Core
>> (Linux rtbf64c.rtems.com 3.10.0-862.11.6.el7.x86_64 #1 SMP Tue Aug 14
>> 21:49:04 UTC 2018 x86_64 x86_64)
>> > Configuration
>> > Version: 5.0.0.08ef50ff6a3b712cef5bcdeb78c531bc6a3e0f9e
>> > Build : RTEMS_NETWORKING,RTEMS_POSIX_API
>> > Tools : 7.4.0 20181206 (RTEMS 5, RSB
>> 38241392a4f96dabf2d1aba51a43dcb623db4dfb, Newlib 1d35a003f)
>> > Summary
>> > Passed: 583
>> > Failed: 1
>> > User Input: 5
>> > Expected Fail: 0
>> > Indeterminate: 0
>> > Benchmark: 3
>> > Timeout: 1
>> > Invalid: 0
>> > Wrong Version: 0
>> > Wrong Build: 0
>> > Wrong Tools: 0
>> > Total: 593
>> > Failures:
>> > dl09.exe
>> This test needs a lot of memory to run. It loads modules 64K apart to
>> test the
>> trampolines. I think there is an option to increase the memory of this
>> simulator
>> but I am not sure.
>> I am wondering if we need a file called 'disable
>> -large-memory-tests.tcfg' with
>> dl09.exe excluded.
> Some of the tests are known to be deliberate memory pigs. This would be
> good. Commonly excluded tests would be obvious candidates.
> I need to investigate the impact of enabling debug and profiling on the
> failures. All built for me without those enabled.
>> Chris
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190312/02ca1c82/attachment-0001.html>
