[PATCH] leon2-sis.ini, leon3-sis.ini: Correct run arguments
Jiri Gaisler jiri at gaisler.se
Thu Mar 14 13:44:27 UTC 2019
I don't think this patch is necessary, the -r option is already present
and does not need to be duplicated.
Jiri.
On 2019-03-14 14:21, Joel Sherrill wrote:
>   tester/rtems/testing/bsps/leon2-sis.ini | 2 +-
>   tester/rtems/testing/bsps/leon3-sis.ini | 2 +-
>   2 files changed, 2 insertions(+), 2 deletions(-)
> diff --git a/tester/rtems/testing/bsps/leon2-sis.ini b/tester/rtems/testing/bsps/leon2-sis.ini
> index 61205ad..d0dd315 100644
> --- a/tester/rtems/testing/bsps/leon2-sis.ini
> +++ b/tester/rtems/testing/bsps/leon2-sis.ini
> @@ -36,4 +36,4 @@ bsp          = leon2
>   arch         = sparc
>   tester       = %{_rtscripts}/run.cfg
>   bsp_run_cmd  = %{rtems_tools}/%{bsp_arch}-rtems%{rtems_version}-sis
> -bsp_run_opts = -leon2 -nouartrx -r -tlim 200 s
> +bsp_run_opts = -r -leon2 -nouartrx -r -tlim 200 s
> diff --git a/tester/rtems/testing/bsps/leon3-sis.ini b/tester/rtems/testing/bsps/leon3-sis.ini
> index 2f933a7..9e8111f 100644
> --- a/tester/rtems/testing/bsps/leon3-sis.ini
> +++ b/tester/rtems/testing/bsps/leon3-sis.ini
> @@ -36,4 +36,4 @@ bsp          = leon3
>   arch         = sparc
> -bsp_run_opts = -leon3 -nouartrx -r -tlim 200 s -m 4
> +bsp_run_opts = -r -leon3 -nouartrx -r -tlim 200 s -m 4
