rtems-libbsd build error
Christian Mauderer list at c-mauderer.de
Fri Mar 15 16:17:19 UTC 2019
Am 15.03.19 um 15:48 schrieb Vijay Kumar Banerjee:
> Hello,
> I am trying to `./waf install` the libbsd but getting some error, need help
> with that. The commands used and the errors are given below ...
> configured using: `./waf configure --buildset=buildset/default.ini
> --prefix=$HOME/development/rtems/5 --rtems-arch=arm`
> configure was successful.
> then : `./waf install`
> Error ...
> Build failed
>  -> task in 'lex__nsyy' failed with exit status 1 (run with -v to
> display more information)
>  -> task in 'yacc__nsyy' failed with exit status 1 (run with -v to
>  -> task in 'lex_pcap' failed with exit status 1 (run with -v to display
> more information)
>  -> task in 'yacc_pcap' failed with exit status 1 (run with -v to
>  -> task in 'objs01' failed with exit status 1 (run with -v to display
> more information)
> more information)
>  -> task in 'yacc_pfctly' failed with exit status 1 (run with -v to
> Thanks
> --vijay
Hello Vijay,
did you try to build before the install? I don't see the call. Normally it's
  waf configure ...
  waf
  waf install
If you did that: It seems that some of the lex / yacc files should be
regenerated. Did you enable --enable-auto-regen somewhen during an
earlier configuration run (not necessary except if you import yacc or
lex files)? Did you import some yacc or lex files?
Best regards
Christian
