rtems-libbsd build error
Christian Mauderer list at c-mauderer.de
Mon Mar 18 21:14:29 UTC 2019
Am 18.03.19 um 20:31 schrieb Vijay Kumar Banerjee:
> On Tue, 19 Mar 2019 at 00:56, Vijay Kumar Banerjee
> <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
>     Hi Christian,
> (it got sent by mistake :) )
> Thanks for telling about the script, now I have the code imported and
> it's building successfully.
> I have forked the repo and created a branch with my commits. Please have
> a look and see if
> It's going in the right direction.
> https://github.com/thelunatic/rtems-libbsd/tree/hdmi_framer
> I have also wrote a first draft of the proposal. Are we supposed to send
> the draft proposals only after the the application period stars? or can
> we just share it offlist with the mentors now?
> Thanks
Hello Vijay,
first regarding the proposal:
@Joel: Please correct me if I'm wrong!
I think it should be OK to discuss the proposal as soon as you have
something. I assume you already have completed the Hello world and sent
it to at least one of our Org Admins?
Regarding the code:
Although the commits need some polishing (see * at the end) it looks
like a good start that you were already able to import and compile some
of the necessary files.
>From what I've seen, you currently pulled in three parts:
1. Some part of videomode. There are some awk scripts in that directory
too so some generated files might need some processing.
2. The iic headers. That looks good. An RTEMS implementation for the
functions most likely is necessary.
3. The driver for the chip that converts from the LCD interface to an
HDMI interface. That's good and necessary too.
What is missing (which is entirely OK at the current phase) are the
following parts:
A. The LCD controller driver itself (am335x_lcd.c, ...).
B. The driver isn't referenced anywhere (normally would be done in
nexus-devices.h for devices that should be always there). So it isn't
linked into the applications yet. That's the reason that you currently
didn't get any `function not found` errors during the linking yet ;-)
C. The framebuffer interface of FreeBSD. I haven't had a detailed look
at that yet. But someone has to do something with the fb_getinfo
DEVMETHOD that is defined in am335x_lcd.c. I'm also not sure whether we
have some generic framebuffer code in RTEMS or whether we should use it
completely from libbsd.
So most likely you will find some more problems when the real work
starts. But it would be no fun if everything would run smoothly ;-)
Best regards
Christian
(*) See hints in CONTRIBUTING.md in chapter "How to Import Code from
FreeBSD". The final commits should be (for each sensible module) one
import commit where unchanged files are imported and one port commit
where the files are added to libbsd.py and necessary changes are made.
>     On Sun, 17 Mar 2019 at 14:30, Christian Mauderer <list at c-mauderer.de
>     <mailto:list at c-mauderer.de>> wrote:
>         Am 16.03.19 um 23:52 schrieb Vijay Kumar Banerjee:
>         > On Sat, 16 Mar 2019 at 01:00, Christian Mauderer
>         <list at c-mauderer.de <mailto:list at c-mauderer.de>
>         > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>> wrote:
>         >     Am 15.03.19 um 19:20 schrieb Vijay Kumar Banerjee:
>         >     > On Fri, 15 Mar 2019 at 21:47, Christian Mauderer
>         >     > <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>
>         <mailto:list at c-mauderer.de <mailto:list at c-mauderer.de>>>> wrote:
>         >     >     Am 15.03.19 um 15:48 schrieb Vijay Kumar Banerjee:
>         >     >     > Hello,
>         >     >     > I am trying to `./waf install` the libbsd but
>         getting some
>         >     error,
>         >     >     need help
>         >     >     > with that. The commands used and the errors are
>         given below ...
>         >     >     > configured using: `./waf configure
>         >     --buildset=buildset/default.ini
>         >     >     > --prefix=$HOME/development/rtems/5 --rtems-arch=arm`
>         >     >     > configure was successful.
>         >     >     > then : `./waf install`
>         >     >     > Error ...
>         >     >     > Build failed
>         >     >     >  -> task in 'lex__nsyy' failed with exit status 1
>         (run with
>         >     -v to
>         >     >     > display more information)
>         >     >     >  -> task in 'yacc__nsyy' failed with exit status 1
>         (run with
>         >     -v to
>         >     >     >  -> task in 'lex_pcap' failed with exit status 1
>         (run with -v to
>         >     >     display
>         >     >     > more information)
>         >     >     >  -> task in 'yacc_pcap' failed with exit status 1
>         (run with
>         >     -v to
>         >     >     >  -> task in 'objs01' failed with exit status 1
>         (run with -v
>         >     to display
>         (run with -v
>         >     to display
>         >     >     >  -> task in 'yacc_pfctly' failed with exit status
>         1 (run
>         >     with -v to
>         >     >     > Thanks
>         >     >     > --vijay
>         >     >     Hello Vijay,
>         >     >     did you try to build before the install? I don't see
>         the call.
>         >     >     Normally it's
>         >     >       waf configure ...
>         >     >       waf
>         >     >       waf install
>         >     >     If you did that: It seems that some of the lex /
>         yacc files
>         >     should be
>         >     >     regenerated. Did you enable --enable-auto-regen
>         somewhen during an
>         >     >     earlier configuration run (not necessary except if
>         you import
>         >     yacc or
>         >     >     lex files)? Did you import some yacc or lex files?
>         >     > I had to install `byacc` package using yum in fedora,
>         then I used the
>         >     > --enable-auto-regen
>         >     > option, that worked.
>         >     > However, it's still not building and I'm seeing a lot of
>         warnings, I
>         >     > think this is because of the
>         >     > files I imported from the freebsd source, maybe they
>         depend on some
>         >     > other headers that
>         >     > I didn't include. Any suggestion on how to debug, if
>         this is the
>         >     case?
>         >     >     Best regards
>         >     >     Christian
>         >     Hello Vijay,
>         >     normally you shouldn't need the --enable-auto-regen
>         option. It only
>         >     changes a lot of files that you don't want to change.
>         Especially: If you
>         >     use Fedora (or some other Linux) you get GPL licensed
>         output. We
>         >     normally use FreeBSD for that step and check in the
>         generated files so
>         >     that no user has to use --enable-auto-regen.
>         >     Regarding how to start such a port: Normally it's a good
>         idea to get
>         >     some overview over what's missing. For that you import the
>         files that
>         >     you think are relevant (like you already did). Then you
>         can build with
>         >     `waf -k -j1` which continues even if some files are not
>         compilable (-k
>         >     is for continue, -j1 so that you receive the messages in
>         order). You
>         >     should get a lot of compiler errors during that run.
>         >     Now comes the hard part: You have to analyse the errors
>         and try to find
>         >     out what's the reason for them. If some big part is
>         missing you most
>         >     likely get a lot of similar errors (like "header xy.h not
>         found"). Most
>         >     likely you can identify some groups. With that you can
>         estimate what has
>         >     to be ported besides the files you already imported.
>         >     Identifying these groups is a quite relevant step for
>         planning the
>         >     amount of work for your GSoC proposal. If you are unsure,
>         try to ask on
>         >     the mailing list. You can also post the build output and
>         an assumption
>         >     what groups you estimate to get some feedback.
>         >     Best regards
>         >     Christian
>         > Hi
>         > I figured out that there were some unnecessary imports I was
>         doing and
>         > also some necessary
>         > header files that I'm missing, after adding those most of the
>         warnings
>         > vanished. The error I'm
>         > seeing now is due to a missing '.m' header file. The error
>         looks like
>         > this ...
>         >    ../../freebsd/sys/arm/ti/am335x/tda19988.c:56:10: fatal error:
>         > rtems/bsd/local/iicbus_if.h: No such file or directory
>         >  #include <rtems/bsd/local/iicbus_if.h>
>         > There's an iicbus_if.m file in the freebsd source which is
>         being included as
>         > ``#include "iicbus_if.h"``
>         > How to work with the .m files ?
>         > Thanks
>         Hello Vijay,
>         that sounds like somewhere during the FreeBSD build process at
>         least the
>         .h file is generated out of the .m file. As far as I can tell,
>         most .m
>         files are processed with the makeobjops.awk script.
>         That's something that isn't yet cleanly integrated into the waf
>         build
>         system yet. Instead there is a "Makefile.todo" in libbsd that is
>         used
>         for this cases. Most likely you can just add that .m file and call a
>         make on that target.
>         Some background for the "Makefile.todo": Originally the libbsd
>         has been
>         build using one big Makefile. Due to the decision that RTEMS
>         should go
>         toward waf, most parts of that Makefile has been replaced. The
>         "Makefile.todo" is the part that is left and should be
>         integrated into
>         waf as soon as someone feels like doing it or finds someone who
>         funds
>         the the time.
>         Regarding iicbus: Most likely that is an interfaces that needs a
>         translation layer so that the RTEMS i2c framework is used. So
>         importing
>         the header with the declarations is good and correct. But you
>         will need
>         to plan some time to implement the functions based on the RTEMS i2c
>         interface.
>         Best regards
>         Christian
