How can I use the covoar tool?
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Wed Mar 20 15:31:29 UTC 2019
On Wed, 20 Mar 2019 at 17:46, Sebastian Huber <
> Hello,
> the RTEMS project has a covoar tool:
> https://git.rtems.org/rtems-tools/tree/tester/covoar
> I have seen some reports generated by it, but I never used it myself. I
> have trouble to find out how it works. There is nothing in the
> documentation:
> cd rtems-docs
> grep -ri covoar .
> There is some documentation available here:
> https://devel.rtems.org/wiki/GCI/Documentation/CoverageAnalysis/Coverage
> If I invoke the rtems-test like this in the erc32 BSP build directory, I
> get an error:
> rtems-test --rtems-bsp=erc32-sis --rtems-tools=/build/rtems/5 --coverage
> --target=sparc-rtems5 .
> RTEMS Testing - Tester, 5.0.not_released
> Command Line: /build/rtems/5/bin/rtems-test --rtems-bsp=erc32-sis
> --rtems-tools=/build/rtems/5 --coverage --target=sparc-rtems5 .
> Python: 3.6.5 (default, Mar 31 2018, 19:45:04) [GCC]
> Host: Linux-4.12.14-lp150.12.48-default-x86_64-with-glibc2.3.4 (Linux
> huber-nb-linux.suse 4.12.14-lp150.12.48-default #1 SMP Tue Feb 12
> 14:01:48 UTC 2019 (268f014) x86_64 x86_64)
> Traceback (most recent call last):
> File "/build/rtems/5/share/rtems/tester/rt/cmd-test.py", line 42, in
> <module>
> test.run(sys.argv[1:], command_path = base)
> File "/build/rtems/5/share/rtems/tester/rt/test.py", line 300, in run
> trace = cov_trace)
> File "/build/rtems/5/share/rtems/tester/rt/coverage.py", line 363, in
> __init__
> self.target = self.macros['target']
> File "/build/rtems/5/share/rtems/rtemstoolkit/macros.py", line 181,
> in __getitem__
> raise IndexError('key: %s' % (key))
> IndexError: key: target
> Hi,
The covoar needs the .cov files to run which is supposed to be generated by
a command like
this
$HOME/development/rtems/5/bin/sparc-rtems5-sis -nouartrx -r -tlim 600 s
-cov
$HOME/development/rtems/kernel/erc32/sparc-rtems5/c/erc32/testsuites/samples/hello.exe
But this runs into a segmentation fault. If my command is right (Please
correct me if it isn't)
then I think it's because the sis coverage is not supported for erc32. :/
about rtems-test,
I have attached a patch that adds erc32-sis-cov.ini, this will fix the
KeyError you're seeing,
but it will return with error 10 as it's trying to run the above command.
If you run rtems-test
with `--no-clean` and `--coverage` options, you'll have a
erc32-sis-symbols.ini file (and the .cov
files, when they're supported, like in leon3), which can be used to run
covoar directly like
below ( but this won't run now as we don't have .cov file )
covoar -S
$HOME/development/rtems/test/rtems-tools/tester/rtems/testing/coverage/erc32-sis-symbols.ini
-O coverage
-E$HOME/development/rtems/test/rtems-tools/tester/rtems/testing/coverage/Explanations.txt
-p RTEMS-5 sparc-rtems5/c/erc32/testsuites/samples/hello.exe
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190320/e5baeb4c/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190320/e5baeb4c/attachment.bin>
