[PATCH 4/4] score: Add ARM CPU architecture group
Mon Mar 25 11:45:07 UTC 2019
Update #3706.
 cpukit/score/cpu/arm/arm_exc_abort.S                |  2 +-
 cpukit/score/cpu/arm/arm_exc_interrupt.S            |  2 +-
 cpukit/score/cpu/arm/cpu.c                          |  2 +-
 cpukit/score/cpu/arm/cpu_asm.S                      |  2 +-
 cpukit/score/cpu/arm/include/rtems/asm.h            |  4 ++--
 cpukit/score/cpu/arm/include/rtems/score/arm.h      |  2 +-
 cpukit/score/cpu/arm/include/rtems/score/cpu.h      |  6 +++---
 cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h  |  2 +-
 cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h  | 12 ++++++++++++
 cpukit/score/cpu/arm/include/rtems/score/paravirt.h | 20 ++++++--------------
 10 files changed, 29 insertions(+), 25 deletions(-)
diff --git a/cpukit/score/cpu/arm/arm_exc_abort.S b/cpukit/score/cpu/arm/arm_exc_abort.S
index c044c0a47f..03f7963eac 100644
--- a/cpukit/score/cpu/arm/arm_exc_abort.S
+++ b/cpukit/score/cpu/arm/arm_exc_abort.S
@@ -1,7 +1,7 @@
  * @file
- * @ingroup RTEMSScoreCPU
+ * @ingroup RTEMSScoreCPUARM
  * @brief ARM data and prefetch abort exception prologue and epilogue.
diff --git a/cpukit/score/cpu/arm/arm_exc_interrupt.S b/cpukit/score/cpu/arm/arm_exc_interrupt.S
index 5afd12d13c..ddcaf945b5 100644
--- a/cpukit/score/cpu/arm/arm_exc_interrupt.S
+++ b/cpukit/score/cpu/arm/arm_exc_interrupt.S
@@ -1,7 +1,7 @@
  * @file
  * @brief ARM interrupt exception prologue and epilogue.
diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
index fe621a2192..07b9588afd 100644
--- a/cpukit/score/cpu/arm/cpu.c
+++ b/cpukit/score/cpu/arm/cpu.c
@@ -1,7 +1,7 @@
  * @file
  * @brief ARM architecture support implementation.
diff --git a/cpukit/score/cpu/arm/cpu_asm.S b/cpukit/score/cpu/arm/cpu_asm.S
index ea6306ac03..66f8ba6032 100644
--- a/cpukit/score/cpu/arm/cpu_asm.S
+++ b/cpukit/score/cpu/arm/cpu_asm.S
@@ -1,7 +1,7 @@
  * @file
diff --git a/cpukit/score/cpu/arm/include/rtems/asm.h b/cpukit/score/cpu/arm/include/rtems/asm.h
index c868b45248..05e186f73c 100644
--- a/cpukit/score/cpu/arm/include/rtems/asm.h
+++ b/cpukit/score/cpu/arm/include/rtems/asm.h
@@ -44,9 +44,9 @@
- * @defgroup ScoreCPUARMASM ARM Assembler Support
+ * @defgroup RTEMSScoreCPUARMASM ARM Assembler Support
  * @brief ARM Assembler Support
diff --git a/cpukit/score/cpu/arm/include/rtems/score/arm.h b/cpukit/score/cpu/arm/include/rtems/score/arm.h
index f8a5470bfb..f753dd60ed 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/arm.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/arm.h
@@ -25,7 +25,7 @@ extern "C" {
 #endif
- * @addtogroup RTEMSScoreCPU
+ * @addtogroup RTEMSScoreCPUARM
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu.h b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
index 3737246f9a..e3e913abfc 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu.h
@@ -40,7 +40,7 @@
  * @defgroup ScoreCPUARM ARM Specific Support
  * @brief ARM specific support.
@@ -96,7 +96,7 @@
 #endif /* defined(ARM_MULTILIB_ARCH_V4) */
@@ -206,7 +206,7 @@ extern "C" {
 #endif
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h b/cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h
index c910ae6821..e25dd25f99 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpu_asm.h
@@ -1,7 +1,7 @@
  * @file
  * @brief ARM Assembler Support API
diff --git a/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
index b856349db3..2c7078b790 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/cpuimpl.h
@@ -17,6 +17,16 @@
 #include <rtems/score/cpu.h>
+ * @defgroup RTEMSScoreCPUARM ARM
+ * @brief ARM Architecture Support
 #define CPU_PER_CPU_CONTROL_SIZE 0
 #ifdef ARM_MULTILIB_ARCH_V4
@@ -122,4 +132,6 @@ RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation( void )
 #endif /* ASM */
 #endif /* _RTEMS_SCORE_CPUIMPL_H */
diff --git a/cpukit/score/cpu/arm/include/rtems/score/paravirt.h b/cpukit/score/cpu/arm/include/rtems/score/paravirt.h
index 08fb8a08ef..d0dc4024e2 100644
--- a/cpukit/score/cpu/arm/include/rtems/score/paravirt.h
+++ b/cpukit/score/cpu/arm/include/rtems/score/paravirt.h
@@ -25,9 +25,9 @@
 #define _RTEMS_SCORE_PARAVIRT_H
- * @defgroup ParavirtARM Paravirtualization ARM Support
+ * @defgroup RTEMSScoreCPUARMParavirt ARM Paravirtualization Support
- * @ingroup Score
  * This handler encapulates the functionality (primarily conditional
  * feature defines) related to paravirtualization on the ARM.
@@ -38,20 +38,10 @@
  *   - Interrupt enable/disable support using the MSR must be disabled
  *     and replaced with BSP provided methods which are adapted to the
  *     hosting environment.
-#ifndef ASM
-#ifdef __cplusplus
-extern "C" {
-#endif
-#ifdef __cplusplus
-#endif
-#endif  /* !ASM */
  * In a paravirtualized environment, RTEMS executes in user space
  * and cannot disable/enable external exceptions (e.g. interrupts).
@@ -72,4 +62,6 @@ extern "C" {
 #define ARM_DISABLE_THREAD_ID_REGISTER_USE
 #endif
2.16.4
