[PATCH 08/25] score: Add Moxie CPU architecture group
Fri Mar 29 10:52:53 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
Update #3706.
 cpukit/score/cpu/moxie/include/rtems/asm.h           | 12 ++++++++++++
 cpukit/score/cpu/moxie/include/rtems/score/cpu.h     |  2 ++
 cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h | 12 ++++++++++++
 3 files changed, 26 insertions(+)
diff --git a/cpukit/score/cpu/moxie/include/rtems/asm.h b/cpukit/score/cpu/moxie/include/rtems/asm.h
index e0d404dced..f328c1ce33 100644
--- a/cpukit/score/cpu/moxie/include/rtems/asm.h
+++ b/cpukit/score/cpu/moxie/include/rtems/asm.h
@@ -41,6 +41,16 @@
 #include <rtems/score/moxie.h>
+ * @defgroup RTEMSScoreCPUMoxieASM Moxie Assembler Support
+ * @ingroup RTEMSScoreCPUMoxie
+ * @brief Moxie Assembler Support
  *  Recent versions of GNU cpp define variables which indicate the
  *  need for underscores and percents.  If not using GNU cpp or
@@ -113,4 +123,6 @@
 #define PUBLIC(sym) .globl SYM (sym)
 #define EXTERN(sym) .globl SYM (sym)
 #endif
diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
index 8485655546..07b5185f5f 100644
--- a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
@@ -1,5 +1,7 @@
  * @file
+ * @addtogroup RTEMSScoreCPUMoxie
diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
index 78b87ef981..9c81cb6193 100644
--- a/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
@@ -17,6 +17,16 @@
 #include <rtems/score/cpu.h>
+ * @defgroup RTEMSScoreCPUMoxie Moxie
+ * @brief Moxie Architecture Support
 #define CPU_PER_CPU_CONTROL_SIZE 0
 #ifndef ASM
@@ -53,4 +63,6 @@ RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation( void )
 #endif /* ASM */
 #endif /* _RTEMS_SCORE_CPUIMPL_H */
2.16.4
