[PATCH 09/25] score: Add nios2 CPU architecture group
Fri Mar 29 10:52:54 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
Update #3706.
 cpukit/score/cpu/nios2/include/rtems/asm.h           | 12 ++++++++++++
 cpukit/score/cpu/nios2/include/rtems/score/cpu.h     |  2 ++
 cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h | 12 ++++++++++++
 3 files changed, 26 insertions(+)
diff --git a/cpukit/score/cpu/nios2/include/rtems/asm.h b/cpukit/score/cpu/nios2/include/rtems/asm.h
index 45ccd8b050..22f3988716 100644
--- a/cpukit/score/cpu/nios2/include/rtems/asm.h
+++ b/cpukit/score/cpu/nios2/include/rtems/asm.h
@@ -39,6 +39,16 @@
 #include <rtems/score/nios2.h>
+ * @defgroup RTEMSScoreCPUnios2ASM nios2 Assembler Support
+ * @ingroup RTEMSScoreCPUnios2
+ * @brief nios2 Assembler Support
  *  Recent versions of GNU cpp define variables which indicate the
  *  need for underscores and percents.  If not using GNU cpp or
@@ -95,4 +105,6 @@
 #define PUBLIC(sym) .globl SYM (sym)
 #define EXTERN(sym) .globl SYM (sym)
 #endif
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
index 4a71987a32..0b32b75e09 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/cpu.h
@@ -1,5 +1,7 @@
  * @file
+ * @addtogroup RTEMSScoreCPUnios2
  * @brief Altera Nios II CPU Department Source
diff --git a/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
index 5f8102009f..e5f326eeb7 100644
--- a/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/nios2/include/rtems/score/cpuimpl.h
@@ -17,6 +17,16 @@
 #include <rtems/score/cpu.h>
+ * @defgroup RTEMSScoreCPUnios2 Nios II (nios2)
+ * @brief Nios II (nios2) Architecture Support
 #define CPU_PER_CPU_CONTROL_SIZE 0
 #ifndef ASM
@@ -45,4 +55,6 @@ RTEMS_INLINE_ROUTINE void _CPU_Instruction_no_operation( void )
 #endif /* ASM */
 #endif /* _RTEMS_SCORE_CPUIMPL_H */
2.16.4
