Interest/Intent to port OpenSSH?
Fri Mar 1 16:01:20 UTC 2019
On Fri, Mar 1, 2019 at 10:52 AM Joel Sherrill <joel at rtems.org> wrote:
> On Fri, Mar 1, 2019 at 2:57 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Hello Gedare,
>> we evaluated porting of OpenSSH some time ago. Something to consider is
>> also Dropbear SSH:
>> https://matt.ucc.asn.au/dropbear/dropbear.html
>> We didn't spend much time with both programs, but it seems to be
>> complex. We ended up with web sockets via HTTPS.
> This would be good to support via a port and the RSB.
Thanks. I have some plan to add an SSH server, but I haven't yet untangled
the complexity of it. Dropbear looks promising--it works under Cygwin so
hopefully the newlib support is sufficient. I think this could be a GSoC
Project, with some proper scoping and some "Extras" in case the porting
turns out to be a bit trivial.
> I thought we had a port of an SSL library but I don't see it in the RSB.
We have OpenSSL in the libbsd. Is that what you mean?
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190301/941bf6c0/attachment-0002.html>
