Query for GSOC Project
Udit agarwal
dev.madaari at gmail.com
Mon Mar 4 10:45:20 UTC 2019
Hello Christian, Vaibhav, Sebastian,
On Mon, Mar 4, 2019 at 3:18 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Am 04.03.19 um 07:47 schrieb Sebastian Huber:
> > Hello Vaibhav Gupta,
> > On 04/03/2019 07:27, Vaibhav Gupta wrote:
> >> I am unable to confirm, if the project is open for GSOC, as some of
> >> them are labelled as new/ need for funding, etc.
> >> So, I made a list of projects which I find interesting. It would be
> >> very helpful for me to finalize a project if mentors confirm which of
> >> the following projects are open/ not open for GSOC.
> >> 1. #3476 : IMFS- Improve bytes per block handling. :
> >> https://devel.rtems.org/ticket/3476
> >> 2. #3477 : IMFS - Add Configurable Allocator Support :
> >> https://devel.rtems.org/ticket/3477
> > the IMFS tickets contain not enough work for a GSoC project.
> >> 1. #3338 : Port CHFS to RTEMS : https://devel.rtems.org/ticket/3338
> > This would be suitable GSoC project if you find a mentor. It needs to
> > deal also with the Erase Block Handler (EBH).
> >> 1. #3428 : Add SDIO driver support to rtems-libbsd :
> >> https://devel.rtems.org/ticket/3428
> >> <https://devel.rtems.org/ticket/3028>
> > I am not sure what the status of this is, it was a GSoC project before.
> > My experience is that this is close to the hardware level and difficult
> > to debug if you don't have a JTAG debugger.
> Last year Udit worked on this project (CC on this mail). See the
> following for the status reports:
> https://devel.rtems.org/wiki/GSoC/2018#UditkumarAgarwal
> The really relevant part of the status is the one from July 18th: The
> driver already started to work but it was still not fully functional.
> After that some more benchmarks have been carried out due to some slight
> direction change in the project.
> For SDIO the stack would have to be updated to the latest version of
> libbsd and some debugging would be necessary. That is most likely not
> enough work left for a complete project.
> Yes, For more detailed status of SDIO stack please have a look at the
following blog posts: (1
<http://uditagarwal.in/index.php/2018/08/01/rtems-sdio-driver-current-progress/>,
2 <http://uditagarwal.in/index.php/2018/08/03/gsoc-2018-final-report/>).
The code has to be updated as per the latest version of libbsd and as
Sebastian pointed out, for debugging
purpose i'd strong recommend the use of JTAG debugger. However, it's a bit
short of being a fully-fledged GSoC project.
Also, How about the idea of porting DTrace to RTEMS? I'm not very sure
about its feasibility, but probably it can turn
out to be a significant addition in RTEMS.
> Kind regards
> Christian
> > Please also have a look at the open projects page:
> > https://devel.rtems.org/wiki/Developer/OpenProjects
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
Regards,
Udit kumar agarwal
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190304/790be773/attachment-0002.html>
