[rtems commit] bsp/lm4f120: Disable unsupported tests
    Sebastian Huber
    Tue Mar  5 06:01:19 UTC 2019
Hello Joel,
On 04/03/2019 22:43, Joel Sherrill wrote:
> Hi
> I thought it was clear that these patches should not be merged. They take
> too broad a stroke and don't make any attempt to resolve the real issue.
Chris complained that the build problems hinder his work to fix the
PowerPC libdl issues with the small-data area:
https://lists.rtems.org/pipermail/devel/2019-March/025016.html
> The psxtm* amd tm* tests can easily be made to fit. Most of the offendiing
> ones respect an OPERATION_COUNT define which controls how many
> objects under test will be created.
> Chris is working on a modification to override OPERATION_COUNT from
> tcfg and that is the more elegant solution.
> Some of the tests likely don't fit but this is a sledgehammer solution
> and ignored the comments that didn't want these patches merged.
> I would have implemented these a couple of months ago if I thought it
> was prudent.
I didn't ignore the comments. I fixed the build problems first and added
tickets for the other issues:
https://devel.rtems.org/ticket/3713
https://devel.rtems.org/ticket/3714
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
