Requirement Management tools
Joel Sherrill
joel at rtems.org
Mon Mar 11 13:36:09 UTC 2019
Thanks Jose.
I think we would like reports to be in Rest so we can use Sphinx and
include them with the RTEMS Documentation Suite. I doubt any of the tools
will meet this requirement. I posted just before this that if we go with
Doorstop, I can see adding this capability.
I like the concept of managing supporting artifacts the same way the code
is. This means we want the files managed in git, able to be version
controlled and ideally diffed. This puts a negative factor on binary
formats. Binary formats also have a tendency to lock you into tools.
I assume we will want to be able to submit fixes. Make sure the tool is
really open source. If I looked at the right repo, the eclipse.org ProR
source looks stagnant while a commercial product which appears to be open
source is active. I am unsure where recent changes go. Just be a bit
cynical.
I know it is premature but are there any thoughts yet on how to implement
fully traceable requirements? To source and then to tests?
--joel
On Mon, Mar 11, 2019 at 8:24 AM Jose Valdez <Jose.Valdez at edisoft.pt> wrote:
> Hello all,
> I am José Valdez from EDISOFT.
> I am working for the RTEMS SMP project which aims to pre-qualify RTEMS SMP
> for space missions.
> I am investigating tools which may partially automate the software
> development process, i.e: Requirements Management, Design and Unit test
> tools and source code analysis and metrics tools.
> Currently I have been investigating myself and also requested Sebastian
> Huber for some tools he knows. With this information I am building an excel
> sheet with the summarized information about the tools (*not yet complete*).
> Could you please help in this discussion, indicating, as far as you know:
> è if do you know other open source Requirement Management Tools
> è if do you know the tools provided and if they are/are not suitable for
> RTEMS SMP
> è if do you remember any tool feature not listed in excel sheet, that is
> relevant or if do you know any feature not listed that may block its
> selection for RTEMS SMP
> As far as I have currently discussed with Sebastian Huber, we have the
> following ideas:
> è Tools which use databases are to be avoided
> è Deprecated tools (“dead projects”) are to be avoided
> è Could be interesting to have a tool which can import/export ReqIf
> standard file
> Looking forward for your suggestions
> Best regards
> José
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190311/8a15832b/attachment-0002.html>
