GSoC: Guidance for POSIX Compilance
Sun Mar 17 16:14:35 UTC 2019
On Sun, Mar 17, 2019, 6:18 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> On Sun, Mar 17, 2019 at 2:10 PM Aditya Upadhyay <aadit0402 at gmail.com>
> wrote:
>> Hi Vaibhav,
>> I saw your doubts on devel mailing list regarding the newlib-c.
>> These are the points, you should know about newlib c and
>> why does most embedded system use newlib c as runtime library.
>> newlib c is used to provide supports to the different platforms and
>> architecute specific compilers.
>> For example:
>> if you have a compiled binary and that you want to run it on a
>> particular platform
>> then this newlib c is used by compiler to invoke some of the built-in
>> functions
>> in that runtime environment.
>> Some low level routines are defined inside the newlib-cygwin that provides
>> architecture support. For example: Stack, Heap, memory management,
>> interrupt facilities is
>> defined in the newlib c and these implementation is architecture
>> dependent.
>> On Sun, Mar 17, 2019 at 10:02 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>> wrote:
>> > Hello Aditya,
>> > First of all Congratulations for your successful completion of POSIX
>> Compilance Project in RTEMS in 2017.
>> > I read your proposal and its impressive. You seem to have done lot of
>> homework on RTEMS that
>> > time.
>> > I am a 2nd year student from JIIT Noida and I am preparing to take same
>> project (POSIX Compilance) this year for GSoC.
>> > I had doubts and asked them on mailing list, then Gedare suggested me
>> to take advice from you as you also went with same processes at your time
>> which I am facing now.
>> For more, You can look into this:
>> https://www.embedded.com/design/prototyping-and-development/4024867/Embedding-with-GNU-Newlib
>> Above link will help you to understand other term like reentrancy concept
>> when you will be going to provide supports in the multi-threaded
>> environment.
>> To understand licensing terms, You can refer here. It will help to
>> figure out the
>> difference between the glibc, newlibc, klibc etc..
>> https://groups.google.com/forum/#!topic/native-client-discuss/_OAQsL77kPQ
>> > It would be great if you can help me out.
>> I would encourage you to test this inttypes test suite code, What
>> I have not yet committed. You just need to change some copyrights things.
>> It would be appreciated if you send a patch on devel. It will help you to
>> understand the code flow and relation between the newlib c and rtems.
>> inttypes methods test suite location:
>> https://drive.google.com/open?id=1vnb0KBhkYLTPzbRJPMuwsnyWLP694VAa
> I did try to run it with following command:
> sparc-rtems5-gcc
> -B/home/varodek/development/rtems/5/sparc-rtems5/erc32/lib -specs bsp_specs
> -qrtems -mcpu=cypress -O2 -g -ffunction-sections -fdata-sections -Wall
> -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
> -Wnested-externs -Wl,--gc-sections -mcpu=cypress init.c
> it gives me error:
> init.c:9:10: fatal error: tmacros.h: No such file or directory
>  #include <tmacros.h>
> compilation terminated.
> Though the headerfile is located at
> /home/varodek/development/rtems/kernel/rtems/testsuites/support/include/tmacros.h
That file is in the RTEMS source tree. His test needs to be built as part
of the test suite.
And did I miss meeting a patch for this? If it is ready, please poke me
with where to get it.
Sorry.
>> > Thanks
>> > Vaibhav Gupta
>> Thanks,
>> Aditya Upadhyay
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190317/dfb5bd1e/attachment-0002.html>
