POSIX Compilance- #2966, GSoC Project 2019
Sun Mar 17 18:24:24 UTC 2019
On Sun, Mar 17, 2019, 12:45 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
wrote:
> I did cloned RTEM source, newlib and rtems-libbsd.
> Kept them in same folder so as to get easy with 'grep' and 'find'.
> $ ls
> newlib-cygwin  rtems  rtems-libbsd
> $ grep -r grantpt ./
> ./newlib-cygwin/winsup/doc/posix.xml:    grantpt
> ./newlib-cygwin/winsup/doc/posix.xml:return -1 and set errno to ENOSYS.
> <function>grantpt</function> and
> ./newlib-cygwin/winsup/cygwin/tty.cc:grantpt (int fd)
> ./newlib-cygwin/winsup/cygwin/libc/bsdlib.cc:      grantpt (master);
> ./newlib-cygwin/winsup/cygwin/common.din:grantpt NOSIGFE
> ./newlib-cygwin/winsup/cygwin/include/cygwin/stdlib.h:int grantpt (int);
> ./newlib-cygwin/winsup/CVSChangeLogs.old/cygwin/ChangeLog-1997:    *
> cygwin.din: srandom, ptsname, grantpt, unlockpt - new exports.
> (grantpt): new
> ./newlib-cygwin/winsup/CVSChangeLogs.old/cygwin/ChangeLog-2001:    *
> tty.cc (grantpt): Fix definition.
> ./newlib-cygwin/winsup/CVSChangeLogs.old/cygwin/ChangeLog-2011:    *
> tty.cc (grantpt): Check for valid fd.
> ./newlib-cygwin/newlib/ChangeLog-2015:    * libc/include/stdlib.h: add
> ptsname, grantpt, unlockpt to cygwin
> ./rtems/testsuites/psxtests/Makefile.am:## lib_a_SOURCES +=
> psxhdrs/stdlib/grantpt.c              See ticket #3645
> ./rtems/testsuites/psxtests/psxhdrs/stdlib/grantpt.c: *  @brief grantpt()
> API Conformance Test
> ./rtems/testsuites/psxtests/psxhdrs/stdlib/grantpt.c:    return_value =
> grantpt(fildes);
> As I analyzed the output, I find no file that contains implementation of
> 'grantpt()', means ticket #3645(https://devel.rtems.org/ticket/3645)
> still needs to be addressed.
> But then how this method is used in rtems testsuites?. (refer last two
> lines of output for grep command).
> Am I doing something wrong? or I am missing something.
You haven't done anything wrong.
The grantpt() method is in a winsup subdirectory which indicates it is a
Cygwin specific implementation.
The psxhdrs test just checks that the prototype us right in the header file.
All said, I don't know if grantpt makes sense on RTEMS or not. That's a
different discussion.
> Thanks
> Vaibhav Gupta
> On Fri, Mar 8, 2019 at 5:31 AM Joel Sherrill <joel at rtems.org> wrote:
>> I'm about to head home so not going to dig into each of those but I
>> will point out for GSoC, we need to get you where you can answer
>> these questions yourself.
>> 1) clone the newlib (sourceware.org/newlib) source, RTEMS source, and
>>     rtems-libbsd source. rtems-libbsd is the source for networking APIs.
>> 2) use "grep -r" (recursive grep) and find (ex: find . -name "XXX") to
>> help you
>>     find implementations.
>> For #3676, RTEMS supports aio but aio.h is one of only a handful of POSIX
>> .h files in RTEMS and not in newlib. That's why the Google Code-In student
>> couldn't find it in newlib. Just scanning the cpukit/include, I see 3
>> POSIX .h
>> files which could be moved to newlib. This is worth discussing on devel@
>> For the rest, I think they are still open to be implemented. Now whether
>> the
>> method makes sense or not on RTEMS or requires more infrastructure than
>> a simple method to be added is something to determine on a case by case
>> basis.
>> --joel
>> On Thu, Mar 7, 2019 at 5:51 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
>> wrote:
>>> It will be very helpful to know the current status of the following
>>> tickets, and if I can choose sub-tasks from them, for GSoC project.
>>> #3676 - Add support for aio.h
>>> #3642 - Add iswalnum(), iswalpha() ... (and 18 others) to <wchar.h>
>>> header
>>> #3371 - Add dirfd() and fdopendir() methods in dirent.h
>>> #3656 - Function prototypes for posix_fadvise() and posix_fallocate()
>>> missing in <fcntl.h> header file
>>> #3652- Add support for sys/resource.h method - getpriority
>>> #3653 - Add support for sys/resource.h method - getrlimit
>>> #3654 - Add support for sys/resource.h method - setpriority
>>> #3655 - Add support for sys/resource.h method - setrlimit
>>> #3644 - Add support for stdlib.h method - getsubopt
>>> #3645 - Add support for stdlib.h method - grantpt
>>> #3646 - Add support for stdlib.h method - posix_openpt
>>> #3647 - Add support for stdlib.h method - ptsname
>>> #3648 - Add support for stdlib.h method - unlockpt
>>> #3643 - Add support for uchar.h header
>>> #3633 - add getdelim() and getline() to stdio.h
>>> Vaibhav Gupta
>>> On Thu, 7 Mar, 2019, 9:57 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com
>>> wrote:
>>>> Hello,
>>>> I was exploring open projects and got very much intrested in the
>>>> following ticket:
>>>> #2966 - POSIX Compilance : https://devel.rtems.org/ticket/2966
>>>> As on the page, the project is divided into multiple sub-tasks. For
>>>> many of them I am not able to find their current status and if enough work
>>>> is left on them to be included as a GSoC project.
>>>> I would like to know the good combinations of sub-tasks which can
>>>> compile into a good GSoC project under the "POSIX" ticket. I am very much
>>>> interested to take this project. It would be great if someone mentors this
>>>> project, I want to discuss further on this.
>>>> Also if there are new any new projects which are not mentioned on
>>>> open-projects page? That can be taken up as GSoC project, I would love to
>>>> explore them as well.
>>>> Thankyou
>>>> Vaibhav Gupta
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190317/e28f8334/attachment-0002.html>
